- Ble medlem
- 28.05.2009
- Innlegg
- 2.036
- Antall liker
- 160
Før du bestemmer deg for om du skal le eller gråte: http://www.ysxbcn.com/upfile/soft/2010626/1998-2-20.pdfSkal man le eller gråte...? Makan til tullprat!I relasjon til debatter om hva som er best av kobber, sølv eller forsølvet kobber, kan det være interessant å lese den spesielle løsning som LAT International har laget:
"EXPLANATION OF OUR PROPRIETARY SILVERFUSE CONDUCTOR MATERIAL: Silverfuse is a near alloy of silver and copper. The copper used in this process is Single Crystal Continuous Cast Copper. It has unique physical and chemical properties, such as considerably longer granules with absolute absence of gaseous impurities such as oxygen, carbon, hydrogen and nitrogen. It is free from impurities (up to 99.99998% pure copper). It is far better than continuous cast Oxygen Free High Conductivity wire (OFHC). IT IS NOT SILVER PLATED. Silver plating causes a dioding effect when signal is passed through resulting in brightness and distortion. Because silver plating has a bad reputation, some manufacturers try to disguise the fact by calling it silver coated, silver clad or silver/copper hybrid. But they are all silver plated. Our Silverfuse process starts with Single Crystal Continuous Cast Copper wire with a diameter that is slightly larger than the required size. It is then pulled through a trough of molten silver. The wire with a silver deposit is then forced through a compacting process where it is subject to tremendous pressure. The silver and the copper are fused together into a near alloy. The compacting fusion also reduces the wire diameter to the desired size. No dioding subsequently occurs with this process. The result provides for the benefits of silver; which are excellent definition and clarity, with the high purity copper benefits of warmth and mellowness. (Incidentally, pure silver wire also causes brightness)"Først så snakker de om singelkrystalinsk kobber, som om at det overhode skulle la seg gjøre å trekke en sammenhengende kobberkrystall i en lengde. Så fremstiller de det som om deres elektrolyttisk rensede kobber er noe unikt, så påstår de at elektrolyttisk forsølving av kobber gir dårlige egenskaper. I neste omgang forsøker de å fremstille det som om at sølvet fester seg på en annen (og bedre) måte med varme enn med strøm. I tillegg har de "mage" til å henge ut andre som useriøse..??
Denne teksten har mer i "Dilldalltråden 1.5" å gjøre, enn i en (singelkrystalinsk)kabel-tråd...
http://www.springerlink.com/content/x63q372013574543/
