Hei,
Selger en Synergistic Research Ground Block med følgene kabler:
- 1 each (10 ft) standard wall ground wire to connect SR Ground Block to the wall
- 1 each (4 ft) standard ground wire USB
- 1 each (4 ft) standard ground wire RJ45
- 1 each (4 ft) standard ground wire Banan 4mm
- 2 each (4 ft) standard ground wires: Enough to connect up to 2 pairs of SR Atmosphere or Galileo UEF Series Interconnects or Speaker Cables
- 2 each (8 ft) standard ground wires with mini spade, 4mm
- 1 each (4 ft) High Def ground wire RCA
Original forpakning så sending ingen problem.
Mvh Magne
Mvh Magne
- Originalemballasje
- Ja
- Orig. kvittering
- Nei
- Forsendelse
- Kan sendes
