Teac dac
  • thomand
    Googling i pausen førte til denne dingsen:
    Teac UD-H01
    Main Features
    USB Audio Class2 High-speed Input from PC/MAC (Tenor 8802)
    32-bit/192kHz Dual D/A Convertors (BurrBrown 1795 x 2)
    Up-conversion to 32bit/192kHz
    Supports Asynchronous Transfer Mode
    Toroidal-core-Power Transformer
    Detachable AC Socket
    Headphone Out with Volume Control
    Aluminium Front Panel
    General Specifications:
    USB Input: x 1 (USB2.0)
    Digital Audio Inputs: x 2 (Coaxial, Optical)
    Balanced Audio Output: x 1 (XLR, 1-GND, 2=Hot, 3=Cold)
    Audio Output: x 1 (RCA)
    Headphone Out: x 1 (6.3mm)
    Input Signal Sampling Rate: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
    Operation:230V AC, 50kHz
    Dimensions (W x H x D): 215mm x 55mm x 215mm
    Ser ut til å havne på ca 3000,-
    Så jo bra ut ihvertfall. Noen som vil kommentere specs?
    Bjørn.H
    Rangeres ikke BurrBrown 1795 som de beste av deres chipper?
    -asynkron USB er jo et pluss.
    thomand
    Jeg Får ringe Maxwell å bestille en. Skader jo ikke å prøve :)
    Bjørn.H
    TEAC PD-H01
    - Slot-loading compact CD player
    - Connect to your PC via USB and use your PDH01 as an external CD-ROM drive
    - Rip CDs to your PC via USB 2.0
    - 24-bit/192kHz Burr Brown 1796 D/A Converter
    - Aluminium front panel
    - Remote control
    TEAC UD-H01
    - Digital to analogue converter with USB, Optical and Coaxial inputs
    - RCA and XLR outputs
    - Tenor 8802 USB high-speed input from PC or Mac
    - 32-bit/192kHz Burr Brown 1795 x 2 D/A converters
    - Supports asynchronous transfer mode
    - Toroidal transformer
    - 192kHz upconversion
    - Dedicated headphone amplifier section with volume control
    TEAC MP-H01
    - Wireless audio streamer
    - Apple Airplay and DLNA certification
    - Airplay allows you to stream from iTunes on your PC, Mac, iPhone, iPad and iPod Touch
    - Streams audio from your PC, Mac, NAS drive or Android device via Wi-Fi or Ethernet
    - Control your MPH01 via your iOS device with a UPnP app
    - Dual digital audio output and analogue audio output
    - Remote control
    TEAC DS-H01
    - Digital iPod dock bypasses the DAC in your iOS device for improved sound quality
    - 24-bit/192kHz Burr Brown 1796 D/A converter
    - Composite and S-video outputs for video playback from your iPod/Pad/Phone
    - Analogue RCA and coax/optical digital outputs
    - Remote control
    TEAC A-H01
    - 50wpc stereo amplifier with USB, RCA and digital audio inputs
    - Integrated 24-bit/192kHz dual Burr Brown 1795 D/A converter
    - Tenor 8802 USB audio input
    - B&O ICEpower amplification
    - Motorised volume control
    - Headphone output
    - Subwoofer preout
    - Remote control
    Bjørn.H
    Ble litt skuffet over at TEAC ikke kostet på den DAC'en en ekstra elektrisk digital inn, eller BNC.
    Graks
    Hvem er forhandler for Teac her til lands?
    rumath
    Si ifra når du har et førsteinntrykk. Sidene til Maxwell fikk jeg lite ut av... Fant ikke produktet, eller pris.
    DSP
    Den nye distinction serien ser jo bra ut også, blant annet effektforsterker i esoteric look på 35 kilo...
    I_L
    I følge produktoversikten til Texas Instruments har 1795 praktisk talt identisk ytelse som 1796, så det er høyst sannsynligvis et redesign hvor det ikke er gjort noen endringer i DAC-kjernen, men hvor interfacet/toppnivået er oppgradert. Så det er samme DACen, med noen endringer i datahåndteringen.
    1795/1796 har forøvrig to DACer i én pakke, dvs det er en stereochip, og det er fortsatt gamle 1792A/1794A (også to varianter av samme kjerne) som har høyest ytelse av de listede TI-chipene. Den er også en god del dyrere, som det står på sidene koster 1792/1794 $10.65 i kvanta på tusen, mens 1795 koster $3.95 og 1796 koster $2.95.
    Torsen
    Powerdacen A-H01 var fristende, helt til jeg så den ikke hadde USB. Men kan jo bruke en sånn usb->spdif sak (som jeg ikke husker hva heter i farten) :)
    Bjørn.H
    Jo, den har USB (USB 2.0) samt digital inn (Coaxial, Optical).
    kjetinho
    For meg var den cd-spelaren veldig interessant. Liten og fin, og eg treng noko til å rippe til serveren min med. Dacen min er ganske lite kresen på drivverkkvalitet og, så kan hende kvaliteten held. Får ta ein prat med Roald på Renaissance Audio.
    Bjørn.H
    CD-spilleren kanskje kan kobles rett på Squeezebox Touch, eller rett på DAC'en ved hjelp av USB??
    Torsen
    Stemmer, jeg så det nå. Si ifra når en av dere finner ut priser denne serien.
    Torsen
    Hmm, det vil si at ampen burde ligge på rundt 4k her til lands. Skal bli spennende å høre om den får gode tilbakemeldinger til den prisen.
    Bjørn.H
    Den spilleren er kanskje et godt drivverk -sikkert mulig å kjøre den inn på en USB-DAC. Blir interessant å finne ut.
    kjetinho
    Nokon som har fått fatt i nokre av desse boksane? Ein forhaldlar i bergen er lova ein cd-spelar inn forlengst, men den har ikkje dukka opp enno.
    thomand
    Venter fortsatt i spenning på min. Håper den kommer før jul ihvertfall :)
    Kjenner jeg gleder meg litt
    SRM
    Oppland
    Prisen på dac'n er 4995,- hos Maxwell.
    kjetinho
    Har det dukka opp nokre slike boksar etterkvart? Eg har ikkje fått fatt i ein enno..
    kjetinho
    Kan virke som om cd-spelaren ikkje kom i produksjon. Nokon som har prøvd dockingen eller andre produkt i serien?
    Aerik
    Våler i Østfold
    Da ingen svarte, så tok jeg sjangsen og klina jeg til. Kjøpt fra Maxwell Import - Hjem
    Så da er denne i hus, Teac Reference Power DAC” A-H01, enkelt å sette opp mot usb,
    bare laste ned siste driver og alt fungerer 100%. Den har selvsagt flere tilkoblingsmuligheter også :cool:
    Har hørt på den i noen timer og er foreløpig kjempefornøyd
    til den bruken jeg skal bruke den, rett fra pc hvor flac, Wimp og Spotify server musikken til hodetelefoner.
    Alle tekniske data finnes ellers her TEAC | A-H01
    En merker at det er ett kvalitetprodukt en har med å gjøre.
    Ett lite utdrag:
    Stereo Amplifier with Integrated DAC (32bit)
    The Heart of the New Reference H-01 Series
    The heart of the Reference H-01 Series is the new “Power DAC” A-H01 – a digital amplifier concept based on ICEpower® technology capable of providing up to 2 x 60 watts of clean power for signals processed through a high resolution, 32 bit, 192 kHz D/A converter chipset (type PCM5102) from the experts at Burr Brown®. A PC or MAC computer can be connected to this component via the Tenor® USB Audio Class 2 input on the rear panel. Processed digital signals are then routed through the amplification stages to attached passive loudspeakers of your choice. A subwoofer pre-out connection is provided for those wishing that extra punch. Four inputs – two analog and two digital (1 x coaxial and 1 x optical) allow the connection of external sources. The system remote control is a standard accessory with the A-H01 and operates the amplifier functions as well as other matching Reference H-01 family components.
    gismo
    Væssia i Grue.
    Ett lite utdrag:
    Vis vedlegget 245803
    Gratulerer Arild:)
    Må si dette var en spennende og meget lekker boks!!
    Skal du dra noen ht på disse 2x60w ICEpower`ne eller blir dette mest som dac og headamp?
    gismo
    Aerik
    Våler i Østfold
    Var tenkt som ren som dac og headamp via pc'en,
    men kona digga både lyden den ga i AKG Q701 og
    "The look", og en cd spiller i samme serie, så kan det hende det kommer en til på kjøkkenet.
    med noen små lekre lydtasser. Vi får se.:cool:
    sorgenfri
    Kan, du ikke gi litt mer "kjøtt på benet" når det kommer til headampen?
    Denne boksen har min største oppmerksomhet!
    Aerik
    Våler i Østfold
    Hei.
    Har bare hørt på den en 3-4timer, men den drar frem toner, godlyd og ting jeg ikke har hørt
    før i dette pris segmentet, eller at den får frem ting i mine AKG Q701 nå som jeg ikke hadde hørt før,
    med den samme musikk jeg har testet mot de med andre dac'ene jeg har prøvd
    (Ikke det at det er så veldig mange, men noen er det jo).
    Det samme inntrykket får jeg frem med B&W P3, bare at B&W virker at de blir mye råere enn jeg har hørt de før.
    Har testet de med 10 referansesanger jeg pleier å bruke, på begge headphonene.
    Skal prøve noen flere modeller headphonene mot Teac Reference Power DAC” A-H01 senere,
    men kort oppsumert så virker dette som ett solid byggverk, som leverer det du håpet at den
    ville levere, og vel så det. Jeg har ikke hørt noen som leverer slik Teac'en gjør, før en i bestefall
    dobler prisen. Så førsteinntrykket er: I'm in love, with a cheap DAC/Amp, denne leverer i mine ører-
    Ps. Jeg har kun brukt den med Usb mot pc, som den skal stå mot.
    Så det blir spennende å se hvordan den åpner seg sånn phø om phø, til og med kona digger hva den leverer?
    Og hun har jeg fått til å høre på mye, men det er første gangen jeg så hun ble virkelig engasjert.
    Så at de hadde 2 stk. på finn.no til en fin pris her om dagen, er jo ikke store summen for å teste.
    Men jeg skulle egentlig ha denne, men hadde ikke tid tilåvente til den kom inn hehe ;)
    TEAC | Products - Mini Audio Systems - 501 Reference Series
    Og 4 dager etter, storfornøyd:cool:
