Diverse Dilldalltråden 1.5
  • Dr Dong
    landskapet uten motstand
    Satans likhet!
    Da vet vi at reinkarnasjonen ikke bryr seg om landegrenser, og at vi ikke trenger å bedrive det samme neste gang. Variasjon er bra når vi nå stadig skal resirkuleres! (For min egen del kunne jeg tenkt meg et litt mer flatterende ytre neste gang, men det er altså ikke en option, som det heter.)
    Er du sikker på at ikke Enzo var på en liten støver all over the map?
    G
    Gjestemedlem
    Du er kanskje en Cis Male uten å vite om det!
    (det finnes sikkert en svensk kreisetelefon for slikt)
    Woman: A person born as a female, and who identifies as female.
    Man: A person born as a male, and who identifies as a male.
    Transgender Man: A person who was assigned female at birth, but now identifies as a man. Some trans people choose to undergo gender reassignment surgery. Others prefer not to, but still identify as a different gender.
    Transgender Woman: A person who was assigned male at birth, but who identifies as a woman. As above, some trans people choose to undergo gender reassignment surgery. Others prefer not to, but still identify as a different gender.
    Trans person: This can mean transsexual or transgender. A transsexual is a person who emotionally and psychologically feels that they belong to the opposite sex.
    Trans Man: A trans man is someone who was assigned female at birth, but now identifies as a man.
    Trans Woman: A person who was assigned male at birth, but who identifies as a woman
    Female to Male: This term is often abbreviated to ‘FTM’ and refers to a transsexual or a transgender man.
    Male to Female: This term is often abbreviated to ‘FTM’ and refers to a transsexual or a transgender female.
    Transsexual: A person who emotionally and psychologically feels that they belong to the opposite sex. Transsexuals are people who transition from one sex to another, usually through dress, hormone therapy, etc.
    Cisgender: A person who identifies with the gender of which they were born. For example, if someone is born as a female and identifies as a woman.
    Cis Female: Cis is short for cisgender. So a cisgender female is a female who identifies as a woman.
    Cis Male: Cis is short for cisgender. A cisgender male is a male who identifies as a man.
    Gender Non-Conforming: A person who does not identify with either the male of female genders.
    None Gender: A person who does not identify with any gender in particular.
    Non-Binary: A person who does not identify entirely with either the female or male genders. They may identify somewhere on a spectrum.
    Neutrois: Neutrois is a non-binary gender identity which is considered to be a neutral or null gender.
    Genderfluid: A person who does not identify entirely with either the female or male genders.
    Genderqueer: An overarching term used to describe people who do not identify exclusively as either male or female.
    Demigender: This term, (demi means half) is an umbrella term for nonbinary gender identities that have a partial connection to a certain gender.
    Demigirl: A person (can also be called a demiwoman or a demifemale) who identifies partially with being a woman or has feminine characteristics. They may have been assigned female as birth, but they could also have been born as a male.
    Demiboy: A person (can also be called a demiman or demimale) who identifies partially with being a man or masculine characteristics. They may have been assigned male at birth, but they could also have been born as a female.
    Agender: This literally means ‘without gender’, so a person who doesn’t identify with any gender.
    Intergender: Intergender people have a gender identity that is in the middle between the binary genders of female and male, and may be a mix of both.
    Intersex: A person who is born with the reproductive anatomy of both a man and a woman. For example, they might appear to be female on the outside, but have mostly male-typical anatomy on the inside. These people were previously referred to as hermaphrodites, but that term is considered rude and outdated.
    Pangender: A person who identifies as more than one gender.
    Poligender: Translates to ‘many genders’. A person who identifies as more than one gender.
    Omnigender: Translates to ‘all genders’. A person who identifies as more than one gender.
    Bigender: Translates to ‘two genders’. A person who identifies as both male and female genders. Some bigender people have two distinct male and female personas.
    Androgyne: A person who doesn’t identify with either gender. They are both feminine and masculine.
    Androgyny: The combination of masculine and feminine characteristics. Androgyny can apply to many things - someone’s gender identity, sexual identity, and even fashion.
    Third Gender: People who identify as neither a man nor a woman. Some cultures refer to some of their people by a third gender.
    For example, in Samoafa’afafines are male at birth, but if a family had more boys than girls and needed more women to help with housework, they male children would be raised as a fa’afafine.
    Trigender: Translates to three genders. A person who shifts between the male, female and third genders.
    totte
    Her tror man kanskje man har klart å finne identiteten sin i havet av muligheter og så må man velge om man er "best described by" androgyne eller androgyny. Vet man forskjellen om man er en av delene?
    G
    Gjestemedlem
    Puberteten blir mer komplisert når den kommer i 50års-alderen..
    weld77
    Ikke bare i USA det er Social Justice Warriors:
    Trondheim skal boikotte israelske bosetterprodukter - Aftenposten
    Skal de starte med egen utenrikspolitikk etter hvert? Etablere ambassader? Ansette undercover agenter som kan reise verden rundt for å finne andre land, områder eller produsenter som slal boikottes?
    Og sist men ikke minst: Hva kjøper Trondheim kommune som er produsert i okkupert palestinsk område i utgangspunktet? Vet i det hele tatt det selv?
    Tankene går i slike tilfeller til raddiser som i fullt alvor tror de tildeler Israel et realt ballespark ved ikke å kjøpe Jaffa-appelsiner.
    H
    Hardingfele
    Den følelsen du sitter med når du har lånt bilen til junior rett etter at han fikk lappen, og det er en masse hestekrefter under panseret.
    I natt var det klart for Trumps møte med Japans statsminister, Shinzo Abe, i New York. Men japanske myndigheter sa at det, dagen før møtet, ikke var sikkert hvor og når de skulle møtes, hvem som var invitert, eller hvem i Trump-leiren de skulle ringe for å få svar. Noe som er veldig uvanlig for et slikt toppmøte i USA, ifølge nyhetsbyrået Reuters.
    Steinar_Lund
    Hvalstad, Asker
    Denne norske blåmuggosten vant verdsmeisterskapen i ost!
    Kraftkar heter den, og ser sånn ut:
    Den danket ut hele osteeliten, Roquefort, Stilton osv. Så det må være faen til ost.
    Den kan visst være litt vanskelig å få tak i, men i verdens navle, Asker, er den tilgjengelig.
    Må prøves! J
    otare
    De har den mange steder her i Trondheim. Og det er litt av en ost - når vi setter fram osteanretning er det alltid Kraftkar som forsvinner først. Vi hadde med et stykke til Praha i fjor og satte den fra til noen tsjekkiske venner, og den var borte før vi fikk snudd oss. rett og slett en fantastisk ost. Akkurat passe salt og passe fet. Nydelig.
    Dr Dong
    Om jeg ikke huser helt feil, så var det Deph eller Fela som introduserte den her i OT for noen måner siden. Elsker den osten.
    Tillegg: #57
    Muligens nevnt før av andre gulltunger.
    OT is good for you!
    H
    Hardingfele
    Tror faktisk det var Roberten som tipset meg, her inne, noen år tilbake.
    Video for tilhengere av Festool.
