Distinctive
Liten grunn til å vente på andres erfaringer!Lurer på hvordan det funker på skalpen? Bedre hårvekst og raskere tanker?
Du kan få kjøpt den med kobber eller aluminium også, uten å bruke hverken ordet "quantum" eller "nano". Koster kr 94,90 for en halvkilo.For noen latterlig små tusenlapper får du en krem du kan smøre på hva du vil.
Står i hylla under.Jamen ... med iblandet quantum må det vel være uendelig mye bedre?? Har ikke sett quantum i hyllene hverken på Biltema, Clasern eller Jula.....
Vis vedlegget 552162
https://www.biltema.no/bilpleie/smoremiddel/fett/kobberpasta-2000041407
https://www.biltema.no/bilpleie/smoremiddel/fett/aluminiumspasta-2000017188
Fy RIP HanevoldHan her stiller i samme klasse som en viss Hanvold.....
Det er ikke skiskytteren det er snakk om (Han het Hanevold)...Fy RIP HanevoldHan her stiller i samme klasse som en viss Hanvold.....
Until today, I've only read about Mr. Ted Denney III and the demos at audio shows for Synergistic...
I can say I have witnessed the antics first hand now. There are these tiny HFT things that get taken on and off the poor Magico speakers. The white tower Atmosphere device is turned on and off to listen for differences. Synergistic cable risers are put on and off with the HFT things stuck on. The whole demo is being done with music from the turntable with the tonearm lifted up and down (not even playing the same segment of the music). We have some Diana Krall "Gee Baby, Ain't I Good To You", and Sinatra "Thanks For The Memory".
Seriously, if I were Magico or any of the other reasonable brands, and I cosponsored this room, I'd be embarrassed. At one point, someone asked "what is the basis of this?" and Denney just kept doing his thing and played the music without answering... The fact that magazines like Stereophile and TAS even gives this company any coverage all these years is ludicrous!
I honestly think the Magico M2 sounded great and the rest of the gear is fine. Too bad the reel-to-reel wasn't playing.
for å illustrere hvor lavmål dette produktet er.Tilbake til Denney
Sku' tro det, men siden dette er en tråd om nærmest idiotiske 'oppgraderinger' så kan en jo aldri vite hva enkelte måtte være overbevist om.Om du har sikringssakp i stål, som vel de fleste har, så er vel alu-folien unødvendig?
Personlig har jeg alltid lagt stor vekt på innspilling av gardinene. Etter at fruen vasker gardinene låter det purre i ca 1000 timer før de er innspilt på nytt. Hvis hun bytter dem ut med noen helt andre må man regne med et par års innspilling. Det hjelper litt å sette på dem et klistremerke med ordet «quantum» skrevet med grønn tusj, klistret på baksiden av gardinen helt nederst, men man må likevel regne med 1500 timer, minst.-innspilling av stofftrekket til høyttalerne?
Du har betydelig mer fritid enn jeg først trodde. [emoji3]Personlig har jeg alltid lagt stor vekt på innspilling av gardinene. Etter at fruen vasker gardinene låter det purre i ca 1000 timer før de er innspilt på nytt. Hvis hun bytter dem ut med noen helt andre må man regne med et par års innspilling. Det hjelper litt å sette på dem et klistremerke med ordet «quantum» skrevet med grønn tusj, klistret på baksiden av gardinen helt nederst, men man må likevel regne med 1500 timer, minst.-innspilling av stofftrekket til høyttalerne?
Vel, for meg virker det minst like logisk som ting folk forsøker å selge på orntli’.
http://www.pwbelectronics.co.uk/wp-content/uploads/2015/05/PWB-Morphic-Link-Paper-Clips.pdf
http://www.pwbelectronics.co.uk/wp-content/uploads/2015/05/PWB_Plug_Devices.pdf
Blue Heaven har + og - leder langt fra hverandre. Det er en oppskrift på hvordan man fanger opp magnetfelt fra motorer og strømførende ledninger.Jeg hadde en aha-opplevelse her om dagen, med platespilleren og Nordost Blue Heaven phonokabler. De fungerer regelrett som antenner, og er veldig gode på å plukke opp støy fra motoren i platespiller (gir en kraftig jordfeil-lyd og brumming dersom den flate Nordostkablelen ligger i nærheten av motoren) og er veldig følsom for trafoer og strømkabler. Den er absolutt ikke egnet til å brukes ifm riia-trinn. Med en gammel, billig Monster-kabel forsvant støyen.
Jeg tror ikke nano, Quantuum, Plenitude X-CELL A+ eller gardinvask/gardinoppgradering ville hjulpet her.
Haha - bikkja pissa på inntakskabelen....For å være litt seriøs i denne tråden, - selv om det siter langt inne, så er det akkurat dette som foundrer meg langt inn i evigheten, - at ikke folk skjønner at dersom alle denne svadaen som serveres med sølvledning, allskens isolasjonmaterialer, runde steiner, gongbjeller. quantum-meg-både-her-og-der og allskens fantaniske komponenter med lugubre egenskaper... Hvis dette virkelig var reelt og hadde en mening, så hadde selvsagt industrien og profesjonelle aktører omfavnet det for lenge siden, - men slik er det ikke. Likevel er det en håndfull audiofile, som mener å høre forskjell på alt fra om bikkja har pissa på inntakskabelen på utsida av huset, til magiske demoner i strømmmåleren til huset. Nå finnes det selvsagt bevislige situasjoner som er problematiske, og mange andre situasjoner feks rundt kabler som er både logiske og forklarlige, men det er faktisk ikke rart at HiEnd industrien blir latterliggjort av andre profesjonelle elektronikkmiljøer
Man legger en ringjord med kråkefot, dvs 1 m tamp i hvert hjørne til hvert sitt jordspyd. Det hele dekkes med Bentonitt.....Jeg har akkurat lagt ned ny jording her. Seff mot Nordøst med en sabla dyr kabel ned til jordspydet i sølv. Men hvilken type jord å grave ned kabelen i låter best da mon tro ?
1.1 Utførelse av kråkefotelektrode
Elektroden bygges opp av 3 eller flere kobberwirer forlagt i stråler vinkelrett på hverandre forlagt i frostfri dybde. For å bedre overgangsmotstanden kan strålene kombineres med jordspyd, i ulike varianter avhengig av type jordsmonn. Figur 1 til Figur 5 viser eksempler på jordelektroder for ulike jordsmonn. I de tilfeller der jordsmonnet har dårlig ledningsevne vil tilsettingsstoffer som bentonitt (natriummontmerillonitt), petrolkoks eller gips (kalsiumsulfat) kunne bedre ledningsevnen.
Okse. Helt klart. Ren og ufortynnet BS. Må etterfylles etter 1000 timers lytting, da magien er utbrent og nytt påfyll behøves.Hva med kumøkk ?
Kopi betyr kaffe på indonesisk, og Luwak er en vill asiatisk desmerkatt, en pelskledd skapning som ser ut som en krysning mellom en katt og en ilder, melder CNN.
Luwaken klatrer i kaffetrærne for å finne de beste bærene, spiser dem, fordøyer bærene og skiter kaffebønner.
Bønder plukker siden opp dyrets avføring og tar bønnene med til fabrikken. Noe ved fordøyelsessaftene i desmerkattens mage gir Kopi Luwak en unik smak.
Ifølge CNNs journalist er kaffen rund med hint av sjokolade og karamell.
En kopp koster omkring 48 kroner i Indonesia, men nærmere 300 kroner i andre land.
Nei, det er ren geometri. Som Hedde skriver gjør avstanden mellom signallederne at kabelen fungerer som en antenne for støy. For å være helt presis er det arealet som omsluttes av ledersløyfen som utgjør antennen og genererer en støyspenning ihht Faradays lov fra 1831. https://en.m.wikipedia.org/wiki/Faraday's_law_of_inductionJeg hadde en aha-opplevelse her om dagen, med platespilleren og Nordost Blue Heaven phonokabler. De fungerer regelrett som antenner, og er veldig gode på å plukke opp støy fra motoren i platespiller (gir en kraftig jordfeil-lyd og brumming dersom den flate Nordostkablelen ligger i nærheten av motoren) og er veldig følsom for trafoer og strømkabler. Den er absolutt ikke egnet til å brukes ifm riia-trinn. Med en gammel, billig Monster-kabel forsvant støyen.
http://www.pwbelectronics.co.uk/wp-content/uploads/2017/05/The-PWB-Red-x-Co-ordinate-Pen.pdfLaszlo Darvas, the Editor of the Hungarian Hi Fi Magazine, knowing of Peter’s discoveries that the printing on the label side of CDs affected the sound decided, during the early 1990s, to do some of his own investigations. He commissioned, from a Hungarian manufacturer of Compact Discs, ten identical (music-wise) Compact Discs, but with nine of them each printed in a different colour on the label side. Eight of the colours were Black, White, Red, Green, Blue, Lilac, Yellow and Brown. The ninth disc had the normal production printing on it’s label and the tenth disc was left completely clear (no paint at all).
After listening to all ten discs the Editor’s conclusion were as follows :-
That every colour has it’s own sound.
For example.
The disc printed Yellow was described as ‘hurting the mind’.
The disc printed Brown was described as ‘gritty’, ’empty’, only one degree better than Yellow.
The disc printed Lilac was described as sounding ‘funny’, ‘murky’, ‘gritty’ like the White One.
The Best sounding disc was the clear one, the one with no printing on at all.
Free sound improving techniques | PWB ElectronicsThe PWB Red ‘x’ Co-ordinate Pen has been induced with complex messages and when a human writes a message with the Pen, the conditions on the object change in a similar way to the events in the ‘double slit’ experiment, in which the essential ingredient is the pure energy form of the photons and electrons which readily interact with the human observer. The PWB Red ‘x’ Co-ordinate Pen possesses the special ingredient of manipulating modern material to form the basic pure energy pattern that readily interacts with the human ‘observer’.
The simplest proof of the efficacy of this special pen is to sign your name in the following way on the outside cover of a Compact Disc or vinyl record.
Using your normal signature, you write. e.g.
John Smith > O.K.
The writing of the affirmative,beneficial term >O.K. is part of the transferring of the beneficial thought patterns from the human to the written message. This form of message can be written with advantage directly onto the printed label side of a Compact Disc or vinyl record where the beneficial change to the perceived sound within the listening environment will be readily appreciated. It should be noted that once an object has had the ‘x’ space-time co-ordinate formed on the object using the PWB Red ‘x’ Pen, the ‘x’ co-ordinate remains permanently on the object.
We know that many people are interested in the scientific implications created by a PWB device. We are therefore supplying, for a limited period, a specially treated self adhesive film with each PWB Red ‘x’ Pen. When the Red ‘x’ Pen writes on this material, a subliminal message, readily understood by any human within its vicinity, is formed on the material. If the written message is attached to the outer surface of an object such as a loudspeaker cabinet or the outer case of any electronic or audio equipment, a significant change to the perceived sound within the listening room will occur.
Men han er i det minste ærlig om hva tweakeriene hans gjør:Aligning the slots in screw heads.
Align the slots in all screw heads so that the slots are parallel to the earth’s surface. ALL screws – screws fastening light switches to the wall, screws fastening AC power sockets to the wall, screws fastening shelves to the wall etc. Listen to some music for a short time and then move any of the screw slots away from being parallel to the earth’s surface and see if you can listen to the same music with the same pleasure !!
Blås i pratet om «energy» og kvantemekanikk, tweakeriet påvirker nevroser og obsessive-compulsive personligheter. Det er det hele. Har ingen ting med lyden å gjøre i det hele tatt.Our basic concept is that everything in the modern environment has an energy pattern that we (human beings) are sensing and reacting to – that we are interpreting these energy patterns as ‘danger’., ‘intruders’.,’ predators’., or that we cannot resolve these energy patterns and therefore remain under tension. Peter has developed techniques to change these adverse energy patterns to ones that we recognise as ‘friendly’ and therefore to gradually treat so many things in the modern environment (including the very audio equipment) so that we (human beings) can be under less tension, therefore can perceive more of the information that is actually in the room.
As we began to realise what was happening – that it was us (human beings) who were doing the changing – not the audio signal nor the acoustic air pressure waves, then we began to develop better techniques and to develop various methods of better applying the ‘friendly’ energy pattern to objects.
