C.E.C. TL 0 3.0 - "Best product 2014 award" High Fidelity Magazine
Dette er blandt det aller beste i verden i dag. Verdens beste ifølge mange!
CEC TL 0 3.0 - review HIGH FIDELITY
"I have mostly concentrated on the tone color that we are able to get with the TL0 3.0. The reason is that it seems to me its most important asset, in which it approaches the
best turntables. With them, the CEC transport could show something even better.
Marveling at the color I have not forgotten about the space (holography) and dynamics. Both are excellent, although one can indicate their certain "tendencies". That includes bringing the image closer to the listener, which favors smaller jazz ensembles and classical music."
Wojciech Pacula
Review High Fidelity | audio magazine 2014
"In a nutshell
We'll make it short. From the mechanics to the smallest detail for the noise immunity of the well-constructed massive TL0 3.0 drive from CEC, all provides for the foundations of an extraordinarily, monumental, natural musical experience - to pack more into these products is currently unimaginable."
Ansgar Hatscher / Alexander Aschenbrunner
Review Hifi Stars | audio magazine 2014
In every respect the new CEC TL 0 3. 0 CD Transport embodies a level of perfectionthat is unprecedented and breathtaking. Handcrafted and assembled in Japan, each TL 0 3.0 is rigorously tested after completion and then "burned in" before being certified.
CEC is legendary for precision. Conventional CD transports tend to amplify even the slightest vibration in the reflective surface of the disc due to the distance the laser beam has to travel. These microvibrations scatter light and reduce the integrity of the digital data stream. The TL 0 3.0's revolutionary three part chassis suppresses micro-vibrations and resonances that cause unwanted jitter in the data stream.
The elimination of jitter greatly reduces the distortion that too often characterizes CDs as digital rather than musical. CEC has achieved superior isolation of the TL 0 3.0 drive mechanism by using three spiked feet and a rubber damped three-point suspension.
CEC has achieved superior isolation of the TL 0 3.0 drive mechanism by using three spikes rubber damped suspension.The drive mechanism is a massive 30 mm sandwich of non magnetic materials with dissimilar resonances: a 20 mm aluminum plate and a 10 mm brass plate. To assure undisturbed operation of the laser pickup, all sources of electro-magnetic interference are physically isolated.The massive regulated power supply is housed in a separate chassis that may be located up to 1.5 meters from the TL0 3.0 drive mechanism chassis.
The drive electronics are enclosed in a 20 mm thick non magnetic anodized aluminum chassis isolated from the main drive mechanism. The drive and laser motors are electronically, magnetically, and mechanically isolated from the laser pickup and turntable, decoupled by two precision drive belts. The disc drive motor is a cog-free low torque design that is inherently free of vibrations.
Much like analogue turntables, inertia is applied to the disc by the use of a 460 g. stabilizer, of 125 mm diameter, supported by an ultra precision spindle/thrust bearing assembly. This avoids the need of permanent electronic servo-corrections required by all other CD transports, and ads vertical stability to the disc
100% made iin japan - handride, craftsmanship, and music reproduction on compact disc have reached a new plateau with the CEC TL 0 3.0.
The result:
music reproduction on its highest level..
CEC's flagship model TL0 X refined 2014 as TL0 3.0.
Major points of improvement are as follows:
1. The servo PCB circuit has been redesigned to shorten
the signal pass and strengthen the grounding. This will
minimize the deterioration and the distortion of the digital
signal recorded on the CD.
2. Word-clock input has been newly installed. Having the
same outer clock as the D/A converter, jitter will be remarkably minimized to improve sound reproduction.
3. The height of CD stabilizer (puck) has been decreased
by 5 mm to stabilize the rotation of the disc.
4. CEC's original Superlink connection has been fitted for
the first time in the TL0 series. When connected to the D/A
converter equipped with Superlink inputs, the shortest and
most direct digital signal transportation is available without
passing through encoding and decoding procedure.The
left/right-clock data, bit-clock data and digital audio music
data are all transmitted from the CD-transport to the DAC
while the master-clock is generated inside the DAC and
sent to the CD-transport.
5. The external appearance has been upgraded for the first
time since it's original release in 1993. The visible fixing
screws and housing have been minimized at each edge of
the housing components.
PRIS:
269.900,-
TEST I HIFI STARS:
http://www.cec-international.com/MEDIA/Hifi Stars TL 0 3.0.pdf
TEST I HIGH FIDELITY MAGAZINE:
http://www.cec-international.com/MEDIA/High Fidelity -Review CEC TL 0 3.0.pdf
Tom Egil
tom@endpointaudio.no
47832922
Bebophifi12
Asker
Bruker selv CEC TL3N drivverk med min Berkeley Dac og kan underskrive på at det gamle CD mediet kan by på svært gode musikkopplevelser! Mildt sagt forbløffende bra. Flotte produkter CEC.
JP
funbunny
Ved Mjøsa
Helt sikkert en gedigen maskin. Men hvorfor legge så mye penger i å kunne avlese CD'er direkte når man kan rippe de med feilkorreksjon og avspille de fra en Mac feilfritt for noen lapper?
Funbunny
yasman
Grenland
det får importør svare for, finnes sikkert gode begrunnelser. men om ikke annet hvilken eierglede!
Bebophifi12
Asker
Jeg kan svare;
Jeg ripper selv og bruker PC med en Berkeley Alpha Dac Series 2 med Berkeley USB Interface/modul. Det fungerer utmerket. Men å spille de samme CD`ene fra CEC drivverket via Berkeley dac`en er faktisk enda bedre. Mer fundament og organisk lyd. For meg er CEC drivverket en nyttig og velfungerende løsning, også fordi jeg har masse CD`er jeg aldri har giddet å rippe.
JP
funbunny
Ved Mjøsa
Jeg kan svare;
JP
Da har du sannsynligvis problemer med klokking/buffring fra PC'n din. Kjør en Firewire med buffer i mellom så er du iallefall kvitt problemet.
Funbunny
lars_erik
Hades
opplever også det samme med et godt drivverk....
Samme her. Lydmessig er det mye bedre enn avspilling fra pc. Mulig det ikke finnes vitenskapelige bevis for det, men det betyr ingen verdens ting når ørene forteller noe helt annet.
E.I.A.
Avspilling "direkte" fra pc har jeg aldri fått noe god lyd utav.
Fra Auralic Aeris eller Bryston Bdp derimot er lyden organisk og nydelig.
Drivverk til flere hundre tusen er bortkastede penger, og kun brukenes som statussymbol imho.
lars_erik
Hades
Nå mente jeg ikke direkte fra pc, men via en dac. Min erfaring er at dess bedre drivverk, dess bedre lyd. Ergo; langt i fra bortkastet.
OlaR
Jeg spiller 90 % fra nas via pc til en dac med god asynkron usb-inngang. Etter å ha satt opp dette etter beskrivelsen til produsenten av dac'en, fungerte dette så bra at jeg la opp til å selge transporten min. Men så gjorde jeg noe "dumt"; jeg kjøpte en Word-clock (transporten min har også mulighet for slik styring), og da rykket cd-riggen fra nas/pc-komboen igjen. Så transporten beholdt plassen sin. :)
Bebophifi12
Asker
Jeg kan svare;
JP
Funbunny
Takk for omtanken, men har ingen problemer med lyden :). Det er bare det at drivverket + Dac er hakket vassere.
JP
Endpoint Audio
Tønsberg
Det er noe eget med et drivverk som er stabilt og solid. Alt oppleves mindre stressende, roligere bakgrunn og en sånn merkelig lettflytende lyd.
Har hørt dette drivverket mot dedikerte streamerløsninger i ultra high end klassen, og dette låter bare bedre.
Det er utvilsomt dyrt, men det henter ting ut av cd mediet jeg ikke trodde var mulig. Jeg bruker selv det rimeligste - TL3N - og syns at dette er et fantastisk drivverk som gir veldig mye av samme opplevelsen, men dette er i en særklasse.
Takk for gode tilbakemeldinger på TL3N :)
Tom E.
E.I.A.
Mente fra PC "direkte" til dac :)
Vet ikke om det er all støyen i pc eller hva, det låter bare mye bedre fra Aeris eller Bdp, disse klarer jeg ikke å høre forskjell på.
Stor forskjell på drivverk digitalt til dac, spesielt hvis det er snakk om aes/ebu, toslink eller Coax, ikke så mye ved asynkron USB, men tror du når "taket" lenge før 250K 8)
KrazyIvan#
porsgrunn
jeg kan også skrive under på at c.e.c. er flotte produkter som jeg gjerne skulle ønske folk her til lands turte å stole mer på :)
for noen musikk formidlere de er, jeg vil også bygge på at cec har noe eget, selv i de mindre klassene skaffet meg for litt siden en cec tl 51 xr, og hadde før den Sony sin xa 7 es og Esoteric dv 50 s ,
og må ærlig si at cec tl 51 xr spiller med mer air, sammenheng og med bedre balanse, og graver egentlig skummelt dypt in i innspillingene til å være i denne prisklassen, så lenge innspillingene tillater det :) men den er også streng på det som er middelmådig, men er innspillingene gode fy søren å den leverer :)
esoteric hadde endel mer autoritet det skal den ha, men den komplette lydsignaturen i cec er bare helt topp, og om jeg kombinerer den med en dac av samme klasse trur jeg det kan bli en ``GIANT`` killer
Gratulerer med års seiern til cec 0 3.0 :) ser virkelig nydelig ut,
har desverre ikke råd til en slik juvel selv :(;) så må nok klare meg med tl 51 xr og en dac etterhvert,
og takk for at dere bringer cec frem :) de fortjener det :)
ivan
Espen R
Tom E.
IQ-mafiaen her på sentralen har jo flere ganger sagt at det holder i massevis med det billigste plastikk driverket produsert i Kina til en 500-lapp, fordi feilkorrigeringskretsene alltid gir 100% korrekte data ut, med mindre Cd'en er oppskrapet og ulesbar. Ja, dem sier endatil at hvis ikke det var sånn at at feilkorrigeringskretsene i CD-system alltid foret DAC'en med 100% korrekte bit data, ja så kunne vi ikke snakket i mobiltelefon i dag. Dette er sagt/skrevet flere ganger.
Så noen må ta litt feil her...;D
funbunny
Ved Mjøsa
Tom E.
Å spille av en CD fra en pc fungerer dårlig. Den må rippes først med feilkorreksjon til disk. Hvis du så har kontroll på klokking og buffring vil du kunne få 100% signal til dac'en din. USB kan være så ymse, jeg har ikke den beste erfaring med det, derfor kjører jeg Firewire ( denne har full kontroll og sync ). Bruk også et avspillingsprogram som kjører i "hog-mode", slik at andre prosesser på pc/mac ikke forstyrrer datastrømmen. En del fallgruber med pc/mac avspilling, men hvis du får kontroll på dette er det uslåelig. Trenger ikke koste så mye heller.
En pc/mac ville ikke fungert hvis den ikke kunne avlese en CD/et program fra disk 100%, så dette er ikke noe problem. Det som er viktig her er å få alle dataene i rett tid til Dac'en.
Funbunny
E.I.A.
Funbunny@ har ikke firewire på dac, så bruker USB fra MacMini.
Har du forslag til noe jeg kunne hatt imellom?
nma
Hvis funbunny refererer til weiss int202/203, så er dette tilsvarende adaptiv usb. Asynkron usb er derfor både et og to steg opp.
E.I.A.
Bra og høre, tanx Man 8)
funbunny
Ved Mjøsa
Sett opp en "TC.Electronics Konnekt 24d" eller lignende i mellom, denne tar firewire inn - buffrer ( kan sette forskellige buffer nivå ), og sender videre eks. som sp/dif. Funker som snus!
USB har jeg bare dårlig erfaring med, men hører at noen får det til.
edit: ser at nyeste modell heter "Impact Twin", dette er bare en oppgradering av Konnekt 24d...
Funbunny
E.I.A.
Funbunny
Takker :)
E.I.A.
For meg er PC bare brukenes til og rippe musikken til NAS. Bruker andre ting for å få filene til DAC, og de fungerer bedre enn feks OPPO 103D.
Andre fordeler er jo avspilling av høyoppløst musikk og DSD .
Eget drivverk til cdplater ser jeg på som bortkastet, da det begrenser seg til 16/44 som jo er mer avlegs en vinyl ;D
Kanutus
Nesodden
Hva er det som "fungerer bedre enn feks OPPO 103D"? Jeg ble nysgjerrig, da det er akkurat den spilleren jeg bruker som 'hub' for å spille av mine musikk-filer fra en NAS. Jeg bruker en NAD-1050 Dac etter OPPO-en, selv om også OPPO-en jo har en Dac selvfølgelig. Jeg hører litt forskjell på om jeg kjører med eller uten ekstern DAC, men må innrømme at det ikke er så mye. Jeg er interessert i å løfte lydkvaliteten opp, og lurer på hvor det "lønner" seg best akkurat nå. Alternativene er mange: DAC (mange prisklasser), forsterker (rør?), streamer (Auralic f.eks?), høytalere (hva får jeg igjen av bedre lyd i 20k høytalere kontra de jeg har nå til 5k?). Så mulighetene er mange, og spørsmålene minst like mange ... :)
Hæææ
Når musikken skal nytes er det KUN vinyl som gjelder.Uansett hva målinger og diverse sier.Det er ørene som bestemmer.Cd spilleren lever godt,men da må den få de gamle ikkeremastrede cdene til kvelds.Pc neitakk.
E.I.A.
Bruker Auralic Aeris, opplever lydbildet fra den som roligere og mere stabilt( mer analogt??????), beste kjøpet mitt i år.
TT.
The smooth jazz guy! 😉🇳🇴
Nedre Tonsåsen
Spiller sikker bra, men styggere enn styggen på ryggen! ;D
Kanutus
Nesodden
Takker for den E.I.A., jeg har 'tellet på knappene' lenge i forhold til Aerisen. Jeg er ikke helt overbevist om utseendet jeg heller, og det har vært en del smårusk i produksjonsprosessen etter hva jeg har lest meg til. Lydkvaliteten høres det ut som de fleste er fornøyd med dog ... :)
Endpoint Audio
Endpoint Audio sine annonser
Nyhet fra Degritter - Fonoteek - leveringsklar Januar 25. forhåndsbestillinger fra 1.September
  • 5
Fonoteek Fonoteek is the ultimate vinyl record cleaning station. The device uses brushes and ultrasonic cleaning together with cleaning fluid to remove even the most stubborn dirt from your disc...
Canor Audio hos Endpoint Audio
  • 1
Jeg er veldig fornøyd med å kunne re-introdusere Canor for det norske markedet, og gir i den forbindelse 15% avslag på alle produktene en kort periode nå i begynnelsen av april. Canor Audio har...
Lockwood Loudspeakers hos Endpoint Audio
  • 3
Jeg er meget fornøyd med å introdusere Lockwood for det norske markedet. Etablert i 1930, Lockwood har vært en av de mest foretrukne monitorer med over 1200 plateinnspillinger på ryggen. Så...
Innbyttekampanje! Oppgrader til Lumin U2 - Eller få 15%
Ønsker du å oppgradere til en av markedets beste streamere? Lumin U2 har oppgradert prosessor, dedikert Low Noise USB til DAC utgang, all-in-one chassis, fiber nettverk, OG lineær...
God Jul til alle!
God Jul til alle!
  • 9
Jeg ønsker alle en riktig God Jul, hvor kanskje både harde og myke pakker er det minst viktige. Det skjer såpass mye galskap i verden i dag, at den beste gaven vi kan gi er medmennesklighet...
EMT 912HI - Test.
EMT 912HI - Test.
EMT lanserte i 2022 nye utgaver av de legendariske tonearmene EMT 929 & 997. Disse er vesentlig oppgradert i forhold til forgjengerene og det legger man merke til med en gang man tar de ut av...
