Et moderne utseende, fullpakket med kvalitet!
For Bestilling eller spørsmål ta kontakt her: Endpoint Audio
Eller ring meg på 47832922 - Jeg har demomodell tilgjengelig.
Mvh Tom Egil
Denne kommer med noen ekstravalg som velges ved bestilling.
Extended Carbon Pack
Extra carbon fibre shielding for the input, output, volume, and power supply section of the Quest. Enhancing the background darkness, micro-details,
texture and emotion of the music playback. 29.880,-
Extended Connection Pack
This pack add two additional remote trigger output for ease of operation. Compatible with the Rei / UNUM and most amplifier on the market.
10.680,-
Gloss Carbon Finish
Gloss Carbon Replaces the top cover with gloss finishes carbon fibre.
11.880,-
Ektravalg som kan bestilles også etter levering.
RCA input RCA input expansion card
21.500,-
Phono Input ( RCA ) MC Phono ( RCA ) input expansion card / Phono Input ( XLR ) MC Phono ( XLR ) input expansion card / DS Audio Equaliser (RCA) input
69.500,-
QUEST – Reinventing The Wheel
The ultimate aim of the Quest is to create the perfect preamplifier to accompany the Rei and the cables lineup. With the Quest, it completes the loom between your source and pair of speakers. Setting out to push the boundary, it redefines how a preamplifier can contribute to the system and the ability to extract every bit of potential from both the recorded music and the music reproduction system.
During the inception of the project, we endlessly question the role of the preamplifier in an audio system, and constantly challenge whether a pre-amplifier is absolutely necessary in a system and what qualities the added stage can bring or may bring to the outcome. We begin with a fresh start to investigate the relationship between the source and the amplifier. Every section of the preamplifier has been looked at thoroughly to see how we can improve every single part and also what kind of synergy we can extract from them.
Full balanced Dual-Mono pre-amplifier from WestminsterLab.
Complete full balanced circuitry with hand picked through whole components matched to 0.5%. Hand soldered and hand crafted in
Hong Kong. Sandblasted aluminium finish with carbon top cover as standard.
SPECIFICATION
Quest
Distortion
<0.0001% @ 1kHz
Signal-to-Noise Ratio
>120dB, unweighted
Input
3 sets of balanced XLR input
2 optional modules
Input Impedance
51 kΩ
Input Voltage
6Vrms
Frequency Response
2Hz to 100kHz, 0.1dB
Outputs
2 sets of balanced XLR outputs
Output Voltage
12Vrms
Channel Separation
>120dB
Gain
6.5dB
Volume Control Range
0 to -63dB / Mute
Dimensions
W470 x H110 x D392 mm
Weight
13.2KG
OPTIONAL MODULE SPECIFICATION
DS Audio Equaliser
Input
1 set of unbalanced RCA input
Gain
27dB
Compatibility
All DS Audio cartridges. DS Audio certified equaliser.
Outputs
19pin proprietary socket
MC/MM Phono
Input
1 set of balanced XLR input or
Input Impedance
60Ohm to 47kOhm ( 18 steps )
Loading Capacitance
22pF to 322pF ( 5 steps )
Gain
40dB to 70db ( 4 steps )
Compatibility
Variety of modern and vintage MC/MM/MI cartridges.
Outputs
RCA Input
Input
Input Impedance
51 kΩ
Input Voltage
6Vrms
Frequency Response
Outputs
Gain
6dB
Mvh Tom Egil
10.680,-
Gloss Carbon Finish
11.880,-
21.500,-
69.500,-
SPECIFICATION
Quest
Distortion
<0.0001% @ 1kHz
>120dB, unweighted
Input
2 optional modules
Input Impedance
51 kΩ
Input Voltage
6Vrms
Frequency Response
Outputs
Output Voltage
12Vrms
Channel Separation
>120dB
Gain
6.5dB
0 to -63dB / Mute
Dimensions
Weight
13.2KG
DS Audio Equaliser
Input
Gain
27dB
Compatibility
Outputs
MC/MM Phono
Input
Input Impedance
Loading Capacitance
Gain
Compatibility
Outputs
RCA Input
Input
Input Impedance
51 kΩ
Input Voltage
6Vrms
Frequency Response
Outputs
Gain
6dB
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
