Audia Flight FL Cd Three S
Audia Flight nye cd spiller FL CD Three S er klar for markedet! Dette er cd spilleren for de som ønsker en analog og varmtlydene spiller.
Pris FL CD Three S 28.000.-
Pris DAC modul 3.800.-
Intro pris i en kort periode for spiller 23.800.-
Vi sender fraktfritt!
Ta kontakt om du skulle ha spørsmål ved noe!
JWK Audio/Sound of heaven
Tlf:+47 464 29 861
E-mail: kontakt@soundofheaven.as
Hjemmeside: www.soundofheaven.as
FL CD Three S cd player
Audia Flight introduce the FL CD Three S, a brand new development cd player for the lovers of really good music.
Starting with its elegant Italian exterior, the FL CD Three S has solidly built casework with a thick aluminum (10 mm) front panel.
In your hand you'll also find a compact, ergonomic remote control hewn from solid aluminium. A large, blue OLED display will keep your eyes informed about all info you need.
The new unit is making use of a CD-Drive which is optimized for single speed playback and not just another computer drive. Also it uses two AKM4493EQ 32-Bit Dacs with “velvet sound” technology (one per channel).
In addition to that Audia Flight is offering the choice of no less than six Digital Filters and one of them is a modernized version of the legendary Audia Flight filter in the original Flight CD1.
Audia Flight is using two completely separate toroidal transformers for the analog (58VA) and digital (36VA) circuits.
Unlike most manufacturers the analog output section of the DACs is fed from the analog power supply as well.
The output section is, in Audia Flight style, A Class discrete current feedback technology and naturally the unit is fully balanced, so balanced and unbalanced analog output are available. It is also available a digital output.
As a special option an input card with five digital inputs (2x Opto, 1x AES/EBU, 1x Coax, 1x USB) is available and can easily be retrofitted at a later point in time.
The USB input allows for 32/384 PCM and DSD 512 and thus makes the unit future proof as a standalone DAC. All digital inputs are insulated to prevent any noise from the digital sources.
All digital inputs are optionally upsampled up to 32bit 768KHz.
100% Made in Italy
Technical Data
Frequency response: 0.5 Hz ˜ 20 KHz ± 0.1dB
Upsampling (only for digital inputs): 32 bits, 768 KHz
Dynamic Range: 126 dB
THD: + noise: >0,01%
Noise: >- 113 dB
Balanced and Unbalanced outputs
Maximum output voltage: 2.5 Vrms
Output impedance: 200 Ohm
Digital Output: PCM S/PDIF
Stand-by power consumption: less than 0,5 W
Operation Power consumption: 30 W
Main voltage AC (50-60 Hz): 100, 110-115, 220-230, 240 V
Dimensions: 450x110x430 mm (WxHxD)
Weight: 10 Kg
Shipping dimensions: 550x250x580 mm (WxHxD)
Shipping weight: 15 Kg
Optional Digital Board:
Inputs:
• 1 XLR AES/EBU
• 1 coaxial SPDIF
• 2 opticals
• 1 asynchronous USB
All inputs are insulated.
The USB input can accept files 32 bit 384KHz and DSD512
Link tester:
www.audia.it/admin/files/banc-dessai-flcd3s-vumetre-012020.pdf
www.audia.it/admin/files/haute_fidelite_12_02_2020.pdf
www.audia.it/admin/files/STEREO-20-03-AudiaFlight-FLCDThreeS.pdf
sound of heaven
sound of heaven sine annonser
Opera Prima V2 - Secrets of Home Theater and High Fidelity
Strålende test av Opera Prima V2 fra deres nye Classica Line serie (y) Noen utdrag: Opera’s Classica Prima v2 Loudspeakers play easily to high volumes without harshness. With a massive sound...
Nytt merke hos Sound of Heaven - SHANLING
  • 1
Sound of Heaven gjenintroduserer Shanling på det Norske markedet med deres splitter nye modeller CT90 og SM90. Når det kommer til ytelse, pris og kvalitet så mener vi at Shanling har satt en helt...
Indian Line Utah serie
  • 1
Indian Line sin nye serie Utah med modellene Utah 5 og Utah 8 står nå ferdig innspilt og klare for demo i våres show rom (y) Tilbakemelding fra fornøyd kunde:) Hei Jess! Ja dette var herlige...
Franco Serblin Accordo Unica - test i Hi-Fi Plus
Strålende test av Franco Serblin sin nye topp modell Accordo Unica i Hi-Fi Plus :) Noen utdrag: This is a loudspeaker that treats music with ` generosity ` . That sounds quite abstract, but a...
Introduksjonstilbud - Takumi
Introduksjonstilbud på Takumi platespiller og pick up ut mars mnd. Vi vil nå tilby en ferdigsydd pakke fra Takumi bestående av dere kritikerroste TT 2.1 DC platespiller med deres Kuro mc pick...
Takumi Moving Coil Cartridge Series - priser klare
Takumi Moving Coil Cartridge Series The Takumi range of moving-coil cartridges is designed and hand-assembled with one clear purpose: to extract music from the groove with precision, stability...
