SATA filter II and SATA filter III are a noise filter that upgrades PC sound by blocking noise from HDD, ODD & SSD.
– Ripple & RF noise filter are used.
– Connect to SATA connector of storage device directly.
SATA Filter III has solved the compatibility issue between SATA Filter II and SATA 3 devices by removing the SATA signal line completely. The flexible PCB is designed to be bent for only necessary portions, it helps not to damage the other components.The high quality components used on SATA filter III make the sound much stable and tight.
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
