Degritter Mark II
Mark II utgaven av den utmerkede ultrasoniske platevaskeren Degritter kan nå forhåndsbestilles hos oss. Selve produktlanseringen er 25. november. Ta kontakt for tilbud.
Her er en beskrivelse på engelsk av funksjonaliteten til Degritter i forbindelse med nyhetsannonseringen av Mark II utgaven (ny funksjonalitet er merket med ‘NEW!’):
Designed For You
  • Distinctly Automatic
    The Degritter is fully automatic, requiring no additional effort after the cleaning cycle has started. Use the free time for listening to records instead of cleaning them.
  • Simple Water Management
    The machine has a convenient removable water tank for replacing cleaning water.
  • Perfect Touch Buttons NEW!
    We have perfected the feel and function of the machine’s buttons. The rotations and presses provide most satisfying feel you will be unable to let go of.
Ultrasonic Cleaning Architecture
  • 4 Transducer Layout
    Ultrasonic cleaning tank that’s in Degritter is purpose built for vinyl records. The tank has two ultrasonic transducers on either side emitting 120 kHz ultrasonic vibrations, evenly distributing the cleaning energy across the record's surface.
  • Power Drive 2.0 NEW!
    • Pulse Mode NEW!
      Pulse Mode cleaning is a feature offered by the Power DriveTM 2.0 ultrasonic generator. During pulsing, ultrasonic transducers rapidly switch on and off at high power. This gives enhanced cavitation in water, but keeps the average power consumption low.
    • Frequency Sweep
      The driving frequency of the Power DriveTM ultrasonic generator sweeps between 120-125 kHz. This evens the cavitation energy distribution in the water, minimizing losses and giving an uniform cleaning action.
    • 300 Watts
      The average power output of all the washing programs is 300 W. This makes Degritter the most powerful ultrasonic record cleaner on the market per liter of water. The higher 120 kHz driving frequency keeps your records safe.
Clever Features
  • Active Filtering
    Cleaning water is pumped through a replaceable filter during washing. Continuous filtration keeps removed dirt from ending back up on the record.
  • Record Safe Temperature Control
    Degritter monitors water temperature and prevents it from rising to levels harmful for vinyl records. High temperatures are managed by automatic cooling cycles.
  • Smart Drying
    Records are dried by a flow of filtered air. Both the drying time and fan speed can be adjusted to keep noise levels in check and to prevent static electricity build up.
  • Postwash Rinse Option
    Degritter supports rinsing records during washing cycles with the help of a separate water tank.
Gjallarhorn Audio
Gjallarhorn Audio sine annonser
Besøk oss på Oslo HiFi Show nå i helgen
Vi har intet mindre enn 6 Norgeslanseringer under Oslo HiFi Show nå i helgen. Du finner oss på rom 106 og 108 i første etasje. Under kan du se hvilke produkter det er Norgespremiere på. Velkommen...
Gjallarhorn lanserer franske B.audio i Norge
  • 5
B.audio er et forholdsvis nystartet firma, men de har i løpet av kort tid blitt anerkjent for sitt gode design og høye lydkvalitet. Firmaet ble grunnlagt i 2016 av brødrene Cédric og Sébastien...
Sveitsiske Stenheim endelig i Norge
  • 10
Varemerket Stenheim ble etablert i 2010 av fem elektronikkingeniører som tidligere hadde jobbet i det sveitsiske high-end firmaet Goldmund. Deres første høyttaler, Alumine, ble lansert i 2011...
Gjallarhorn showroom holder stengt i romjulen
  • 6
Vi lar julefreden senke seg og holder vårt showroom stengt i romjulen. Men vår nettbutikk vil være betjent og det vil fremdeles være mulig å hente varer på vår adresse ved kjøp eller hjemlån i...
Juletilbud på Harbeth (-25%)
Det blir juletilbud på Harbeth ut desember for å få ned vår lagerbeholdning. Alt av modeller, bortsett fra toppmodellen, er på lager i de fleste finisher. Merk at tilbudet om 25% rabatt på...
Juletilbud på SPEC (-25%)
Vi kjører juletilbud på SPEC i hele desember ved å tilby 25% rabatt på alle produktene som befinner seg på lager. SPEC sine integrerte forsterkere er unike klasse D forsterkere med lav effekt...
