Moet Audio
Butikk Revival Sprint 3 - demo i Stavanger
Gulvhøyttalere
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Rogaland
Pris
Kr 13.990
Annonse beskrivelse
Annonse nummer: 248878
Stativhøyttaler ifra Revival i budsjettklassen. Les testen ifra ear.
Prisen er uten stativ.
Pris for stativ: 4990,-
Best buy i ear
Sprint 3 Finishes Well | The Ear (the-ear.net)
SPRINT 3 - Punches Above Its Weight! | Revival Audio
KEY FEATURES
SPRINT’ing Miles Ahead! A 100% Original Innovation
SPRINT 3, the 2-way standmounter inherits the ATALANTE line technologies.
SPRINT proudly inherits the same technology that powers our ATALANTE line, with a twist that makes it uniquely SPRINT. It features a 28mm RASC soft-dome tweeter and built-in ARID (Anti-Reflection Inner Dome) patented technology. With its specialised back-chamber design, this stylish speaker design is capable of absorbing over 95% of unwanted resonance within any space to elevate your listening experience, whether you’re reminiscing over your vintage vinyls or playing your favourite new playlists of the 21st century.
SPRINT also features the high-end BSC (Basalt Sandwich Construction) 7” woofer, perfectly balancing out rigidity and lightweight design. With superior damping construction, SPRINT promises a rapid yet smooth response with impressively tight bass dynamics.
The ELYTRON front baffle is an original Revival Audio creation; a stylish speaker design developed through hundreds of hours of painstaking simulation. Such listening precision has never been seen before at its level, and won’t be seen again soon from any other manufacturer, unless they copy SPRINT. But that’s ok, because that’s our goal: To create new trends and technology in the speaker industry, with sound precision that must be heard to be believed.
TECHNICAL SPECIFICATIONS
Type2-way bookshelf loudspeaker
Drivers
  • 1 1/8” (28mm) soft-dome tweeter equipped with Revival Audio ARID (Anti Reflection Inner Dome) patented technology with a large back chamber with the low resonance frequency of 650Hz
  • 7” (18cm) BSC (Basalt Sandwich Construction) woofer
Frequency Response (+/-3db)55Hz – 22kHz (-3dB)
Sensitivity (2.83V/1m)87dB/2.83V/ 1 metre
Nominal Impedance6 ohms
Minimum Impedance4.5 ohms at 175Hz
Crossover Frequency1.8kHz
Recommended Amplifier PowerPower handling: 150 watts, starting from 30 watts.
Recommended Room Size15 to 35 m2
Dimensions (H*W*D)380 mm x 213 mm x 307 mm
Net Weight9.1 kg (20.06 lbs.)
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Moet Audio
Torget karakterer
Vurderinger
Andre annonser av Moet Audio
