Her er ein kar bortpå kølaholmen som har gått grundig teverks. Ikkje no 3D print-juks heller. Tøffere blir det ikke. Og det funker ! Fra tidsepoken før de "svære svarte bananene" gjorde sin inntogsmarsj i PA verdenen.
Stjålet av meg utpå verdensveven:
"To celebrate Martin Audio's 50th year - i thought i'd build myself a mini Martin audio modular stack!
The whole thing is just 10 inches wide x 15 inches high, pair of boots for scale.
215MK3 bass section is a single 5 inch subwoofer (£5 ripped from a Logitech sub!) + 8 inch passive radiator on the back of the cab. Built from 12mm MDF, then 6mm ply outer.
MH212 is 2 x 2.5 inch full range drivers (Also £5 from a Canton sound base!), the top is just for show.
Powered off of a TPA3116 2.1 amplifier."
Dr.E
Dr.E
