Moet Audio
Butikk YBA Passion A650 Power Amplifier - i demo
Denne annonsen er utgått.
Effektforsterker
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Rogaland
Pris
Kr 78.800
Annonse beskrivelse
Annonse nummer: 241803
Kraftfull, musikalsk, engasjerende og utømmelig, er synonymer for franske YBA sitt effekt-trinn som også enkelt kan kjøres som monoblokker. Står som monoblokker i demo, kan enkelt kobles om til stereo. Dette trinnet bør virkelig vurderes oppimot andre. Har også et tøft VU meter. Kabinettet er i lekker aluminium, og alle delene er franske! (Skrudd sammen i Kina).
https://www.moetaudio.com/produkt/f...terker/yba-4/yba-passion-a650-power-amplifier
YBA Passion 650 never hides its origins. It’s a music lover’s amplifier that clearly translates Yves-Bernard André’s vision and passion. The 650 has more than enough potency in its design to translate music with power, dynamics, natural transparency and most important, correct timbre and musical imprint. Passion needs no second guesses. Seamless integration of technology in the service of music is evident even after those first few musical notes.
Within its price range Passion 650 offers one of the most complete power amplifier packages that bring not only great sound, but standout aesthetics. In this day and age YBA offers great value and pleasure for both the ears and the eyes! There are eye catching details like the power output meter on the front panel and the heatsinks on either side shaped into the company name.
The power amplifier rests on three feet; one in front, two in the back, which is synonymous with YBA. The mains power switch is hidden from sight on the bottom panel, towards the front edge. The backlight brightness is adjustable in four steps from the remote control unit, and can also be switched off altogether. The amplifier’s rear panel includes two pairs of gold plated speaker outputs – speaker A has the higher quality sound. It has stereo RCA and balanced inputs plus a mono balanced input if it is to be used in bridged mono mode.
SPESIFIKASJONER
Product type
Power Amplifier
Audio Outputs
2 Pairs Speaker Outputs
Power Outputs
Stereo 200W @ 8 Ohms per channel
Stereo 400W @ 4 Ohms per channel
Mono 600W @ 8 Ohms bridged
SNR
>95dB
Frequency Response
20Hz – 20kHz (-0.5dB)
THD+N (20Hz - 20kHz)
<0.1%
Inputs
1 RCA, 1 Balanced Input (Stereo)
1 Balanced Input (Mono)
Power Supply
Linear power supply with high performance UICore
transformer 1000VA
Color / Finish
Natural aluminium
Dimensions (w x d x h)
430 x 397 x 178mm
Weight
25 kg
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Moet Audio
Torget karakterer
Vurderinger
Andre annonser av Moet Audio
