Noe rart med overheng data
Turn 3 data
Type of turntable: Belt drive
Motor: DC Motor
Rotation speeds: 33 1/3, 45 & 78
Wow and Flutter: 0.2% WRMS
Analogue Output: Phono / Line switchable
Connections: RCA Audio output (gold-plated), USB type B
Phono Output Level: 4.0 mV (with Ortofon 2M Red)
Line Output Level: 224 mV (with Ortofon 2M Red)
Tone Arm type: Straight
Effective Arm Length: 233 mm
Effective tonearm mass: 24.84 g
Overhang: 233 mm
Tracking force Range: 18 nM
Platter diameter: 300 mm
Anti-Skating adjustment: Yes
USB Audio Output with 48 kHz / 16-Bit: Yes
OS Supported: Windows & Mac
Type of cartridge: MM (Ortofon 2M Red)
Needle pressure range: 1.8 +/- 0.2 g
Headshell weight: 20 g
Power consumption: 6 W
S/N: >60 dB or higher
Dimensions: 450 (W) x 352 (D) x 138.7 (H) mm (incl. Dust cover)
Net weight: 7.02 kg
Cartridge Weight Range: 6g - 8g
Counterweight Weight Range: 2g - 5g
