Paradox Audio slipper endelig sine planlagte high end signalkabler. De kommer i både ubalansert RCA og balansert XLR variant med de originale navnene ”Unbalanced” for RCA og ”Balanced” for XLR versjonen. Begge har ledere av høykvalitets kobber, dobble lag skjerming og har veldig gode inductance/capacitance verdier. De blir levert i par med Rhodium platerte kobberplugger for både XLR og RCA versjonen.
Unbalanced RCA interconnect:
Unbalanced RCA interconnects with double shielding and incredibly low capacitance and inductance. Made with the purest of copper, silver and connectors of rhodium plated tellurium copper, it has the same conductivity to pure copper but with much higher hardness and shown oxidation resistance. Each connector is housed in a carbon cover and the cable is wrapped with exclusive braided sleeving making this interconnect truly worthy of the most expensive of high end setups with extremely low distortion and signal loss enhancing crystal clear sound.
Balanced XLR interconnect:
Balanced XLR interconnects with double shielding and incredibly low capacitance and inductance. Made with the purest of copper, silver and connectors of rhodium plated tellurium copper, it has the same conductivity to pure copper but with much higher hardness and shown oxidation resistance. Each connector is housed in a carbon cover and the cable is wrapped with an exclusive braided sleeving making this interconnect truly worthy of the most expensive of high end setups with extremely low distortion and signal loss enhancing crystal clear sound.
www.paradox-audio.com
Conductors | 2x24 AWG (2x0,34mm) Extremely pure copper 99,99% with silver soldering |
Connector | Carbon housing with rhodium plated tellurium copper. Tellurium copper: 99.5% copper, 0.5% Te and 0.008% phosphorus |
Insulation | Layers of PVC and PE. Double shielded with aluminum foil, copper mantel and bicoupled copperwires. All wrapped in high class braided sleeving |
Measurements | 0,31 inches diameter (7,6mm diameter) |
Resistance | 0,01614 Ohms per foot (0,02105 Ohms per M) |
Inductance | Below 0,1 uH per M |
Capacitance | 22,86 pF per foot (75 pF per M) |
Conductors | 4x26 AWG (4x0,22mm) Extremely pure copper 99,99% with silver soldering |
Insulation | Layers of PVC, PE and ultrathin SFRS covered with thread. Double shielded with aluminum foil, copper mantel and bicoupled copperwires. All wrapped in an exclusive braided sleeving |
Measurements | 0,4 inches diameter (9mm diameter) |
Resistance | 0,02567 Ohms per foot (0,03349 Ohms per M) |
Capacitance | 25,86 pF per foot (84 pF per M) |
