High res utgaven .
Tracks 1-7 > Remixed & Remastered by Kevin Shirley.
Tracks 7-14 > Original 1972 Mix, Remastered by Martin Pullen.
Analyzed: Deep Purple / Made In Japan (Deluxe Edition)
DR Peak RMS Duration Track
DR8 0.00 dB -8.88 dB 6:41 01-Highway Star (2014 Remaster)
DR8 0.00 dB -10.63 dB 12:33 02-Child In Time (2014 Remaster)
DR8 0.00 dB -10.01 dB 7:19 03-Smoke On The Water (2014 Remaster)
DR8 0.00 dB -10.88 dB 9:28 04-The Mule (2014 Remaster)
DR8 0.00 dB -9.59 dB 9:52 05-Strange Kind Of Woman (2014 Remaster)
DR8 0.00 dB -11.16 dB 10:25 06-Lazy (2014 Remaster)
DR8 0.00 dB -10.84 dB 19:50 07-Space Truckin' (2014 Remaster)
DR9 -0.86 dB -12.20 dB 6:42 08-Highway Star (Original 1972 Mix)
DR9 -0.19 dB -12.61 dB 12:17 09-Child In Time (Original 1972 Mix)
DR8 0.00 dB -9.99 dB 7:36 10-Smoke On The Water (Original 1972 Mix)
DR9 -0.03 dB -12.13 dB 9:27 11-The Mule (Original 1972 Mix)
DR9 0.00 dB -11.71 dB 9:52 12-Strange Kind Of Woman (Original 1972 Mix)
DR10 -0.36 dB -13.99 dB 10:26 13-Lazy (Original 1972 Mix)
DR8 -0.02 dB -11.51 dB 19:55 14-Space Truckin' (Original 1972 Mix)
Number of tracks: 14
Official DR value: DR8
Samplerate: 96000 Hz
Channels: 2
Bits per sample: 24
Bitrate: 3132 kbps
Codec: FLAC
Kan bidrage med en CD version som er mere original
foobar2000 1.3.4 / Dynamic Range Meter 1.1.1
log date: 2015-04-08 08:27:35
Analyzed: Deep Purple / Made In Japan - DCC
DR10 -0.43 dB -12.82 dB 6:55 01-Highway Star
DR10 -0.94 dB -15.32 dB 12:32 02-Child In Time
DR12 -0.05 dB -14.19 dB 7:34 03-Smoke On The Water
DR13 -0.32 dB -16.87 dB 9:57 04-The Mule
DR10 -1.62 dB -14.89 dB 9:55 05-Strange Kind Of Woman
DR11 -0.94 dB -16.98 dB 10:35 06-Lazy
DR11 -0.48 dB -14.69 dB 19:59 07-Space Truckin'
Number of tracks: 7
Official DR value: DR11
Hvis DR værdierne er meget ens og der er kørt helt op til loftet 0 db på alle numre , som man ser i den ene remastrede udgaver så bør klokkerne ringe, det vil sandsynligvis lyde temmelig komprimeret.
Det sjove/pudsige er at musikken delvis kan genskabes på vinyl ud fra en voldskomprimeret remastret CD version.
Når der tilføres RIAA og anti RIAA og pladen skæres og afspilles med en slinger grammofon, så kommer lyddiagrammet igen til at ligne musik i stedet for at det virker som der er kørt en grønthøster/græsslåmaskine på toppen af lyddiagram-kurven.
Det er simpelthen umuligt at få et output fra en vinylplade til at se ud som en CD hvor der påført kraftig komprimering og kørt helt til nul db.
Vinyl er en mere naturlig form for trykning og afspilning af musik som vil "modsætte" sig en del af de mange muligheder i digital teknikens "vidunderlige" verden, DR værdien kan være 3-4 stykker højre på vinyl udfra den samme hårdt komprimerede CD master.
Jeg havde en diskussion i et andet forum om dette , men kan desværre ikke finde dokumentationen i øjeblikket.
