Finnes det noen "tweaks" som er så "over the top" at ingen går på de?
  • Valentino
    J. Brünnhilde
    Ikke jeg. Men så har jeg heller ikke slike greier på utstilling. Kona synes det er ille nok med den firedoble Elkoen på gulvet bak høyre sub.
    Hva slags nettkabler kommer med Beolab 90? Noen som vet?
    4-string
    Interiore Simplicitate
    Elmer
    Mamma mia, here we go again !
    The iSO-CAT7 is a further improved LAN isolating filter that easily surpasses the performance of the iSO-CAT6 and has been developed after numerous tests to realize the sound performance required for Ultra high-end audio. Through this test process, specially selected parts to shape and refine the audio were chosen and each of the four Ethernet signal lines embedded in the Ethernet cable are separated and shielded to reduce interference between each signal line as much as possible to lead to a definite improvement in sound quality.
    If you listen to music using the iSO-CAT7 in your system, connecting it to the network player which, is the most important part in the network audio system, you will be able to understand what it means to refine digital sound closer to analog sound. This is not just simple improvements in specific parts of the music, but clear changes in sound that causes the illusion of reconstructing sound of the entirety of the music or listening to another recording of the same music.
    The moment you add the iSO-CAT7 to your system and
    feel the higher level of sound, it won’t be easy to stop playing music with its novelty.
    (The iSO-CAT7 Christmas Special Edition is limited to 100pcs. The delivery date is after 15th, December.
    Dr.E
    na_X
    ... realize the sound performance required for Ultra high-end audio.
    Når high-end audio suger..?
    Mangler bare super turbo hyper foran ultra, veldig 80-90 talls markedsføring det er blitt på disse "highend" produsentene. Skal vel kanskje ikke vente noe annet når produktene nesten er fra samme era.
    JMM
    Slava Ukraini!
    Fredrikstad
    En liste over produsentene nevnt i tråden hadde vært kjekt å ha, som en kjapp og hendig referanse for hvilke merker man skal styre langt, langt unna.
    P
    parafinoksen
    Med den avansen mange av disse tweaksene har, og med en naïv, pengesterk og kjøpevillig kundegruppe, er det kanskje ikke så rart at de selger dette. Det er kanskje nødvendig for å overleve?
    AleksanderMR
    HiFi-klubben selger noen overprisede kabler. Men ser ikke ut som de reklamerer noe særlig for de. Det er nok mange kunder som ønsker å kjøpe slikt, og forventer at forhandler kan levere.
    J. Brünnhilde
    There’s a sucker born every minute.
    En til å utnytte fenomenet også, i alle fall hvert tiende minutt om det skal bli inntekter av det.
    Jeg kjøpte forresten en singelpuck hos Hifi-Klubben for 200. Noen ganger driter jeg i det og bare flyter med. Ikke så gøy å drive butikk i kjedefranchise.
    Syncrolux
    Apropos Hifi-klubben. Jeg var innom for å kjøpe en litt aparte USB-kabel. Joa, den hadde de. Men da jeg kom til disken og skulle dra kortet krevde de at jeg måtte registrere meg som kunde for å kjøpe en kabel til 150 kr... "Det er lovpålagt" ble det sagt. Makan til sprøyt! Gikk over gata til Power i stedet....
    Eirik84
    Drammen
    Det er vel bare for å få 6års garanti man må registrere seg. Hvis man bare vil ha ordinær garanti og reklamasjon så er det ikke nødvendig.
    Syncrolux
    Akkurat som "meld deg inn i kundeklubben og motta fantastiske tilbud...". Ikke faen.
    Elkjøp pusher nå i alle fall ikke produkter som ikke virker (stort sett), men faen så irriterende med mas om "forsikring", "kundeklubb"... blærg.
    P
    parafinoksen
    Kjøpte TV til min mor på Elkjøp i vinter. Selgeren forsøkte å prakke på meg forsikringer, hjelp til systemoppdatering, monteringshjelp og frakt (jeg hadde tatt bussen ut til butikken). Er vi kommet dit at butikkene bare antar at alle er klønete, evneveike imbesiler? Og frakten – det kostet 5-600 kroner. Jeg tok taxi hjem for 200. Er så frekt at det går ikke an.
    H.R
    Jessheim | Ullensaker
    Det er oppløftende å se at noen kjeder faktisk ikke reklamerer for ting som knapt har noe å si for lyden.
    Helt fair å ha i sortimentet, samme med alskens annet fjas, men i gamle dager var det under disken produkter og hadde med glede sett at konseptet ble tatt i bruk igjen når det kommer til svadaprodukter innen for reprodusering av lyd.
    Ikke at det kommer til å skje, butikker tjener mer på kunder som kaster penger etter de en bevisste forbrukere som ønsker troverdige forhandlere.
    JMM
    Slava Ukraini!
    Fredrikstad
    Akkurat som pornobladene i bruktbutikkene altså, bare langt mindre nyttig.
    JMM
    Slava Ukraini!
    Fredrikstad
    Finnes de ennå mon tro? Lenge siden jeg har vært innom ei bruktsjappe.
    Er ikke på aktiv leting altså, bare så det er klart. Jeg har da internett. Ingen grunn til å sende meg bunker med gamle blader i posten.
    H.R
    Mindre nyttig for menigmann, men ser på disse produktene som ganske kinky greier i retning epoktofili, klysmafili eller rett og slett kokihami selv om sistnevnte er i retning kabler
    Sober
    ikke tweak, men denne er vel sterkt overpriset?
    JENO
    Saksvik - Trøndelag
    Jeg synes Soundgarden er noenlunde edruelige, selv om de selger dyre kabler de også.
    Da jeg var fersk hi fi-entusiast midt på 90-tallet, hadde jeg fått for meg at det svakeste punktet i anlegget mitt var kabelen i RB300-armen min. Selgeren på Hi Fi Centeret (nå Soundgarden) i Trondheim kunne skaffe meg en egnet sølvkabel, men frarådet meg dette, da arbeidet med å skifte er noe herk og resultatet tvilsomt. Jeg syntes den gang fyren var en gjøk, men senere da jeg hadde innsett kabelbløffen, ble jeg takknemlig for det ærlige rådet.
    Singh
    Ikke direkte ett tweak, men Ansuz Jumperz D-TC til 126 000 er en hårreisende pris for ett par ledningsstumper. Men i kjent Ansuz stil så er pris ingen hindring,
    DagT
    Er ikke det et tweak?
    Uansett minner denne tråden meg om at jeg neppe kommer til å leggemye penger i HiFi de neste årene. Jeg har to OK anlegg og kommer heller til å kjøpe leica (som ikke kommer til å gjøre bildene mine noe bedre) enn tullete HiFi-tweaks i dårlig forpakning. Et digitalt Leicakamera av ypperste klasse koster mindre enn en ledningstubb på noen cm.
    Sigma62
    Ja, magien i lækre komponenter er væk. Tidligere når de store producenter lavede et staement produkt, følte man altid, at det var lidt ud over det sædvanlige. I dag laver de bare et flot kabinet eller en latterlig ledning, og tager en masse penge for det. Det er sørgeligt.
    na_X
    Jeg tenker i samme baner som deg, det finnes så utrolig mye annet som er så mye mer morsomt å legge penger i enn noen teite kabelstusser eller tweaks fra slike latterlige firma som vet å utnytte dumme kunder.
    Fornye bil f.eks. litt oftere, koster ikke mer enn noen ledningstubber og duppedingser man putter i ledige stikkontakter. Ny bil er noe både dama og jeg har glede av og ikke minst så merker vi forskjellen begge to! :ROFLMAO:
    Pug309gti
    Stavanger. Innflytter til Norges svar: Twin Peaks
    Løk subben, var det første som slo meg eller er det bare jeg som er skrudd litt merkelig sammen. 9000 dollar, er nok andre jeg villle ha kjøpt, samtidig er prisen på ikke tiny tot taleren i samme gaten? overpriset pc høytalere...
    Pug309gti
    Dyrere en bmw min... ledningsstump vs bil med all av elektronik m.m. Ansuz har tydelig meget stor tro på produktet gitt. Har trollmannen Merlin vært involvert hehe
    Balle Clorin
    Ser jo ut som en platespiller combo fra Jula til 229kr. Svndel fra ende til annen
    J. Brünnhilde
    Kjekt at tøysedyr hifi ser ut som jallabillig hifi og omvendt. Se bildene, styr unna.
