Strømfilter med 8 uttak. Solid aluminiums boks med meget god internkabling med OFC kobber med 4mm2 kabeltykkelse. Overload beskyttelse. Norsk importør er K-Audio.
This filtered mains distributor Viborg VE80 has 8 Schuko sockets. Filtering provides a clean and stable current to supply your HiFi devices correctly and thus limit noise. The power strip benefits from excellent manufacturing quality with a robust aluminum housing and an internal cable with OFC Copper conductors with a cross-section of 4mm². This power supply unit also has overload protection.
Sjekk:
The Power Surge Protector and Overload Protection feature helps to safeguard your equipment against sudden power surges, ensuring prolonged equipment lifespan and safe usage. The sockets will be powered off when total current over 15A, press RESET button to restore power supply.
Sjekk:
- The unit features 8 hospital grade power outlets, which provide plenty of space for you to connect all your equipment easily and in one place. This eliminates the need for multiple power strips or extensions.
- It ensures that all devices connected to VM80 receive clean & filtered power, which reduces noise and ensures better sound and picture quality from amplifier, DJ equipment, home recording, projector, TV, computer, and other electronics.
- The Power Conditioner and Power Distributor helps to regulate the voltage supplied to your equipment, ensuring a consistent and stable voltage. This allows your audio and video components to operate optimally, without any damage.
- This Viborg HiFi power filter is designed with advanced technology to deliver pristine power to your audio and video components, without any interference or noise.
SPECIFICATIONS | |
Product type | Filtered power distributor |
Number of filtered plugs | 8 |
Plug type | Schuko |
Max. power | 3300W |
Max. current | 15A |
Internal wiring | OFC Copper conductors 4mm² |
Supply voltage | 220-250V 50Hz |
Protection | Surge protection |
GENERAL | |
Case material | Aluminium |
Dimensions | 380 x 160 x 95mm |
Weight | 3kg |
Color | Gray |
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
