Martin Speakers
  • defacto
    Liten by
    Har noen sett og hørt om denne?
    Sent from my iPhone using Tapatalk
    el_mariachi
    Ikke annet enn at USA Martin ble produsert i Norge en perioden, samme fabrikk som produserte Wellex. Kanskje Møre høyttalerfabrikk.
    Hvordan låter de?
    EDIT: Haram industrier tenker jeg det var.
    defacto
    Liten by
    De låter overaskende bra. Skikkelig dypbass og forførende. Men de har til nå bare vært koblet opp mot en NAD3020, så jeg har ikke testet de skikkelig. Men litt hakeslepp bra faktisk...
    De er forøvrig laget i Danmark, om det sier noen noe?
    Noen som vet noe om dette Transflex prinsippet?
    defacto
    Liten by
    Da har jeg prøvd å undersøke litt rundt dette og her var det ikke lett å finne opplysninger.
    Dette er historikken:
    In 1964 Frederick I. Martin founded Martin Speakers U.S.A., a division of Eastman Sound Manufacturing Corporation. A company dedicated to the design and manufacture of one kind of product and only one kind of product, the worlds finest loudspeakers. Using only components of the highest caliber and the most stringent quality controls imaginable Fredrick Martin manufactured the most exceptional loudspeaker systems available at any price. Each pair was meticulously handcrafted one by one for a discerning audience that demanded the Sound of Perfection.
    Martin Speakers were the number one selling loudspeaker in Europe year after year. Their popularity was so overwhelming that the demand in Europe actually prevented saturation in the American market. Martin Speakers have been praised by Paru dans Harmonie and La Nouvelle Revue Du Son, two of Europe's most popular audio publications. Martin gained worldwide recognition after being rigorously tested by The National Testing Laboratories of France where the Martin ranked superior to many Speaker Systems costing far more than the Martin Gamma ® and Transflex ® series.
    Det var en gang en WEB-side som het: martinspeakersusa.com
    Den eksisterer ikke lenger.
    EDIT: Såvidt jeg klarer å finne ut, så fant Jensen opp dette i 1952! Og JBL har brukt dette prinsippet? Men om dette er det samme systemet som Martin bruker er jeg veldig usikker på. Systemet til jensen baserer seg på en innvendig høyttaler, mens Martin bruker en utvendig.
    Det kan også se ut som Wisdom Audio subbene er bygget opp rundt et tilsvarende prinsipp.
    Jeg fant noe om Transflex:
    "The' Transflex x (see figure) is described as a bass-reflex transmission-line system. Essentially, it is a modified Labyrinth 2,a enclosure. It differs from the latter in that the absorbent lining has been omitted "to prevent loss of effciency" and the front of the loudspeaker diaphragm has been brought within the tube mouth to achieve tight cou-
    pling between the two. This tighter coupling augments the output in the vicinity of frequencies where the frontal and tube-mouth radiation are in phase (tube length is an odd number of half wavelengths), at the expense of that at frequencies where they are nearly opposite in phase (tube length is an even number of half wavelengths)."
    Noen som har lyst til å oversette dette til noe jeg kan forstå? :)
    Disse låter så bra at jeg virkelig har lyst til å vite mere om de.
    baluba
    Kopervik og Bergen
    Husker de norskproduserte Martin-høyttalerne fra åttitallet. Såvidt jeg kommer på så var de ikke dyre. Det virker som om de har satt sammen høyttalere nærmest mulig markedene, en hifi-ens John Deere.
    el_mariachi
    USA Martin har visst vært på Danske hender også.
    Har de noen port bak?
    Kan du ta noen flere bilder kanskje?
    baluba
    Kopervik og Bergen
    Det er jo fullt mulig at f.eks. Jamo har eid Martin, men det virker uansett som om forretningsideen etterhvert ble å lisensiere ut både merkevare og konstruksjon til lokale fabrikker som den i Møre-traktene. Noe som i og for seg er svært fornuftig med høyttalerproduksjon hvis kvalitetskontrollen er make i alle fabrikker som produserer dem.
    el_mariachi
    Ja det har nok vært en del av det, så forresten bilder av en Teac høyttaler i en annen tråd her og det så ut som en Seaskonstruksjon ala Kit-303. Til og med filtrene så ut som hyllevare fra Seas.
    baluba
    Kopervik og Bergen
    Da kan det meget gjerne være en rebrandet OEM-modell. Skulle ikke forundre meg. Jeg har oppfordret Jeppe, som eieren heter, å lage en egen tråd om Teac-høyttalerne. Kanskje vi får kastet litt lys over dem da?
    defacto
    Liten by
    Det står at de er laget i Danmark, for og under overvåking av Eastman Sound.
    Om det hjelper noe?
    baluba
    Kopervik og Bergen
    Martin var en merkevare utviklet av Eastman Sound, som lisensierte produksjonen til lokale høyttalerfabrikker der de skulle selges, slik jeg har oppfattet det. Eastman opprettet varemerket på femtitallet, så det har lang tradisjon.
    GeirH
    Singsås, Sør-Trøndelag
    Hei,
    Litt sent å slenge seg på, men skitt au!
    Transflex'ene på bildet har elementer fra danske Vifa (tidl. Videbæk Fabrikker AS), som løsrev seg fra norske Seas høsten 1981. Til å begynne med produserte Vifa helt identiske elementer (attpåtil med Seas sine verktøy), og overtok nok dessverre en del av Seas sine kunder også. De utviklet imidlertid egne elementer etter hvert, slik som disse, og jeg vil derfor tippe høyttalerne er fra omkring midten av åttitallet.
    Jeg har lenge trodd at Martin Speakers var "døde", men fant denne hjemmesida nylig: Martin Speakers.
    Merkenavnet er tydeligvis eid av samme familie ennå, skjønt det er lite som tyder på at de fortsatt produserer høyttalere. Martin Speakers hadde en viss suksess i Europa, og etter sigende særlig i Frankrike. Etter utbredelsen her til lands å dømme, må nok det meste av produksjonen i Norge og Danmark ha gått med til å fylle etterspørsel sørover på kontinentet. Modellene som vises på hjemmesida er eldre "amerikanske" typer, som ble produsert i New Jersey, i stor grad for hånd. Det er ingen spor på nettsida av modellene som ble masseprodusert i Skandinavia. Noen av de norske, selvsagt med Seas-elementer, finnes imidlertid i denne katalogen fra ca. 1981:
    - G -
    GeirH
    Apropos Transflex:
    Martin sine Transflex høyttalere har en del til felles med Jensen-patentet nevnt tidligere, da de begge tilhører det vi kaller kvartbølgehøyttalere, skjønt de har et par viktige forskjeller. Jeg er ingen kløpper i fransk, men et gammelt tidsskrift gjengir følgende:
    Skissen over viser et kabinett som ligner mistenkelig på det vi kaller "Mass-Loaded Transmission Line", dvs. en transmisjonslinje som munner ut i en bassrefleksport. Man har dermed to ulike "tuninger" av kabinettet; En systemresonans bestemt av lengden på den innvendige kanalen bak basselementet, og en portresonans bestemt av portens lengde/diameter. I praksis betyr dette friere hender til å forme frekvensgangen i bunnoktavene, men på bekostning av oppførselen i tidsdomenet (forringet puls-/transientgjengivelse).
    Jeg er for øvrig veldig nysgjerrig på hvordan de har løst dette i de bittesmå TL1450. De har nemlig en litt pussig gjengivelse i bassen... Nesten så jeg må åpne opp mine for å sjekke! ;)
    Jensen-patentet er i bunn og grunn også en form for transmisjonslinje, skjønt det minner mer om det vi i dag kaller "Tapped Horn". For å oppnå høyere effektivitet, er nemlig munningen plassert direkte foran basselementet - eller basselementet i munningen, om du vil. Slik økes den akustiske koblingen mellom disse. Ulempen er at dette bare fungerer så lenge direktelyden fra høyttalerelementet og den forsinkede lyden fra linja er noenlunde i fase. På frekvenser hvor lydbølgene er i motfase, får man en tilsvarende kraftig kansellering. Resultatet vil være en frekvensgang med en serie svært tydelige "topper" og "bunner"...
    Tradisjonelle transmisjonslinjer har samme problem, men i mye mindre grad, og som regel bare i bassregisteret. Samme tendens ses også i målekurven til Martin'en over. Dempematerialet innvendig vil nemlig delvis filtrere bort høyere frekvenser, og dermed begrense uheldige virkninger oppover i registeret. Jensen utelater dempematerialet bevisst - igjen for å øke effektiviteten. Derfor vil en høyttaler laget etter Jensen-patentet ha et helt spekter av vekselvise resonanser og kanselleringer, langt opp i mellomtoneområdet, og jeg vil dermed anta at det kun er ment for subwoofer-bruk! :eek:
    - G -
