Digital reproduction of analogue sound
At venue recording sessions our analogue to digital converters can do both the one-bit DSD and the multi-bit PCM formats. We can also listen directly to the analogue output from the microphones. Digital eXtreme Definition is a professional audio format that brings “analogue” qualities in 24 bit at 352.8 kHz sampling rate. DXD preserves 8.4672 Mbit/s (3 times the data of DSD) per channel. This leaves headroom for editing and balancing before quantizing to DSD for SACD or PCM for Blu-Ray.
All audio formats on The Nordic Sound are sample rate converted from the same DXD master. Comparing them in our studio we find only subtle differences from DXD down to 192kHz and 96kHz. The obvious degeneration is from 96kHz down to 48kHz. We find DSD, as used in the SACD format, somewhat different in colour from PCM; in some mysterious way DSD is softer and more beautiful but slightly less detailed. In DXD we find the shimmering brilliance from the original analogue source as directly from the microphones. Linear PCM is offered in addition to DTS HD Master Audio on this Blu-ray with the purpose of convincing audiophiles of the true lossless qualities of commercial encoding. The stereo layer of the SACD and the LPCM 2.0-stream on the Blu-ray are both full resolution mix from the original microphones. Mostly we find that the microphone placements used for the surround make a fine stereo. Occasionally we put up extra microphones dedicated for the stereo stream.
I personally prefer extremely high resolution PCM over the DSD and I would claim that DSD is not transparent. But it all comes down to what the sound from your speakers can do to your body and mind.
I find that the placement of microphones has an infinite more important role in the final experience of music, than the difference between HiRes PCM and DSD. Sometimes a lie can be more beautiful than the truth!
2L sampler CD 2007
