Audioquest Dragonfly Black and Red
svk
:rolleyes:
Beklager ot.
Men anskaffet dragonfly black. Koblet til Ipone6 via kamera adapter.
Fikk da opp feilmelding at Dragonfly trakk for mye strøm til å kunne benyttes på telefon.
Noen som vet løsning på dette?
Jonas
Sikker på at du har en black og ikke en dragonfly v1.0 eller v1.2? Skriften skal være i gull på dragonfly black. Både black og red skal fungere fint, så hvis den trekker mer enn iphone6 tillater så bør du ta den med tilbake til forhandler for å få den sjekket.
Da spørs det om det er 1.0 elr 1.2 jeg har. :rolleyes:
Jonas
Begge er er vel feil til ditt bruk. Er vel 1.5 du skal ha
svk
Noen som har prøvd sammen med tidal og mqa?
Har registrert med på audioquest.com
Men ikke funnet noe ang mqa?
svk
Fant denne på et annet forum:
Quote from Head-Fi
Emailed them today and got this reply. It seems we'll never get it :/
"The software update will be available to download for free via the Desktop Manager app on our website: DragonFly Series. The MQA update will not be launched until Tidal has a resolution for their buffering issue. People simply aren’t buying hi res MQA files, they’re streaming them. With so little material to choose from, this delay should not cause any issues. We want to be a good partner to Tidal and not put any additional pressure on them. As soon as they’re ready, we’ll make the update available.
If you registered your Dragonfly, you will receive an email when it's available.
Please note: you will need to use a suitable media player to play MQA files. This is because MQA requires a decoder and a renderer to play a file. The renderer is built into the Dragonfly and the decoder is built into the media player's software. Once updated, your Dragonfly will glow a beautiful shade of blue to let you know you're playing an MQA file.
Our apologies if this delay causes you any inconvenience.
Best regards,
Alasdair Patrick
AudioQuest
2621 White Rd., Irvine, CA 92614
AQ Main: 949-585-0111
www.audioquest.com"
svk
Red har 9016 dac og black har 9010. Så teknisk sett er jo denne bedre. Så da er det vel bare løp og kjøp?
Edit: hvor ble det av innlegget jeg svarte på?
svk
BeetleBug
Hei,
Det ble slettet av meg ved en feil. Beklager!
Jeg har hatt Dragonfly Black og Red og byttet dem ut med fordel for HifiMe Sabre 9018 da jeg mener den spiller klart bedre. Forskjellene var tydelig både med øretelefoner og på stereoen hvor jeg kobler den til med vanlig jack til RCA overgang.
BB
svk
Sabre ser ut til og gi 2volt ut også. Ingen norske forhandlere?
BeetleBug
Sabre ser ut til og gi 2voltb ut også. Ingen norske forhandlere?
Nei, ikke enda ihvertfall. Det tar ca 14 dager fra du betaler til du har den levert på døra avhengig av somlingen hos posten i Norge.
BB
svk
Ser ut til at en må punge ut med 2-3000 om en skal ha en portabel dac som er bedre.. eks oppo ha2
iMystic
Men hva med M2TECH hiFace DAC. Funker knallbra på iPhone med camera adapter og en høyohmig hp som hd600/650/800. Hiface dac er også 32/384kHz kompatibel!. Kr 1490 fra dustinhome.
svk
Hadde ikke denne høy utgangsimpedans eller noe sånt? Slik at den ikke var egnet til hodetelefoner med liten motstand. Veldig mange er 80 ohm eller lavere.
baluba
Kopervik og Bergen
Hei,
BB
Men hvordan er strømforbruket ved bruk til telefon ute i feltet? Dragonfly Black og Red drar jo svært lite strøm fra telefonen.
BeetleBug
Hei,
BB
Hei Baluba,
Jeg merker ingen forskjell mellom Dragon og HifiMe Sabre.
BB
svk
Noen som har prøvd dragonfly sammen med samsung s8/s8+ ?
Hvor mye strøm brukerer deres mobil etter 1 time sammen med dragonfly?
Har brukt 20% på 45 min.
svk
MQA for DragonFly is Here!
Owners of AudioQuest DragonFly Black and DragonFly Red USB DACs can now update their devices to firmware version 1.06 which includes support for MQA rendering and optimizations for use with Android devices.
Trond_B
Fungerer knirkefritt på Android telefonen men har litt problemer på iPad mini 4 som jeg kjøpte. Nesten som det er dårlig kontakt av og til slik at musikken stopper opp og DragonFly Red blinker i forskjellige farger. Har prøvd to forskjellige Apple Lightning to USB Camera Adapter med samme resultat. Vanlig problem?
svk
Black virker fint på div ios dingser hos meg. Høres ut som en defekt i ipad eller dragonfly
Kabeldragern
Kristiansund
Samme til meg. Har RED. Misset også på oppgradering fra AudioQuest. På vei inn til HIFI-Klubben for rep/bytte.
svk
Feilet den under oppdatering? Eller er det den nye softwaren som tuller?
Trond_B
Nei. Skrev siden 10.3.1. Flere som skriver der at de også har problemer med DACer som er merket med Made for iPhone.
Trond_B
Etter litt testing så virker det på meg som det er litt bedre lyd fra DragonFly Red/Sony Xperia XZs enn fra DragonFly Red/iPad mini 4. Går digitalsignalene en runde gjennom iOS før DragonFly? USB Audio Player Pro går forbi Android gjennom en egen USB driver og henter digitalsignalene direkte uten tap av kvalitet.
Apple har heller ingen støtte for Hi-res audio så du får ikke utnyttet DragonFly sitt potensiale fullt ut. Når jeg bruker Xperia XZs sammen med DragonFly så lyser den opp i både grønt, blått, amber og rosa etter oppløsningen på musikkfilene. Synes dette er for dårlig av Apple i 2017. Er du opptatt av best mulig lyd så styr unna Apple er min mening.
svk
Skal ikke være sånn, er noe galt med ipad'n din.
Hvordan spiller du hires med ipad'n ?
evhvis
Grimstad
Er forskjell på usb-adapterne til IOS enheter. USB3 adapteren (den som har USB3 støtte og ladport sammen med usb-uttaket) har klart bedre lyd enn den lille, men begge henger et stykke etter å koble dragonfly red i en PC. Tipper det er strømkvalitet som er synderen (kapasitet, impedans og støy).
Trond_B
Tror ikke det er noe feil på den, bare Apple som henger litt etter Sony når det gjelder lydkvalitet. Går ikke men den funker fint som fjernkontroll til Linn Akurate DS. :cool:
Trond_B
Hva har jeg misforstått? Jeg kjøpte den først og fremst for å styre avspillingen av musikken jeg har gjennom nettverksspilleren Linn Akurate DS. Fungerer utmerket til dette. Ser på nettet at mange har problemer med DragonFly og Apple. USB3 adapteret skal fungere bedre men da må du ha strømforsyning i tillegg. Ikke så portabel lenger da.
svk
Du sier at apple ikke støtter hires, apple gjør det. Men ikke via den innebygde musikk spilleren. Du må ha onkyo hf player.
Jeg får alle fargene i dragonfly med iphone.
evhvis
Grimstad
Må strømforsyning? Hvor har du fått det fra? At man har mulighet til å lade mens man bruker USB til kamera, DAC osv. er ikke det samme som at man må ha ekstra strøm.
Reaksjoner: svk
iMystic
Kan noen verifisere med sikkerhet hvordan apple USB3 adapteret fungerer i praksis? Jeg har selv vurdert dette for å lade iphone under bruk, men tror ikke det fungerer. Apple sier jo adapter er for å gi støm til den tilkoblede enhet (feks DAC), og da spørs det om det vil fungere uten power tilkoblet adapter, eller lade iPhone. Apple sier ingenting om at man kan lade iDevice via USB3 adapteret...
Trond_B
Det er vel strengt tatt ikke Apple som skal ha æren men Onkyo spilleren fungerer faktisk. Kostet meg riktignok 109 kr. Burde vært innebygd Hi-res støtte i Apple sin egen spiller.
Mulig den fungerer uten strøm men dette står på Apple sin produktside for USB 3 adapteren:
"Gjør iPad Pro kraftigere og mer fleksibel ved å koble en USB-lader til Lightning-til-USB 3-adapteren for kamera. Deretter kan du koble til eksterne USB-enheter som huber, Ethernet-adaptere, lyd/MIDI-grensesnitt og kortlesere for CompactFlash, SD, microSD og lignende."
Synes apple gjør det tungvint for forbrukerne med sitt kabelrot. Står litt om det her også:
Kommentar: Dette henger jo ikke i hop, Apple? - DinSide
evhvis
Grimstad
iMystic og Trond_B: Et lite google søk og dere hadde funnet ut av alt det ;) Den ekstra lightning porten er for strøm, dersom man trenger det og når ios-enheter får strøm så kan de lade. Den trenger ikke strøm når man har en enhet som ikke bruker mer enn det som maks tillates av strømtrekk på den enkle adapteren.
svk
Ipad og iphone burde støttet hires via innebygd musikkspiller.
Burde også hatt minnekort mulighet for musikk og video/foto. Og enkle filoverføring. Itunes er noe herk
Trond_B
Står jo at en skal koble til strøm før man setter i eksterne USB enheter på Apple sine sider, må jo gå ut ifra at det stemmer da.
