Nyhet fra Degritter - Fonoteek - leveringsklar Januar 25. forhåndsbestillinger fra 1.September
Fonoteek
Fonoteek is the ultimate vinyl record cleaning station. The device uses brushes and ultrasonic cleaning together with cleaning fluid to remove even the most stubborn dirt from your disc. Washing cycle is followed up with a rinse from pure distilled water continued by a drying process where water is pushed off the disc with air blades.
The machine is also very versatile as you can set and save your custom programs according to your need. Be it a quick 5 minute brushing run for those 1$ drift finds or a 20 minute ultrasonic cycle plus rinsing for your mint condition Blue Note.
Washing programs
Brush wash
Fonoteek has two microfiber brushes to wash off larger surface dirt from the record surface. The brushes are moved away from the disc when not in use and are easy to clean or replace.
Ultrasonic wash
To bring out the fine details from the bottom of the groove, we have powerful yet delicate ultrasonic cleaning that has proven its worth in Degritter MARK II machines. Fonoteek has been fitted with a large and powerful water cooling system that allows you to run long ultrasonic cleaning cycles while still keeping water temperature cool and safe.
Fonoteek water tank
Rinse
The machine comes with two 3L removable water tanks – one where the cleaning fluid is added, for brushing and ultrasonic washing and one tank for pure distilled water for rinsing.
To keep the rinse water clean, we use three large activated carbon filters. These will prevent soapy and dirty water from ending up in rinse tank.
Fonoteek drying
Dry
Drying process is using two integrated air blades to push off most of the water. Tiny amount that remains will quickly dry in the air flow.
Fonoteek
SOON AVAILABLE FOR
PREORDER
Pris ca.6900 EUR
MVH
Tom Egil
ynot
Alle trenger en slik, men prisen var da noe i overkant.
Ja, jeg har første versjon :D
Prebs
Jeg har også MK1 som funker gull, men dette hadde jo vært spennende:)
Endpoint Audio
Endpoint Audio sine annonser
Black weeks hos Endpoint Audio - 15-20%
Jeg kjører tilbud på en rekke merker ut november. Horns - 20%. EMT og Thales - 15%. Canor 15%. Norma - 20%. Ring eller send mail for tilbud om det er noe du ønsker...
Lagertømming av Lumin. - 40%
Jeg har noen få Lumin U2 mini igjen på lager, og selger ut disse med ca. 40% avslag. Nå 18000,- https://perfect-sense.se/varumarken/lumin
Høstkampanje på Canor Produkter hos Endpoint
  • 2
Jeg kjører igang en høstkampanje på alle Canorprodukter. -20% på alle enhetene. Canor Audio har utviklet og produsert Hi-Fi-elektronikk i over 25 år med spesielt fokus på rørbaserte løsninger. I...
J. Sikora Reference - 1 av 4 A+ rankede i Stereophile
J. Sikoras toppspiller er også den "billigste" A+ spilleren Stereophile har ranket - Prisen er 48.000 USD (389.000,- i norge) + arm. Michael Fremer hos Stereophile har testet J.Sikora Reference...
EMT 928 II - Stereophile Klasse A Platespiller, Høst 2024
Igjen, og fremdeles så får EMT's 928 II en Klasse A ranking i Stereophile. "EMT 928 II: $9995 without tonearm, $14,995 with EMT 909-HI tonearm, $17,995 with tonearm and EMT JSD Pure Black...
Canor Audio hos Endpoint Audio
  • 1
Jeg er veldig fornøyd med å kunne re-introdusere Canor for det norske markedet, og gir i den forbindelse 15% avslag på alle produktene en kort periode nå i begynnelsen av april. Canor Audio har...
