KINKI STUDIO
  • Zerostat
    Strømmen
    Bruke også et par råbra AQ Fire (25k) ballanserte kabler. Veksler mellom Audience AU24SE og denne. Kan nesten ikke høre forskjell. Det pleier jeg å gjøre.
    EX-M1 er vel ikke ballansert. Dvs at den ikke avnserer på ballanserte kabler.
    Flisespikkeri, men allikevel....: "Jeg ønsker meg en raskere og i tillegg en logaritmisk volumekontroll. Samt å sette displayet i "dim" ved oppstart."
    U
    utgatt27022
    HTR-1 som er hodetelefon/forforsterker har 1 rca og 1 xlr inngang og xlr pre out i tillegg til 4 pins xlr ut til hodetelefoner. Forsterkeren er ikke fullbalansert så jeg synes ikke den er så godt konstruert. Hvorfor xlr er brukt skjønner jeg ikke. Må bruke overganger og det er ikke opptimalt.
    Zerostat
    Strømmen
    Du vil ikke klare å høre en Cardas XLR/RCA overgang. Jeg har 3 RCA og 1 XLR. Dette holder for meg uansett. Beste kjøpet jeg noen gang har gjort ifm audio.
    Exicon (Profusion) Mosfet transistors
    2x 200W/ 8 Ohm
    2x 400W / 4 Ohm
    2x 700W / 2 Ohm
    2000 dampimgfactor
    Distortion 0.0232%; 0.006% (A-Weighted)
    "This is a very fast and articulate amp but there is no hardness or grain and although the amp is incredibly punchy and dynamic, there is never a feeling of being bombarded with a wall of sound. The combination of these factors is not heard very often, certainly not in a relatively affordable price range."
    "The Kinki amp can certainly convey all the warmth, color and richness that is in recordings with big bass and total authority but there is just no added warmth or smoothness, the sound is pure and honest and timbrally incredibly lifelike."
    "There is nothing weak or indistinct about this amp and image focus is another strong asset. Centrally placed sounds such as vocals really sound as if they are hammered into place, never wavering to the sides regardless of volume setting and its dynamics are also astounding. It’s as if there is simply never any rounding or compression, no matter if you play softly or at deafening levels."
    BeetleBug
    Kinki EX-1 er ikke fullbalansert og derfor anbefaler dem å bruke RCA. DAC-1 er fullbalansert.
    -BB-
    U
    utgatt27022
    2x 200W/ 8 Ohm
    2x 400W / 4 Ohm
    2x 700W / 2 Ohm
    2000 dampimgfactor
    Det fungerer, men hvorfor en fabrikant bruker balanserte kontakter når konstruksjon ikke er balansert skjønner jeg ikke. Det blir unødvendig synes jeg, men den låter vanvittig bra da. Kunne tenkt meg den integrerte EX-1 da, men den er litt for dyr for meg.
    Zerostat
    Strømmen
    Har sittet å lyttet musikk i hele dag. Ikke antydning til lyttetretthet. Det pleier jeg å bli. God natt! ;)
    Batmobil
    Gilleleje
    Hejsa ser lige den her tråd med priserne i Danmark. Jeg ved ikke lige hvordan og hvor de nævnte 46 tusen danske kommer fra. En EX-M1 og DAC Vision 1 koster 35 tusen danske inkl moms selvfølgelig..........med hensyn til fragten - well vi har undersøgt både i Danmark og i Singapore om man kan sende vare hvor moms og told er betalt til eksempelvis os som er importør i Danmark direkte fra Kinki til køber. Svaret er nej - men vi undersøger stadig om der er muligheder. For så vil fragten være den samme som tidligere. Men som det er nu koster det ekstra fragt fra importør til slutbruger - jeg ved der i sverige og danmark findes nogle alternative løsninger som eks bus/rutebil fragt til omtrent 100kr - men skal vi sende til Norge indtil der kommer en importør så må vi ligge arm om fragten :) Håber mit svar giver mening.
    Zerostat
    Strømmen
    Blir mer og mer imponert over denne forsterkeren. Den responderer på nettkabler. Hvilken kabel bruker du ifm din M1?
    Ganske gjennomtenkt produkt. Her ser du at det er luftehull i lokket som fortsetter igjennom kjøleblokken og ut av bunnplaten. Racket mitt har spalter i hyllene, så luften fortsetter tvers igjennom. Bra! Ikke at den blir spesielt varm, men allikevel ... I tillegg gjør dette kjøleprinsippet at forsterkern er totalt lukket og støv kommer ikke inn.
    En kan justere for gain på inngangene. Spesielt bra, siden ampen har høy gain.
    Valfy
    Så kjekt at du liker den så godt :)
    Jeg bruker Supra strømkabler, men jeg hører ikke forskjell her :)
    Valfy
    Jeg er så forferdelig glad for at jeg trakk annonsene mine, og lot både kropp og elektronikk gå seg til før slike avgjørelser tas. :p
    EX-M1 er et lite vidunder av en formidler av musikk, sjel og følelser. Absolutt null antydning til lyttetretthet, kun ren nytelse.
    T-1 skal vi ikke ta å prøve den på Øene dine en passende dag, og sammenligne litt mot Blak? ;D
    T-1
    Klart vi kan. Skal ordne god pris på Black til deg etterpå ;)
    Valfy
    Haha. Forstår det jo sånn at Blak er meget kapabel, så ingenting er avgjort. Ekstra morro at de er i samme prisklasse. :)
    Jeg kan kanskje finne ledig tid i helgen, men det er kanskje litt kort varsel?
    Edit: Jeg kan ta med AMR og Kinki dac også. :p
    T-1
    Det hadde vært gøy ja. Søndag passer greit, resten av helgen er låst til oppussing :mad:
    X-Cell
    Lorden av Nord!
    Ikke ta med for mye... Det blir dyrt for T-1 ;)
    Zerostat
    Strømmen
    Den DAC'en dere burde teste mot er Benchmark DAC3.
    Husk å ikke test med kalde DAC'er.
    Valfy
    Det er jo ikke alltid supernøytrale komponenter passer resten av anlegg og ører best.
    Dharmabum
    Du må teste dac - 1 zero, det er synergi made in heaven, og for å siterte Valfy, "what the actual fuck is this magic" .
    Valfy
    Tøft oppsett!
    Vurderer å prøve Emerald 25.
    Zerostat
    Strømmen
    Det er jeg faktisk ening i, men Benchmark’s DAC er så til de grader riktig-nøytral og oppløst. For beskrive dette litt, så henger hele lydbildet sammen slik at du ikke fokuserer på ballansen, men alt det det handler om i selve musikken. Unoter er stort sett fraværende. Stemmer får sjelden naturlig klang og kant som jeg faktisk også har tilgode å høre på analoge kilder. Spesielt DAC3, med sin 9028PRO DA, er helt dratt ut i denne retningen. Alle DAC’er jeg har sammenlignet denne med, har hatt en eller annet samling med seg av unoter. Jeg er veldig opptatt av en «våt» presentasjon. Ikke nødvendigvis fra rør. DAC3's DNA er uovertruffen imo. Faktisk eneste DAC’en jeg til nå har klart å sidestille med den sorte analoge vinylen. Til 24k er dette tidenes lydkjøp i DAC-sammenheng. ...så Kinki DAC1 skal bli spendende og sammenligne med.
    Dharmabum
    En trist dag for en kinki venn da jeg må la ex-m1 gå av økonomiske hensyn. Har prøvd å selge min fantastiske octave v70 men av en eller annen uforståelig grunn går den ikke selv for gi bort pris. Folk skjønner ikke hva det er for noe. Kinki derimot har vel folk fått med seg er god som gull. Skal ha den igjen senere, vær sikker, og dac - 1 blir stående for den matcher også glimrende med octave ampen.
    Zerostat
    Strømmen
    Har en utrolig god match mellom M1 og Dynaudio. Bruker Audience AU24SE kabler. Hva gode kabler gjør, er nesten magisk. Underlaget påvirker også. Bruker rack laget med perforerte hyller i bambus. Kan "dreie" lyden ganske mye med 8 DAAD'er. Dette er gøy!
    BeetleBug
    Kinki står for stemningen og går perfekt sammen med en god kopp kaffe og sløy, deilig trip hop fra Moderator. En god start på dagen.
    -BB-
    BeetleBug
    Miles ahead
    I have owned many integrated amplifiers (Octave v70se, Gold Note Demidoff Signature Anniversary, Manley Stingray II ...) with different sonic signatures but not of them equal the Kinki Studio EX-M1, it also surpasses my last separated Pass Labs set-up Preamp XP-10 and power amp XA 30.8 which is not an easy task. I am totally impressed by the smoothness and fluidity of the sound, there is sweetness but also heavy notes which gives a real weight to the music, the high frequencies are never aggressive, the low medium is really present and gives superb body to the music while the bass is incredibly deep.
    Laurent Le Fers @ France
    -BB-
    BeetleBug
    Kinki Studio har tatt beskyldningene i Kina tråden på dette forumet på alvor har nettopp postet følgende på deres hjemmeside:
    https://www.kinki-studio.com/news/electronics-geek
    Edit:
    Bildene jeg la ut forsvant. Følg linken over for mer informasjon om hvilke produkter som benyttes i Kinki Studio og hvor dem kommer fra.
    -BB-
    Valfy
    Har hørt noen låter på Ø med kraftverket Teac AI-3000 nå, og jeg kan like godt bare fjerne annonsen min på Kinki.
    Dette er en forsterker jeg eide i noen år, og jeg husker den som meget god og med fin klang, men i forhold til Kinki spiller det innelukka og med lite liv og engasjement.
    Stemmer er lengre bak i lydbildet, og har nesten ingen trykk. Akustiske gitarer er blottet for liv og klang. Bassen er nok like dyp, men også langt mer sirumpa. Jeg kjenner konstant lysten på å skru opp volumet for å få det til å spille engasjerende. Dette er ikke tilfelle med Kinki.
    Enten er Kinki en jævla god match med Ø, eller så er Teac en jækla dårlig match med Ø. Sannheten ligger nok en plass mellom der. Konklusjonen er uansett at jeg fjerner annonsen min, og lever lykkelig med Kinki en god stund fremover. :)
    (Jepp, jeg er til tider et vinglete rotehue) 8)
    Kjendis
    Norway
    Fristende greier. Bare må prøve! Har de Kinki på Norsk Audioteknikk?
