Strømfilter som både beskytter og forbedrer strømmen til dine komponenter. Nypris var vel rundt 4000 når jeg kjøpte den og ser at de fortsatt selges for rundt dette.
Må hentes på Smestad i Oslo.
Sakset fra hjemmesidene til PS Audio
Our very best entry level power center
The Dectet is an active three zone, ten outlet power center producing cleaned unrestricted AC power for an entire high-end audio or video system.
Filtration is handled through large-core high permeability magnetic devices wound with heavy gauge OFC windings. The Dectet offers both common mode and differential mode filtering you can both measure and hear the benefits for yourself. Protection is handled by an internal measurement system that automatically determines over/under voltage conditions as well as full surge and spike protection.
Each of the Power Port outlets on the Dectet are hand wired with a star wiring system that provides similar benefits to having individualdedicatedlines feeding each piece in your high-end audio system.
This is true high-end, despite its entry level pricing. Use the Dectet for you entire system to clean, protect and improve.
