Moet Audio
Butikk Revival Atalante 5 - Demosett til salgs 50000kr
Stativhøyttalere
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Rogaland
Pris
Kr 61.900
Annonse beskrivelse
Annonse nummer: 248872
Fullpris 61900 + stativ 4995 kr
Demosett med stativ til salgs 50000kr
Fantastisk test hos Stereo+
Ett knallkjøp til prisen ifølge Stereo+ og 9.7 av 10 i samlet karakter
ear:
Sound Stage Australia
ATALANTE 5, is a 3-way model equipped with the 28mm soft-dome tweeter, 75mm mid-range driver, and its built-in Revival Audio ARID+ (Anti Reflection Inner Dome) patented technology, that can absorb 95+% of resonance in the chamber.
Moreover, the first-ever in High-End BSC (Basalt Sandwich Construction) 12” woofer is the best balance found between rigidity and light-weight, with its great damping construction, provides fast and smooth responses with tight bass dynamics.
ATALANTE 5 has everything you need: Sophisticated high frequencies, sweet mid-tone and impressive bass dynamics.
STATIV: 4999 kr
Type 3-way loudspeaker
Drivers
1 1/8” (28mm) soft-dome tweeter equipped with Revival Audio ARID (Anti Reflection Inner Dome) patented technology with a large back chamber and low resonance frequency of 520Hz
3” (75mm) soft-dome mid-range equipped with ARID+ patent technology
12” (30cm) BSC (Basalt Sandwich Construction) woofer
Frequency Response (+/-3db) 28Hz – 22kHz (-3dB)
Sensitivity (2.83V/1m) 89dB/2.83V/ 1 metre
Nominal Impedance 4 ohms
Minimum Impedance 3.2 ohms at 110Hz
Crossover Frequency 450Hz and 3.5kHz
Recommended Amplifier Power Power handling: 200 watts. Starting from 30-50 watts.
Recommended Room Size 30 to 60m2
Dimensions (H*W*D) 710 mm x 420 mm x 355 mm
Net Weight 33 kg. (72.75 lbs.)
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Avtales nærmere
Moet Audio
Torget karakterer
Vurderinger
Andre annonser av Moet Audio
