Bergmann nyhet. Galder/Odin Signature!
Bergmann har gjort det igjen. Forbedret en analog spiller som har blitt kåret til en av verdens beste analog spiller av mange av verdens ledene analog og HiFi magasiner og til en pris som ligger langt under konkurrentene!
Etter å ha levert etter kundeoppfordringer platetallerken med i div Bronse legeringer mm. Så har det aldri vært en stor nok oppgradering til at ville ble en ny (signatur) modell.
Men etter å ha testet ut div andre metaller og legeringer. Så var det rustfritt stål som utmerket seg som en god oppgradering med tanke på lyd!
Det var nok til å lansere Galder/Odin Signature.
Prisen forventes å havne på NOK. 435.000.- komplett.
Les mer her:
We are very proud to launch the new Galder-Odin Signature.
It is 5 years since we launched the well-known classic Galder & Odin, which, from the beginning, has won great acclaim - for design, technology, craftsmanship, ease of use, and not least the sonic qualities.
The classic Galder and Odin will continue in the Bergmann product line for many years. But we decided to follow up on this success with the new Galder-Odin Signature, to push the performance even further.
With the new Galder-Odin Signature, we have taken this system to a new sonic level.
Vital parts are made of solid stainless steel. Such as the 36kg platter, the clamp, and the unique adjustable Galder feet (further developed).
We have improved the Odin tonearm for additional strength and stiffness, as well as even easier adjustment of the VTA and overhang. We have developed a libelle tool that makes it quit easy to adjust the air pipe levelling.
Galder-Odin Signature comes with a more powerful airsupply, to lift the dramatically heavier platter. And the easy operated vacuum hold down is integrated as usual, on the turntable.
With the new Galder-Odin Signature, we achieve more depth and weight in the low frequencies. The transparency is dramatically improved, and the full sound image has become even more vivid.
To complete the design, we have added additional items in steel, such as push buttons, Bergmann logo plate.
The plinth is painted in Black Velvet finish which matches the semi-shiny honed stainless steel parts perfectly.
Galder-Odin Signature. A performer. Forever.
Danish design - produced in Denmark
I know we will have the question: - can the classic Galder or Odin be “upgraded”? And the answer is that only the classic Odin tonearm can be upgraded with the features from Odin Signature.
Norsk AudioTeknikk AS
Ullevålsveien 13
0165 Oslo
Tlf: 22200095
Mail: morten@norskaudioteknikk.no
Web: www.norskaudioteknikk.no
Facebook: https://www.facebook.com/NorskAudioTeknikk/
Facebook PMC: https://www.facebook.com/groups/384770248991790/
Hønndjevelen
Sier meg enig med motoren, her;). Prisen derimot.......
Som med alt jeg har lyst på: flott villa, rå bil, high-end eller damer med high maintenance...
Må du spørre om prisen, da har du ikke råd!
Reaksjoner: nat
Motorhome
Sunndalsøra
Synes denne er penere enn Magne. Ser ut til at armbase og motor er helt adskillt fra selve basen for å få ennå mindre vibrasjon. Er man seriøs vinyl og musikkelsker, så er man villig til å betale det det koster og samtidig er ungkar. Kjenner til sorten:)
Reaksjoner: nat
nat
Synes denne er penere enn Magne. Ser ut til at armbase og motor er helt adskillt fra selve basen for å få ennå mindre vibrasjon. er man seriøs vinyl og musikkelsker, så er man villig til å betale det det koster og samtidig er ungkar. Kjenner til sorten:)
Det er helt riktig oppservert 👍
nat
nat sine annonser
En stor og tung nyhet ifra broderfolket!!!
  • 41
De første Bladelius Oden II er i ferd med å bli klare til levering. 85Kg med rå kraft og musikalitet. Norsk AudioTeknikk AS Sofiemyrveien 12. Inngang A1. 1412 Sofiemyr Tlf: 22200095 Mail...
Møt sommeren med godlyd på ørene!
  • 1
Vi har fått inn igjen den meget omtalte Cayin RU7 dongle DAC på lager. (Vi har også fått inn igjen Cayin CD-Mini MK-II. Kr 3.590.-) Prisen er Kr 3.590.- da medfølger USB-C kabel og overgang ifra...
Enda en glimrende test av Bladelius Ask integrert med DAC/Streamer. Nå i Norske Stereo+
  • 1
Etter en liten stund på markedet. Så har Bladelius Ask gjort seg sterkt bemerket hvor bra man kan få en alt-i-et forsteker med samme egenskapene som separate løsninger (bokser) Les hele testen på...
Lørdagen 6 april stenger vi kl 13.30 grunnet kundebesøk.
  • 8
Vi må dessverre stenge kl 13.30 i morgen grunnet kundebesøk. Skal kjøre halvveis opp til Trondheim og tilbake igjen i morgen. Er tilgjengelig på telefon. . Norsk AudioTeknikk AS Sofiemyrveien...
Da var det siste farvel til Ullevålsveien i dag.
  • 30
Sofaen er på plass i demorom Nr.1. Fortsatt mye jobb som gjenstår. Men dette blir bra🍾
Norsk Audio Teknikk flytter!
  • 117
Sofiemyr blir Mekka for troende audiofile:cool: Trommevirvel! Etter nesten tre tiår med å utvikle en mild avhengighet til bylufta i Oslo, har vi bestemt oss for å pakke sammen sirkuset og...
