mteinum
Dette er nok formater for de mer interesserte av oss, men nå er jo også dette et entusiastforum
Musikk
Vel, svært begrenset.
Her er en oversikt som Sony har samlet:
http://www.ps3sacd.com/dsd_downloads.html
Software
Foobar med DSDIFF Decoder
http://www.foobar2000.org/components/view/foo_input_dsdiff
HQPlayer
http://www.signalyst.com/consumer.html
Korg AudioGate
Konverterer DSD on-the-fly (til PCM) så disse kan spilles av via lydkortet/dac'en som er tilknyttet maskinen.
http://www.korguser.net/audiogate/en/index.html
Hardware
Ikke mye her heller. Mytek ser ut til å komme en DSD DAC i april.
http://ralaudio.com/mytek-stereo192dsd-dac-24-bit-192-khz-dsd-dac-preorder-now-p-4306.html
Playback Designs
http://www.playbackdesigns.com/mpd3.html
DIY
http://www.diyaudio.com/forums/digital-source/177336-usb-dsd-dac-adc-electrart.html
Noen som har utforsket dette?
Hadde det bare eksistert en SACD ripper 1:1 så kunne dette vært et meget spennende felt innen hires.
Edit: Se neste innlegg
http://en.wikipedia.org/wiki/Direct_Stream_DigitalDirect-Stream Digital (DSD) is the trademark name used by Sony and Philips for their system of recreating audible signals which uses pulse-density modulation encoding, a technology to store audio signals on digital storage media which is used for the Super Audio CD (SACD).
Musikk
Software
HQPlayer
Korg AudioGate
Hardware
http://puresuperaudio.blogspot.com/2010/08/mytek-digital-usa-to-unlock-dsd-files.htmlIn comes MYTEK DIGITAL, the US leading manufacturer of digital audio converters, with its new DAC. Aside from basic capabilities of handling hi-rez PCM files (up to 24/192), it will be a first device letting you play native DSD files directly from your hard drive, "with absolute state of the art accuracy and transparency". Mytek has not yet revealed if the device will support both DSD 2.8MHz and 5.6MHz files (although already available Mytek A/D converters offer support for both sampling speeds).
Playback Designs
DIY
39.6 KB Visninger: 2.771
