Diamond Revision Aqueou
The Aqueous line of speaker and bi-wire cables, a continuation of the Aqueous Aureus, initially introduced over 5 years ago, was one of the first cables to use Contego (a specific ratio mixture of Fluid and Ferox). The Diamond Revision of the Aqueous further improves the Fluid Ferox mixture! With the enhanced finely stranded alloy conductors and the sleek hand-crafted design, the Aqueous Aureus delivers some of the sonically rich and detailed performance for its price point!
Aqueous formidler musikksignalene gudt over hele frekvensområdet, uten å framheve enkelte frekvensområder på bekostning av andre!
Aqueous heller nok tonalt mot det varme og gir en meget god bass!
Pris 2,4m 21300kr.
The audiophile aims for the highest quality and best sound possible. We offer the Aqueous line in two different configurations, with customization available upon request:
Standard Speaker
Bi-Wire Speaker
These speaker cables come in a two (2) cable set.
The Aqueous Speaker Cables come standard with:
Purist's newly designed spade or banana.
These are our best connectors yet! They are crafted from beryllium copper with silver plating and then a final gold plating.
Additional spade or banana tips can be purchased through your dealer.
Cable Specifications
Aqueous Aureus Speaker/Bi-Wire Specifications
Conductors Alloy
Metals Ag/Cu
Dielectric Material F.E.P. Teflon
Gauge (effective) 10 AWG
Dampening Material Contego
Current Capacity (DC) 55
Resistance 0.000999Ω/FT
Estimated Break-In Time 250 Hours
Cable Diameter (Speaker) 3/4 Inch
Cable Diameter (Bi-Wire) 7/8 Inch
Connector Type Purist Spades & Bananas
Material Treatment Triple (3x) Cryomag©
Pris 2,4m 21300kr.
Aqueous Aureus Speaker Cables
www.puristaudiodesign.com
Standard Speaker
Bi-Wire Speaker
Conductors Alloy
Metals Ag/Cu
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
