EMT 928 II
Pris for platespiller alene er 104990,-
EMT 909HI 69990,-
Samlet pris for pakken er 160990,- en besparelse på 14000,-
The EMT 928 II is a massive built precision turntable with an overall weight of 23kg. The chassis is machined from aluminium, resting on four decoupled, spherical feet.
The device features an independent battery power source, so any interference from the power grid is excluded. The built-in charger circuit handles the charging cycles automatically and shows the status with a two-colour LED.
A most modern 20 Watts motor speeds up the 5,5kg platter in a short time and keeps the speed constant within a narrow tolerance-field.
Product Flyer
mvh Tom egil
EMT 909HI 69990,-
Product Flyer
Platter speed: | 33⅓ / 45 / 78rpm |
Wow and flutter: | ±0,07% (IEC 386) |
Rumble: | -85dB (IEC 98) |
Speed-up time: | 10 / 12 / 20s |
Battery service life: | 40 / 38 / 30h |
Dimension: | 480x340x100mm |
Weight: | 23kg |
Input voltage: | 100-240VAC, 50-60Hz |
Output terminal: | RCA, with separated tonearm ground |
Mounting distance arm: | 215-245mm, prepared for EMT 9-inch tonearm |
mvh Tom egil
93.1 KB Visninger: 142
124.6 KB Visninger: 124
125.2 KB Visninger: 117
