Finnes det noen "tweaks" som er så "over the top" at ingen går på de?
  • KJ
    Den har selvfølgelig fått «hederlig» omtale, og utmerkelse ...
    Mono & Stereo monoandstereo.com ‘Kemp Elektroniks MAXiiMUS P16,‘ review by Kurt Lassen
    «The sound in my listening room suddenly is more relaxed and more 3 dimensional. Songs are more fluently presented - as though they are floating in the sound space, and not coming from the speakers. When I just let the P16 settle for a week and just let my ears adapt to the new sound, suddenly I was gobsmacked when I removed the MAXiiMUS. The sound stage collapsed, and small fragments in the sound space where not as present anymore.»
    Home & Music Emotion Magazine ‘Most meaningful accessory of the year 2014,’ by Werner Ero
    «Finally, due to the improvements all six musicians simply stand in front of me, nearly tangible, so realistic it becomes frightening. Whow, that’s a difference! I can hear a larger holographic stereo image, a higher amount of fluently presented low level information and a deeper insight in the music. As an added bonus, the point where complex music becomes smeared is clearly extended. Finally, I shouldn’t forget to mention the picture of your television improves noticeably! Colours are more beautiful, a more tranquil picture and better low level details are the fascinating results.»
    Jf. http://www.kempelektroniks.nl/Files...ektroniks_maxiimusp16brochure_eng_copy1. pdf
    Det er også en videosnutt på youtube som bidrar til underholdningen :
    Free energy .... intet mindre, med litt quantum ditt eller datt.
    Kun 1500 euro.
    Drossel
    We are doomed
    Entreq Tellus grounding - Page 248
    3 person that I know start using the Entreq ground box and Nordost as ground cable few years ago. At the beginning start with one Tellus, then Silver Tellus and 2 Silver Tellus. Using a $30US/ft silver wire as ground cable. One person think Entreq Silver grounding cable is expensive. He came up an idea, trying to use 1 strand of the Valhalla power cord as ground cable. He did a comparison with the $30US/ft silver wire, Entreq Copper and Silver, 1 strand of Valhalla. He thinks 1 strand Valhalla is the best. Other people using Tellus, single Silver Tellus and 2 Silver Tellus have do the comparison at home. And everyone prefer 1 strand Valhalla.
    After 1 strand, 2 strands, 3 strands, the whole cable 7 strands, V2. Everytime has a very positive result. No one has tried the higher price Entreq ground cable, so don't know how they compare with Nordost. Someone came up an idea connecting the posts. Begin with 1 jumpers and end up with 4 jumpers on each Silver Tellus. Finally adding 4 more jumpers to connect 2 Silver Tellus together. All equipments are connected to Silver Telllus, interference should exist. But the add benefit with 12 pieces of jumpers made 3 owners very happy. Their friend in USA do the same thing, connecting 2 Silver Tellus posts together with an Atlantis Tellus.
    Someone tried a ground cable from ground box to wall receptacle, the difference is very impressive. Entreq doesn't recommend connect equipments to Silver Tellus and wall receptacle together. Entreq came out the Olympus Tellus which has one post dedicate for ground receptacle. They started to discover Silver Tellus connect to wall receptacle has a negative effect if the receptacle is not a dedicate line. Even it is a dedicate line, other equipment has plugged in and share the same receptacle will have a negative effect.
    At the beginning, we think connecting Silver Tellus to wall receptacle will drain away the "noise" because it works. After we know Entreq recommend plugging a Silver Minimus(nothing connect to it) to wall receptacle to clear the 'noise" in the power line. We start to think connecting to wall receptacle is not draining away the "noise" ,connecting Silver Tellus is actually cleaning the power line. The "noise" from the power line may enter back into Silver Tellus, that's why they found out it must be a dedicated line with nothing connect to the wall receptacle. One person feel that using the jumpers is not a good idea when Silver Tellus connect to equipments and wall receptacle together. He removed all 12 jumpers. Two other person still prefer with 12 jumpers.
    One person try using Odin as ground cable. He was very happy with the result. He lent Odin to other people. A few person start to look for 2nd hand Odin.
    All of them have upgrade to Olympus Tellus now.
    People have use Nordost Valhalla, V2 or Odin power cord probably will think the background noise is very low. Also the speed is fast. This two characteristic made us think Nordost is a very good ground cable.
    Det finnes faktisk ingen grenser for hvor ømfintlig hørselen til enkelte mennesker. Det er totalt grenseløst og imponerende. Oss andre lekfolk har ikke noe å bidra med.
    Hørt fra anden kilde at dette er en teknik man benyttet under krigen hvor der ikke var andre muligheder. Dog ikke til Hifi men det virker eftersigende mod forstyrrelser.
    Du mener et skjærereir av Nordost Valhalla kabling skrudd fast til en kommode med blomsterjord?
    Balle Clorin
    sabla bra effekt av Entreq gitt,
    Håper noen kommer med analyse av Nordost sine duppeditter etterhvert
    Aurora
    Ytterst i havgapet...
    Har fundert noen ganger på hvor all denne regelrette idiotien kommer fra... er det fantasifulle enkeltpersoner fra "Flat Earth" og Tinfoil-Hat-klubben som konsiperer alt dette, eller er det rett og slett bunn sleipe "forretningsgenier" som koker i hop alt dette mølet som blir presentert som manna fra himmelen? :cool:
    Ikke akkurat ukjent for mange at Furutec er et merke man absolutt bør holde seg borte fra dersom man ikke ønsker å øse penger inn til alternativ bransjen.
    Nå kommer NCF Booster
    The NCF Booster is almost here! | FURUTECH
    A new kind of audio accessory will be relased by Furutech at the end of October.
    The NCF Booster is a multifunctional performance-enhancing connector & cable holder. The much antcipated NCF Booster has been receiving rave reviews in Japanese publications and such was demand that initial production runs sold out to industry insiders in Japan before the NCF Booster even reached audio store shelves.
    Furutech has since increased production to allow for international release in late October.
    What is the NCF Booster?
    It is a multi-material, hybrid constructed performance-enhancing connector & cable holder for superior connetcor and cable damping.
    Not only does the Furutech NCF Booster Connector and Cable Holder lift audio cables off the floor minimizing their points of contact with the floor, reducing electromagnetic interference, it also excels at providing NCF damping support for connectors and cables at points of connection. The NCF Booster Connector and Cable Holder allows for the optimum alignment between connectors and sockets and eliminates static – boosting performance by allowing a more pure and clear signal.
    NCF: Nano Crystal² Formula
    Developed by Furutech, NCF features a special crystalline material that has two ‘active’ properties. First, it generates negative ions that eliminate static. Second, it converts thermal energy into far infrared. Furutech combines this remarkable material with nano-sized ceramic particles and carbon powder for their additional piezoelectric damping properties. The resulting Nano Crystal² Formula, exclusive to Furutech, is the ultimate electrical and mechanical damping material.
    QUE?
    Her er det bare å klampe fast strømpluggen din som selvsagt også må være Nano Crystal belagt og helst noe Quantum greier.
    Før dette er gjennomført er følgende egenskaper ikke oppfulgt i stor nok grad.
    Increased sound to noise ratio, strengthened contrast and definition, response speed improved, transparency increased and distortion reduced… improved space, depth and imaging. So surprised by how much of an effect this product brings.
    Jeez.
    Z
    Zomby_Woof
    De begynte med plugger i konkurranse med WBT en gang i tiden, gjorde de ikke?
    Siden har det bare blitt dyrere og dyrere, og mer og mer spesielt.
    E.H.
    Når man bruker kabler og plugger som veier flere kilo så er det kanskje noe å hente med tanke på sikkerhet ved bruk av slike holdere?
    Kanskje det burde påbys?
    L
    larkus!
    Skal disse papphylsene rundt pluggene være noen lydforbedrende greier?
    Line Magnetic - LP33 Rør Riaa.
    Z
    Zomby_Woof
    Greia er at om man drar ut kabelen, og sitter igjen med bare den, så har man tapt. Drar man derimot med seg phonobøssingen ut av kabinettet, så har man vunnet. Et smell på kjøpet får man også, i disse kransekaketider.
    W
    WayAhead
    Man tager hva man haver, mangler bare litt sølvspray og er par ringer med neglelakk så er de vel gode for -nok 690,- eller så....?---:)
    Hven er det som sletter min likes her flere ganger? Det er mye fornuft i det som står her!
    Dette er for drøyt - et helt relevant og reflektert innlegg slettet, minst to ganger også. Ikke bra.
    Valfy
    Hvorfor ble det slettet? Er det vår danske venn?
    Ja han var dansk - men innlegget var helt relevant og reflektert, med mye riktige beskrivelser. Og ingen personangrep av noe slag. regner med at moderator ikke gidder å sile men bare sletter rått og røti.
    Fra kjelleren til Asbjørn dette..:cool:
    En Tesla-coil kunne vært morsomt, men jeg står over de kablene:
    High Fidelity Cables: Professional Series RCA Interconnects
    High Fidelity Cables: Technology
    Å tro på det der forutsetter at man forstår veldig lite av hvordan elektromagnetisme fungerer. Mannen bak prosjektet er forøvrig Rick Schultz, tidligere innehaver av Virtual Dynamics. De som har vært med en stund husker kanskje Patrick82's erfaringer med Virtual Dynamics The Judge strømkabler til en Sony Walkman på head-fi.org:
    Espen R
    Har Bybee's internal Quantum Signal Enhancer (iQSE) blitt diskutert?
    "Bybee Technologies has developed a product that is energized by a surrounding energy field. Once energized, our product resonates at the same frequency as the C13 atom. (Versus the more common carbon 12 atom - emphasis added) Consequently, this creates a magnetic field of force effect. In this magnetic field, the polarity of all electrons and protons are altered, affecting their oscillation by making them more aligned with each other. This reaction creates an affect that makes the transfer or sharing of electrons between atoms more streamline and efficient; and air molecules less resistant."
    Testet i Positive Feedback:
    https://positive-feedback.com/reviews/hardware-reviews/bybeetech-quantum-signal-enhancer/
    Fra testen i PF:
    It is unfair, I think to call the iQSE a tweak because it so profoundly impacts performance to such an exceptional extent.
    Balle Clorin
    uffamei enda en tulling å eliminere fra listen over anmeldere å stole på
    X-Cell
    King of the North!
    Har vel mer med at han er bannet på livstid for sin oppførsel. Da hjelper det lite å ha et glimt av fornuft en gang i skuddåret.
    Seriøst: Den listen begynner å bli veldig kort. Det er så mye wooo og så lite kritisk sans at man blir helt matt.
    Nå har jeg ikke hørt på hele videoklippet med Serinus, men her snakker han også om sånt som effektforsterkere vs høyttalernes impedanskurve, romakustikk og plassering av høyttalere og lytteposisjon. Dette stikker ikke ut som en «foliehattulling» for min del. Mine valg er noe annerledes, men dette er vel omtrent så bra som man kan forvente fra en subjektivistisk hifianmelder uten særlig forståelse av hvordan de enkelte boksene fungerer.
    Espen R
    Nå har jeg ikke hørt på hele videoklippet med Serinus, men her snakker han også om sånt som effektforsterkere vs høyttalernes impedanskurve, romakustikk og plassering av høyttalere og lytteposisjon. Dette stikker ikke ut som en «foliehatttulling» for min del. Mine valg er noe annerledes, men dette er vel omtrent så bra som man kan forvente fra en subjektivistisk hifianmelder uten særlig forståelse av hvordan de enkelte boksene fungerer.
    Det jeg syns er litt trist når jeg ser klippet er at rommet må være fylt opp av så mye stuff bare for å lytte til musikk. Bare for å få en perfekt avspilning av en CD i 2017 trengs det 3-4 digitale boxer av ulike slag + forsterkere og høttalere.
    Det er litt retro-tech over det. De fleste av oss har vel allerede gått over til harddiskbasert avspilling og streaming, så "perfekt avspilling av en CD" begynner å ligne litt på "perfekt fyring under en dampkjel" i mine øyne. Et mekanisk CD-drev som skal spille av musikkfiler i sanntid er en dyr og komplisert måte å gjøre det på når det finnes løsninger som er bedre, enklere og billigere på en gang.
    Olav2
    Det er jo ikke helt riktig, ut fra objektive kriterier for lydkvalitet i hvert fall. Det holder med en god aktiv DSP-styrt høyttaler med digital input (man bør opp i minimum et par titusener for virkelig å få god kvalitet IMO), og en enkel CD- eller DVD-spiller av ok kvalitet med digital utgang. Så kan man ta det videre derfra, og bestemmer selv hvor langt man vil gå i å presse sitronen sånn lydmessig. Men the law of diminishing returns setter inn ganske raskt IMO.
    Distinctive
    Det er mange transportere som buffrer før avspilling (bla. min) så da er ikke forskjellen fra strømming like stor.
    Uten å ha gjort pinlig nøyaktige sammenligninger så holder jeg en knapp på CD avspilling vs. 'harddisk' avspilling (SSD) for kilder med samme oppløsning.
    Har dog ikke forsikret meg om at opprinnelsen er samme Master og volum-matchet med SPL-meter.
    Dette skal jeg dog gjøre, så får vi se om min uformelle sammenligning holder vann.
    Holy mother of god..
    https://positive-feedback.com/audio-discourse/impressions-van-den-hul-the-extender/
    Van den hul der. Jadda er folk her på forumet som lovpriser produkter derfra.
    The creation of The Extender was based on the search to find this "lost" live experience in any sound reproduction.
    However, The Extender produces no sound-field, is therefore literary no super-tweeter. You cannot measure or hear any sound coming from The Extender.
    The Extender emits a signal which communicates direct with the brain. Limited loudspeaker performance, colored acoustics, or even some ear defects are hereby bridged. These acoustical limitations in sound reproduction do therefore play no essential role anymore.
    Pris - tja kanskje rundt 60k?
    Som "noen" skriver
    I've always considered VHD to be operating on the fringes of rationality along with the likes of Audioquest and Nordost. This puts him squarely in Synergistic Research territory.
