Kristian
Mye fjas her som ellers i kabel-tråder, men kan dere ikke vente med å dømme innbrenning nord og ned til dere har testet ut selv? Nordost lager tross alt kabler til F16 og medisinsk utstyr med svært lave toleranser for feil, og har drevet massiv forskning på kabler, så helt borte i natta kan de nok ikke være... Jeg kjøper et sett SPM Reference XLR-kabler denne uka fra OHC og vil gjerne ha dem inn-brente. Her har jeg kopiert litt info fra nett om Nordost Vidar:
The VIDAR combines three different functions in one operation
1) It neutralizes spurious charges that build up around the cables and the insulation.
2) It provides a very wide band and deep conditioning into the conductor core, which produces changes in the way signals pass through the metal.
3) It ultrasonically conditions the surface of the conductors.
This new VIDAR burn-in service will is only available exclusively from authorized Nordost dealers. No matter how long one burns-in cables in a hi-fi system, they will never sound as good as cables burned-in on a VIDAR. This is due to the use of complex signal patterns which stress the cable in a particular way.
During normal use, there is a leakage current from electrical equipment which causes the cable to take on a charge; cable conditioning will neutralize this charge. New cables often have very high levels of electrical charge caused by the production process. In addition, gases are often trapped between the insulation and the conductor during manufacture. This can often result in new cables sounding brittle, bright and lacking in detail. These charges must be neutralized if a cable is to ever achieve its maximum performance.
