2Track Suder B67 i god stand.
Tekniske data (fra The Recodman):
The B67 can be considered the compact version of the A80R. Presented in 1973 and produced until 1982, it was replaced by its successor the A810. Its functions, in a compact version, are the same of the A80R, exception made for the Edit and the back to Zero functions.
• 2 tracks stereo recorder, ¼ inch (6,35 mm).
• Rack 19” portable recorder with wooden side panels and handles.
• Tape speeds: 15 - 7.5 – 3,75 ips (38.1 - 19.05 – 9,5 cm/sec.).
• Equalization: CCIR.
• Tape Reel: CINE (EIA) -Trident.
• Reel size: up to 10,5” (26,5 cm) for metal reels or plates.
• Balanced XLR input and output.
• Digital timer display; H, Min, Sec.
• Reset timer function; manual pause button; headphone output (jack 6,3mm).
• Butterfly heads.
• Spooling time: about 145 sec. for 760 mt. of tape.
• Weight: about 35 Kg
• Dimensions: H x W x D, 510 x 483 x 237 mm.
• Power absorption: about 85 W in Stop, 170W Play-Rec, 190W FF-Rew.
• Voltage selector: from 100 to 240 Volt, 50-60 Hz.
• Butterfly heads.
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
- Forsendelse
- Avtales nærmere
