Fordi at?finnes ikke tørket sand hos byggehandlere eller lignene?
jeg ville ikke bruke metalsand
Produktet Atacama Atabites har forandret seg over tid og også mellom produksjonsbatcher. Man kan derfor finne beskrivelser og bilder av Atacama Atabites som er meget ulike.Atacama Atabites - cirka 450 for ett spann på 7,5kg - består av galvaniserte rester fra spikerproduksjon.
Vi skrev en god del om Atacama Atabites i tråden "Hvor kjøpe bly?":Description
In order to get the best possible sound from your speaker stands, it is reccomended that the main columns are filled with a high density inert filler .This will reduce ringing and give a sonically dead platform from which to position bookshelf style speakers. By adjusting the amount of filler used, you can experiment to find the optimum amount of filler to suit your speakers .Featuring new zinc coated micro-discs, the NEW UPGRADED Atabite inert filler now gives increased density to volume over the old Atabite inert filler and has a uniformed particulate size giving consistant sonic performance. The Zinc coating reduces any oxidisation and degradation and enhances the visual aesthetics.
PLEASE NOTE- Atabites are supplied by weight, not volume. (7.5 KG tubs). Some settling of contents may occur in transit. Here is the maximum Approximate weight of Atabites that can be used in each pair of speaker stands:- Duo 6=10.4KG Duo 7=12.2Kg Duo 10=N/A Nexus 6i=8.2KG Nexus7i=12.2KG Nexus10i=21KG SL200=7.2KG SL300=15.2KG SL400=24KG SL500=32.8KG SL600=41.6KG SL700=48.8KG SL1000=68KG HMS1.1 500mm=34KG HMS1.1 600mm=41.8KG HMS1.1 700mm=55.4KG HMS2.1=84KG. Sonic results will depend on speaker stand positioning, type of speaker, room size, type of electronics and cabling, listening position and personal taste. However, as a general rule filling the stands approximately two thirds full generally gives the best results. NOT suitable for Aurora 6 Speaker stands.
Atacama Atabites leveres nå i spann á 9 kg brutto. Konsistens og utseende varierer mellom produksjonsbatcher. Spannet er normalt ikke fullt som på bildet
Atacama Atabites importeres av Akustikk: http://www.akustikk.no/atacama_tilbehor.htm
Renaissance Audio i Bergen selger Atacama Atabites. Hvis Akustikk har det på lager, noe de normalt har, tar det i underkant av en uke.
Vær dog obs på at massetettheten (utseende, konsistens m.m.) varierer mellom produksjonsbatcher. Hvor mange liter et spann fyller varierer m.a.o. fra produksjonsbatch til produksjonsbatch og kan derfor hverken forutsies eller beregnes på forhånd. Man må altså kjøpe noe, fylle på og bestille mer inntil man er i mål.
Tillegg:
Jeg har originale stativer for KEF Reference 201/2. Jeg fikk akkurat plass til 3 spann Atacama Atabites fra 3 ulike produksjonsbatcher i hvert stativ (3 spann x 2 = 6 spann). Da var det kun igjen ca. 2 cm for å unngå Atabites i gjengene for topplaten (gjengene er delvis åpne ut mot søylekamrene).
Hvis alle spannene hadde vært fra samme produksjonsbatch, ville jeg hatt plass til fra ca. 2,8 til 3,7 spann per stativ avhengig av produksjonsbatch (hvis jeg husker korrekt ang. mine beregninger).
