Dr_BASS
HahahaHer er det mye artig …
Plain piece of paper under one of four feet.
Place a plain piece of paper under any ONE of the four feet of a piece of equipment. This applies to any piece of equipment, even if it is not an item of audio equipment. Listen to some music for a short time, then remove the piece of paper and see if you can listen to the same music with the same pleasure – without the plain piece of paper in position !!
Pinning back one corner of a curtain.
Pin back ONE of the four corners of all curtains in the listening room with a safety pin.. Listen to some music for a short time, then remove the safety pins and see if you can listen to the same music with the same pleasure – without the corner of the curtain pinned back !!
Plain piece of Blue paper under any vase of flowers or any pot plant in the listening room.
If you have a vase of flowers or a pot in a plant pot in the listening room, stand the vase or the plant pot on a plain piece of BLUE paper. Listen to some music for a short time, then remove the piece of Blue paper and see if you can listen to the same music with the same pleasure – without the piece of Blue paper in position !!
