Eit interessant produkt!Er nå offisiell.
Schiit Audio: Audio Products Made in USA
www.schiit.com
Hadde likt det endå betre, om det kunne LVDS over HDMI…
![Smilende fjes med smilende øyne :blush: 😊](https://cdn.jsdelivr.net/gh/joypixels/emoji-assets@5.0/png/64/1f60a.png)
Mvh Arild
www.schiit.com
o Schiit does a CD player now?
Nope!
Well, this certainly looks like a CD player. What is it, then?
It’s a CD transport and Unison USB Hub. That means, amongst other things, it does play CDs, but it only provides digital output. If you want analog output, you need to add a DAC.
Aha. Ok. Digital out from CDs. Snore.
Well, there is the little tiny fact that Urd is the only CD transport that provides a Unison USB output.
Wait, what? A USB output from a CD? How does that work?
Very well!
Sigh. Okay, why don’t you just tell me all the wonderful things Urd does?
Absolutely, here you go. Urd is a:
Wait a sec! So I can plug in my streamer and switch it in when I don’t want to run CDs?
- CD Transport. As in, put in a CD, get digital out via AES and coax. You know, like most transports. But you can also select the Unison USB output, which means you can play your CD directly to a USB-input DAC.
- Unison USB Hub. Urd also has two USB inputs that you can connect to other USB sources, and switch between them. This allows you to integrate a streamer or computer into the mix without having a ton of USB inputs on your DAC. Since most DACs usually have only single USB input, we figured this would be super helpful.
- USB to SPDIF converter. Urd can also convert those two USB inputs to SPDIF, and output via coax and AES.
Yes.
And I can convert any USB source into SPDIF for my DACs that don’t take USB?
Absolutely.
And I can compare my streaming services to CDs?
You’re getting it!
So what’s the catch? This thing must be using a crappy drive or something?
No. Actually, we’re using a StreamUnlimited real true Redbook CD drive with a metal mechanism—basically the gold standard for drives. You’ll see it in products that cost 10-20x what this one does. No computer drives, no slot loads, just a good old tray-loading drive.
Then it must be crap parts and engineering?
Nope! In fact, Urd has four 32-bit microprocessors inside to manage all the digital switching and format conversions, all run with Schiit’s Unison USB code—the only USB input that was designed specifically for open-standard audio formats, without the distractions of unicorn formats du jour. It also has a 100% linear power supply with two transformers (one for the drive and one for the digital section, as well as a properly-isolated AES digital output and super-high-reliability USB-C connectors. The chassis is made in USA, from heavy aluminum and steel, with machined aluminum buttons and drawer.
There’s gotta be a catch.
Only one: your source and your DAC will need to be UAC2. This is the worldwide standard for USB audio, and most DACs these days are UAC2 compliant. All of our DACs since the $99 Modi 3 from 2017 have been UAC2 compliant, for example. Some dongles aren’t, and some older DACs aren’t. If you’re unsure, ask your DAC manufacturer if they are UAC2 compliant.
So what if I want just a CD transport?
Then use Urd as just a CD transport. There’s no law against that.
Or just a USB switcher?
Weird use, but sure, why not?
How about a DDC?
Again, yes, but why not do CDs?
What if I don’t have CDs?
Then Urd may not be for you. However, if you want to get into CDs, now is a great time. Prices are low, unlike records. You can stock up on plenty of physical media for the time after Skynet takes over and wipes all the streaming files from existence.
You know, there are lots of transports out there that are cheaper than Urd.
Absolutely there are. We bet none of them are using an actual StreamUnlimited CD drive—as in, they might be using some DVD drive for computers, the kind of thing that was closed out at Frys in 2014 at $18.99—and we know that none of them have Unison USB output or USB hub functionality. And that's fine. There are plenty of choices out there, including not having a transport at all and just doing streaming. Your choice!
You know, this is a helluva deal for a transport that uses a real StreamUnlimited CD drive, and has a ton of unique tech, and is small and slim, rather than as big as a 1980's rack-mount product.
Yes, and there's that perspective too. We hope you enjoy Urd!
What is an "Urd?"
In Norse mythology, Urd is a Norn relating to fate in Norse mythology. It’s the one looking to the past. In this case, the dim dark past of 1981, and the introduction of the CD. Enjoy your retro media!
Vet du noe om det er noe stor forskjell imellom dem lydmessigt?Bruker sannsynligvis en JPL-2800 transport. CD Pro-8 vil kreve mye større skuff.
Tray Loaders | SUOS-Hifi
CD Pro 8 skal være et mer presist og mye dyrere drivverk . Hvor mye det slår ut lydmessig vet jeg ikke.Vet du noe om det er noe stor forskjell imellom dem lydmessigt?
Om de ikke ønsker kunder så kan man kjøpe direkte fra Schiit, både EU og US webshop.Sendt E-post til Duet.no om Schiit Urd CDT, da de er importør i Norge.
Ingen planer fra Duet.no å ta inn Schiit Urd….
Kan ikke finne Schiit Urd CDT hos EU importør…Om de ikke ønsker kunder så kan man kjøpe direkte fra Schiit, både EU og US webshop.
Den er jo helt ny, kommer nok etter hvert.Kan ikke finne Schiit Urd CDT hos EU importør…
Da ville jeg tatt kontakt med Schiit, forklart og spurt om alternativt utsalgsted.Sendt E-post til Duet.no om Schiit Urd CDT, da de er importør i Norge.
Men som importør må de jo være forpliktet til å skaffe på forhåndsbestilling skulle man tro?Sendt E-post til Duet.no om Schiit Urd CDT, da de er importør i Norge.
Skulle forvente det ja….Men som importør må de jo være forpliktet til å skaffe på forhåndsbestilling skulle man tro?
Er tilgjengelig på websiden nå, men hadde ikke sett for meg at $1299 skulle bli kr.22 900!Sendt E-post til Duet.no om Schiit Urd CDT, da de er importør i Norge.
$1300 = 13 000 kr uten moms.Er tilgjengelig på websiden nå, men hadde ikke sett for meg at $1299 skulle bli kr.22 900!
Schiit Urd | Duet Audio AS
Schiit Urd CD transporteren lar deg vekke liv i CD-samlingen og kan enkelt integreres med både streamere og datamaskiner.www.duet.no
Mener jeg betalte noen hundrelapper i frakt sist jeg kjøpte fra dem, lagt fra 1000. Får se hva den havner på i EU- shoppen, men tviler på det blir noe kjøp i år.$1300 = 13 000 kr uten moms.
1000 kr transport
600 kr fortollingsavgift
+25 % moms. = rundt 18500 kr. - (hvis bestilles direkte fra USA, men får da ikke 5 års reklamasjons rett som man har i norge..)
Hvis du ser på andre Schiit produkter hos Duet.no, tar de rundt samme avanse.…
Og forstår jeg konklusjonen rett så påvirker dac'en i Cayin spdif signalet og ekstern dac vil evt bli tilført et dårlig signal.Jeg leste denne test/sammenlikningen og synes den er verd å dele i denne tråden, siden det tydelig går an å selge saker som ikke fungerer som de bør til lav pris også:
Artig nok er referansen en tilårskommen Linn Mimik.![]()
Cayin Mini-CD MKII CD Player Review
This is a review and detailed measurements of the Cayin Mini-CD MKII CD transport and stereo player. It is on kind loan from a member and costs US $279. The unit comes with a good looking and feeling metal case. I like the large display but controls didn't seem very responsive. Below it is my...www.audiosciencereview.com
Dette drevet er nok ikke fasit på den problemstillingen slik jeg ser det. Første magerefleks er at dette er et Kinaprodukt hvor jeg ikke er fremmed for å tenke at en smarting kan ha benyttet et billig DVD drivverk med SPDIF utgang som ESS sin ES9018K2M DAC-chip kan nyttegjøre direkte.Greit å vite med tanke på den evinnelige diskusjonen om dedikert drivverk eller ikke. Har begge deler. Esoteric cd spiller og TagMcLaren cddrivverk.
Har virkelig tro på hva hegel holder på med her ,,,Usikker på om de er det ultimate, men passer til trådens tema om ikke annet:
Thanx god ,,, Nei heldigvis er det AKM ,,,resampling/ upsample free" Det er veien å .Mye nye greier etter at AKM ble borte. Ikke bare hos Hegel. Alle som brukte AKM gikk over på siste ESS, ble det bedre? Det ble i hvertfall nye modeller med grunnlag for ny markedsføring. Forrige gang promoterte selvsagt Hegel med Mohican AKM sin fortreffelighet fremfor ESS. Nå promoterer de Viking med ESS selv om de antakelig ikke hadde gjort en dritt om AKM fortsatt eksisterte. Det er vel en del av gamet og bare å leve med.
Takk for rettelsenThanx god ,,, Nei heldigvis er det AKM ,,,resampling/ upsample free" Det er veien å .
Viking loads CDs via a slot (and not the Mohican’s in-out tray) behind which sit a brand new laser-and-CD drive mechanism and a resampling/upsampling-free AKM 4493SEQ-based D/A converter, both of which are directly controlled by a thoroughly revised Master clock system.
Artig å se at Schiit endelig har fått istand et drivverkUsikker på om de er det ultimate, men passer til trådens tema om ikke annet:
Problemet med Mohikaneren var vel at det ble dele-mangel som gjorde at de ikke kunne lage den lenger uten å gjøre store endringer.Artig å se at Schiit endelig har fått istand et drivverkMen hva gjør Hegel? Den siste Mohikaner, liksom.. De burde jo bare holdt seg til skuff, og implementert nye løsninger i Mohikaneren(også pga navnet).
