Butikk YBA Signature Pre MKII
Forforsterker
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Buskerud
Pris
Kr 159.900
Annonse beskrivelse
Annonse nummer: 245987
Signature PRE offers a XLR input, an array of 5 RCA inputs and also a dedicated MM Phono input. On the side of outputs, Mark II version implements a pair of XLR outputs and single RCA output. Making it a versatile choice for wide range of Hi-Fi setups, all easily controlled with our classic YBA remote controller.
In the centre of the embossed YBA logo on the front panel is a standby switch, which responds to the touch of a finger. The source selector rotates through 10 different inputs and phase and mute switches are on the right-hand side along with the rotary encoded volume control.
New Mark II version brings quite a few improvements in its digital section, mainly thanks to the Analog Devices AD1955 DAC, with a native support of PCM up to 24 bit / 192 kHz and DSD64. USB input was also significantly upgraded with the XMOS controller, offering the top-quality sound with a direct connection to your computer. Optical and coaxial inputs are still included for use with other digital sources.
For use with a separate DAC or CD player, the whole digital section can be quickly disabled, resulting in an improved performance of its analog circuit.
Product typePreamplifier
Audio Outputs2 Balanced XLR & 1 RCA
Audio Inputs1 Balanced XLR, 5 RCA & 1 Phono
D/A ConverterAnalog Devices AD1955 – Native support up to 24/192 & DSD64
USB InputXMOS XU208 – PCM 32bit / 768 kHz & DSD512
Other Digital InputsOptical & Coaxial
Gain+6dB
SNR>110dB
Frequency Response20 Hz – 40 kHz (-0.5dB)
THD+N>0.0009% (20 Hz – 20 khz)
Power SupplyLinear power supply with high performance UI-Core transformer 190VA
Color / FinishNatural aluminium
Dimensions (w x d x h)430 x 388 x 151 mm
Weight27.5 kg
Sound of Heaven tilbyr:
+ Innbytte ( god pris for ditt utstyr )
+ Nedbetalingsplan ( rente og gebyrfritt)
+ Gratis frakt i hele Norge
JWK Audio/Sound of heaven
Tlf:+47 464 29 861
E-mail: kontakt@soundofheaven.as
Hjemmeside: www.soundofheaven.as
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
sound of heaven
Torget karakterer
Vurderinger (3)
Andre annonser av sound of heaven
