The whestTWO.2 is built to complement any entry level turntable front-end but more than that can be integrated into any high-end turntable front-end system because of its inherent high-resolution capabilities.
Like all whest audio phono stages the whestTWO.2 is tonally neutral which is a unique trait at this price level. This allows you to hear everything in the recording at their correct levels. The higher frequencies are not pushed forwards, nor the bass recessed. This is in-part thanks to our heritage in small signal design, design of microphone preamplifiers and our understanding of ultra-low-noise solid-state circuitry.
Connecting the whestTWO.2 like all whest audio phono stages is easy and flexible. 1 pair of audiophile quality RCA connectors for the input section with a substantial ground post for the turntable ground. For outputs, 1 stereo pair are available via RCA, for connecting to a main system. A 2nd output on balanced 3 pin XLR can be used to connect your whestTWO.2 to a stand-alone digital or analog recorder or headphone amplifier for accurate and low noise transfer work or high quality headphone listening.
With the whestTWO.2 high-resolution vinyl playback is within your reach – it always has been.
www.moetaudio.com
![www.moetaudio.com](https://www.moetaudio.com/assets/img/630/630/bilder_nettbutikk/0d344f0e12e8c0c598219db6cbbbb5ed-image.jpeg)
Whest TWO.2 high resolution entry level phono stage
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
