Dear Customer,
Congratulations on your purchase of the Advanced Installers Package for the Ellipse iDP system.
In this readme you will find the latest information on PC IP for Ellipse iDP Monitors.
Please read this documentation carefully.
This program can control parameters in a Ellipse iDP monitor system.
This document refers to the PC IP - Advanced Installers Software Package.
1. Requirements
- Windows 95,98,2000 or XP
- Pentium 233 Mhz
- Minimum 16 MB of RAM
- 800 x 600 resolution with minimum 24 bit color
- One free Serial port (or USB - requires converter)
2. Limitations
Connect only one PC IP to your Ellipse iDP network at the time.
If several connections are made simultanously (from more PC's or ports) to
your Ellipse iDP network, all functions might not work as intended.
3. Connections
Always connect the Cat-5 plug on the cable enclosed to the TC LINK found on Ellipse iDP speakers.
The serial plug should be connected to your computer - either to the Serial port or
an USB port. Read more below.
3.1. Connection - to Serial Port
The Ellipse iDP network can be connected to a free Serial Port with the cable enclosed.
Connect the CAT 5 plug to a TC Link plug in your Ellipse iDP system, and connect the
Serial connector to a serial port on your PC.
3.2. Connection - to USB port.
Connection to the USB port requires an optional "USB to Serial Port" converter
The "KeySpan USA 19" has been tested by TC Electronic and found appropriate.
For further information please visit
www.keyspan.com or contact TC customer support.
PC IP is written by:
TC Electronic A/S
Sindalsvej 34
DK-8240 Risskov
Denmark
Phone: +45 8742 7000
