Det er litt MQA-vibber her i måten den «forbedrer» signalet på:Dette må være noe av det mest perverst groteske.. både som produkt, design og pris!!!!! Fy for helvete.
The Wadax digital components employ our own MusIC Chip 2 technology, a feed-forward error correction system that compensates for time, amplitude and phase errors in the D-to-A conversion path. Using the same technique – adding the inverse of the transfer function error to the signal – we realised that it would be possible to compensate for the bit waveform distortion in the USB interlink. But whereas in our DACs, we are dealing with a closed system of known elements, with a universal USB interface, the corrective applied would have to be user adjustable. Our response to this challenge is the Digital Waveform Control, a set of three rotary knobs that allow users to adjust/compensate for errors in the rise-time and amplitude of the sent signal as well as the spacing on the return channel (counteracting echoes and reflections). Users can establish three, pre-set compensations, to match the replay characteristics of different streaming services or locally stored files.
Ville ikke kjøpt kabler av de engang når man leser det der, de aner ikke hva lag2 er for noe engang. Direkte flaut spør du meg..Introducing the QNET – Network Switch - Nordost Blog
Over the past two decades, the way in which people listen to music has evolved tremendously. Today, even the most discerning of audiophiles have embraced digital sources into their systems. However, in some cases, this adoption has moved faster than … Continue reading →nordost.com
Hadde disse produktene kostet en halv dollar på Ali express så hadde ingen tatt de seriøst (mer en passende pris spør du meg), men ettersom det koster mer enn en brukbar bruksbil så blir de automatisk tatt seriøst?
Er det virkelig så enkelt "high-end" markedet fungerer for tiden?
Du skjønner vel også at 1gbit gir dårligere lyd. Trodde dette var barnelærdom, jo bredere båndbredde, jo trangere lydVille ikke kjøpt kabler av de engang når man leser det der, de aner ikke hva lag2 er for noe engang. Direkte flaut spør du meg..
Audio optimized, layer2? Altså, lag to har noe med MAC adresser å gjøre og that's it. Om det er lyd, bilde eller hva som helst så driter både lag1-3 i det.
Også dedikert NAS port på 100mbit!?? Hahahaha!!!
Hvilken idiot kjører NAS på 100mbit, når man kan kjøpe en 1gbit switch med flere porter enn dette til godt under tusenlappen inkl. Kabler, som er en brøkdel av hva denne dritten koster.. 100mbit til NAS med film holder ikke veldig godt når man skal starte å streame 4K etc. Og kanskje flere brukere på samme NAS, oversubscription er et stikkord.
"Velkommen til dårlig nettverk fra 1995, Nordost®."
Ja, congestion på linja gir en varmere lyd sies det.Du skjønner vel også at 1gbit gir dårligere lyd. Trodde dette var barnelærdom, jo bredere båndbredde, jo trangere lyd
Skummelt å bruke et materiale som beveger seg i noe som krever så mye stabilitet over tid. Kan bli fryktelig mye reklamasjoner.
Den der hører hjemme i "Turn off ord" tråden.Det må da låte langt mer organisk?
Jeg syns den har steinkul design jeg, Nagra på LSD liksom
Litt steam-punk?Jeg syns den har steinkul design jeg
Hmm-
Der finns ja også tonearmer i tre.
Skal ja være kokt og «dødt» men jeg har alltid hatt mine tvil om de ikke påvirkes av temperatur og luftfuktighet.
Masse matte, da må det være braThis latest treated adhesive sticker label from P.W.B. makes use of, for the first time, a fractal image. So… a lot of math behind this!
Er det en puffet ris jeg ser der? Det er i allefall supre absorbenterVis vedlegget 820432
De beste tviksene er alltid de en produserer selv og som er kortreist, ikke de dyre alternativene fra ali baba og de andre røverene.
Mine selvproduserte high end audiofile hybelkaniner har nu medført at jeg med god overbevisning og godt resultat har kunnet erstatte min Luxman 590 osv med en Audiolab 6000A.
Adekvat spørsmål.Er det en puffet ris jeg ser der? Det er i allefall supre absorbenter
Navlelo har allerede blitt brukt, så hvis du prøver kan du bli beskyldt for plagiat.Kunne eventuelt tapetsert stueveggene med hjemmedyrket navlelo. Super absorbering. Og muligens en kandidat til Høstutstillingen.
– Fluxus-kunstnere var opptatt av å bryte med den borgerlige kunsten. Hente det hverdagslige inn i kunsten, sier Ugelstad. Blant annet representert med en av kunstnernes navlelo gjennom 30 år i et monter.
Typisk meg å være for sent ute. Hva blir det neste, at noen maler ei dame vi ikke vet om smiler eller ikke?Navlelo har allerede blitt brukt, så hvis du prøver kan du bli beskyldt for plagiat.
(+) Høvikodden feirer 50 år med ny utstilling inspirert av Alice i eventyrland
Du inviteres inn i en verden inspirert av Alice i eventyrland på Henie Onstads jubileumsutstilling.www.budstikka.no
