Har en Ortofon T20 mc trafo til salg
Hadd den fra nye av, fra ca 90 tallet.
DescriptionThe T-20 transformer has been engineered on the same principle as the T-30 so it offers a high performance level.Designed essentially for use with Ortofon moving coil cartridges, which have an internal impedance of 3 ohm per channel, it can also be used with cartridges of different manufacture in the 2 to 4 ohm range.The T-20 includes a bypass position for switching between moving coil and magnetic cartridges.SpecificationsType of unit: transformerPick up impedance: 2 to 4 ohmOutput loading: 47k ohm / 150pfFrequency response: 10Hz to 60kHzPhase linearity: +-18 degreesGain: 32dBChannel balance: 0.2dBChannel separation: 50dBTransformer type: toroidalShielding: permalloy + soft ironDimensions: 40 x 80 x 122mm
http://www.vinylengine.com/library/ortofon/t-20.shtml
