I demo i butikken i Stavanger. muligheter for hjemlån.
Taking the whestTWO.2 further comes the new 2022 whestTWO.2 Discrete. It is built to complement any entry level turntable front-end but more than that can be integrated into any high-end turntable front-end system because of its inherent high-resolution.
Like all whest audio phono stages the whestTWO.2 Discrete is tonally neutral and has plenty of current drive making it the perfect partner for any high-end system. Like its smaller sibling, the whestTWO.2 Discrete owes much to our heritage in small signal design, design of microphone preamplifiers and our understanding of ultra-low-noise solid-state circuitry.
Connecting the whestTWO.2 Discrete like all whest audio phono stages is easy and flexible. 1 pair of audiophile quality RCA connectors for the input section with a substantial ground post for the turntable ground. For outputs, 1 stereo pair are available via RCA, for connecting to a main system. A 2nd output on balanced 3 pin XLR can be used to connect your whestTWO.2 Discrete to a stand-alone digital or analog recorder or headphone amplifier for accurate and low noise transfer work or high quality headphone listening.
With the whestTWO.2 Discrete high-resolution vinyl playback is within your reach.
Dimensions – W252 x D250 x H60mm
WhestTWO.2 Discrete high resolution phono stage
www.moetaudio.com
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
