----> A boundled thread with subwoofer builds by me and my friend
  • MattiasBGD
    Hi my name is Mattias Vendel,
    My daytime job is as an electrician and my friend works at the woodshop as an CNC operator. At weekends and evenings we spend time building the speakers and when I´m not there I do the drawings and designs at home.
    Me and my friend have some builds I would like to share.
    Until today it´s only subwoofer builds but soon we will start with a ML-TL speaker from Creative Sound Solutions - CSS Criton.2 but there will be a separate thread with info and pictures of all the build stages.
    Hope you enjoy the builds.
    I understand that you may think that we are a production company but right now it´s just an hobby which have escalated and the last build with four LMS-R 15 and two Ultimax 15" are two friends we helped building new subwoofers at the Swedish forum to learn more about cabinet design.
    My first DIY:
    Dual Sonotube 400mm diameter absolute minimum to fit a 15inch driver
    Amp: Behringer iNuke 6000Dsp
    Drivers: Dayton Audio DVC385-88 15"
    Clothing: White leatherette (found very good quality feels like real leather)
    HTS Forum
    My dual sonosub build Dayton DVC 15" "SWE" - Home Theater Forum and Systems - HomeTheaterShack.com
    Swedish forum picture gallery
    Minhembio.com - Hemma hos MattiasBGD - DIY - 2st cylindersubbar 15tum
    The thread continues when I build new cabinets big ported 190liters instead for the Dayton drivers but my wife started to cry when I brought them home to our apartment so I sold them to a friend and made inserts to fit his TC Sounds LMS 4000 12" instead.
    The sonotubes was sold including the Dayton drivers and with the money I started to plan a new subwoofer build.
    Final result should look like this first picture
    Today 6months later they are back for the paint job.
    Third build
    The subwoofers I use today
    Dual CSS SDX12 Hybrid Ported/Sealed
    HTS Forum
    Dual CSS SDX12 Ported/Sealed - Home Theater Forum and Systems - HomeTheaterShack.com
    Minhembio.com - Hemma hos MattiasBGD - DIY Dual CSS SDX12 Subwoofers!
    Fourth build
    My woodshop friends subwoofers
    Dual Eminence LAB12 Hybrid Ported/Sealed
    HTS Forum
    Dual Eminence LAB12 Ported/Sealed - Home Theater Forum and Systems - HomeTheaterShack.com
    Minhembio.com - Hemma hos MattiasBGD - DIY Dual Eminence Lab 12 Subwoofers!
    Picture taken at my place before he picked them up.
    Fifth and sixth build
    Four LMS-R 15 & Two Ultimax 15 sealed
    One guy will get two LMS-R 15" towers and the other guy two singel Dayton Ultimax 15" same cabinets design but different roundovers on the edges
    HTS Forum
    Four LMS-R 15 & Two Ultimax 15 sealed --Sweden-- - Home Theater Forum and Systems - HomeTheaterShack.com
    Minhembio.com - Hemma hos MattiasBGD - DIY 4st LMS-R 15 och 2st Ultimax 15
    Regards
    Mattias and Albin
    W.Sand
    moelv
    Nice builds ( and wrong wife?)!
    Hos would you describe pros and cons regarding the iNukes?
    MattiasBGD
    Inukes: There has been a lot of discussions on the Swedish forums in the matter of class D vs the heavy toroidal amps. Conclusion - no one has done a A/B test between the two. We did a short testing at a small event but it should have been done more accuralty and when we all were sober :)
    The thing we found out was that his toroidal amp delivered more punch and energy with kickdrums but measurments didn´t show any boost in that region were the subwoofer played.
    Thou people have ideas and critic for new measurment tecniques which have not fully driven the amps hard in the infrasonic region for longer duration or below 30Hz at all. There is a test out on the web but that guy did not go below 30Hz... I don´t want to discuss how tests are done becasue I don´t have the knowledge.
    Inukes seem to be good value for the money I´m happy with mine. The dsp version offers good features but since you can´t target highpass and EQ below 20Hz I felt that a minidsp would have a lot of more benefits and above all good fullrange sound and LT compensation if needed.
    The only thing I use in the inuke now is limiter which is easy to manage to not over power the drivers.
    Inuke above the 3000 modell can´t handle loads below 4ohm not sure if one should load the 3000 with 2ohm either but basically the 6000 modell is two bridged 3000 amps that´s why.
    Inuke will play down to 10hz no problem but sometimes I think about if the capacitor power is enough to handle it with good control and hit hard not sloppy.
    Still I´m curios to test a t.amp 2400MKX which I found to be good value toroidal but I don´t have the money for playing around like that now. Maybe the t.amp proline 3000 if I build other subwoofers in the future.
    MattiasBGD
    Thanks!
    We will try to step up a few notches with the speaker kit from CSS and do something innovative with the design after that we have a speaker we want to be our own design cabinet and floorstand but we will need the experience from the ML-TL build to learn more about speakerbuilding.
