Den gromeste integrerte forsterkeren?
  • ssm
    Denne er superflott , noe av det bedre rørintegrerte på markedet....Italienske GRAAF....modellen heter gm 50 og har kt 88 rør på utgangen , forhandler er Audioart , jeg fant bildet der....
    kablang
    Shanling A-300
    Think Large
    Shanling-a sourous
    At 66 pounds and !8” x 19” x 7, the Shanling A300 is
    the largest hybrid amplifier we have seen. Quality
    speaks loudly for this behemoth, as it smoothly
    delivers over 200 watts of Mosfet power per channel
    into 8 ohms and 280 watts into 4 ohms.
    Large Design
    The A300's hybrid design is dual mono and features
    an input buffer circuitry using two 6922 vacuum
    tubes. The solid state output stage uses four pairs
    of Sanken 2SA1295 / 2SC3264 output transistors
    per channel, for stability, reliability, and control that
    solid state circuitry offers. The A300 incorporates
    two large independent power transformers one per
    channel. For high current stability and dynamics, the
    A300 features a bank of capacitors providing a
    massive 80,000 microfarads of reserve power. A
    premium ALPS motorized potentiometer provides
    noise-free control.
    Large Features
    The front panel also includes a headphone monitor
    output that uses the tube circuitry of the preamp
    stage for warm and detailed sound. On the
    connection side, the Shanlling offers four pairs of
    RCA inputs, plus two pairs of balanced XLR inputs.
    There's also a preamp output plus a final stage
    input. Also included with the A300 is a full function
    wireless remote that makes operation even more of
    a stoned pleasure.
    Large Specs.
    Heavy, rugged and beautiful aluminum
    chassis
    Dual mono design Completely separate
    preamp and power amp stages
    Tube input stage: Two 6922 input buffer
    stage tubes Solid state output stage:
    Four pairs of Sanken 2SA1295/2SC3264
    output transistors per channel
    Total of 80,000 uf of reservoir capacity
    Motorized ALPS volume control
    Four single ended RCA-type inputs and two balanced inputs
    Preamplifier output and power amplifier input
    Headphone jack Remote control
    Power Output: 2 x 200W RMS (8 Ohms) / 2 x
    320W RMS (4 Ohms)
    Input sensitivity: 410mV
    Frequency response: 20 Hz - 30 kHz - 1dB
    THD: 0.08% at 1kHz
    Power consumption: 800W
    Dimensions: 18" wide, x 19" deep, 7" tall
    Net weight: 66 lbs.
    kablang
    Bada Purer 3.8SE
    Bada 3.8H
    . Uses top end Germany WIMA MKP10 capacitors
    . Uses top end Japanese KOA resistors
    . Separate design on Pre-amp and Power-amp, which enabled to be used
    separately. Pre-amp stage is tube based while Power-amp is sold state.
    . XLR Balanced Input
    . Remote controlled
    . Power Output: Class A 80W+80W (8ohm), Class AB 138W+138W(8ohm)
    . THD:<=0.065%
    . Frequency Response: 10Hz-35kHz(-0.5dB)
    . Signal-to-Noise Ratio: >=95dB
    . Power input: AC200V - AC240V 50Hz
    . Net Weight: 39KG
    ceroxol
    Asker
    Cappuccino skrev:
    Jeff Rowland Continuum må med i denne listen!
    Har hatt den selv i mitt andre anlegg noen måneder og den spiller forrykende. Masse av krefter samt mer musikals enn Accuphase E-408 som jeg også har hatt i dette anlegget.
    Finnes i 2 varianter, 250w og 500w. Vil så absolutt anbefale sistnevnte da den også har innebygget den nye PC1 power correction enheten til Jeff Rowland og kun koster $1k mer (totalt $8800)
    Denne JR Continuum var fantastisk lekker, alltid hatt sansen for designet og byggkvaliteten til JR. Hva er en norsk vill- og veiledende pris?
    Pen bakfra også, oohh..
    Casle
    Etter å ha hatt den nyeste utgaven av denne i hus en stund kan jeg trygt poste den i denne tråden. Liten og lekker, ren som en fjellbekk, utrolig rask og med mye pulver når det trengs...
    Chapter Audio Précis mkII.
    /C
    Her sett over cd-spiller fra samme merke.
    Og baksiden.
    ceroxol
    Asker
    Denne fra Burmester passer jo meget godt inn her... Høy siklefaktor!
    spurv
    Her var det masse snadder. Cayin rør forsterkern som blir nevt er uberpen, og ikke så alt for dyr :).
    Selv skal jeg teste denne rakkern om noen måneder (tror jeg):
    Syns denne får det til å låte kjempebra på de fleste høyttalere, ikke så alt for kraftig, men på riktige høyttalre spiller den utrolig godt :).
    belia
    Riktignok en gammel sak, men noe av det feteste jeg vet om. Skulle gjerne hatt denne i et minianlegg på kjøkkenet i stedet for Tivolien.
    Cundis
    Stockholm
    motoren skrev:
    synes denne bør være med her,har dessverre ikke hørt den men her burde det være krefter nok.
    Korsun V8i går jeg virkelig god for, har tidligere hatt fler forskjellig E.C., Gryphon, Papworth, Musical Innovation etc, men denne slår dem alle IMO.
    Legger ved flere bilder av den. :)
    Cundis
    Stockholm
    Hadde en slik i mitt eie for noen år siden, ikke så dum den nei.. :) Iflg. Hifi Huset ble den visst designet spesielt til å matche godt med Nautilus serien til B&W.
    thomand
    Sugden Masterclass tror jeg fortjener en plass her
    Chalshus
    Horten
    Belia: Ser ikke på TV, så da har jeg nok gått glipp av det. ;)
    Tipper denne også er anstendig:
    eldo472
    Tranby
    Sony Ta-F5000. Ikke best lyd, men best finish, design og feeling. Best i forhold til prisen.
    Bilder og historie finnes på thevintageknob.org.
    musicus
    MPT skrev:
    Denne ML 383 har jeg lenge vært nysgjerrig på, og jammen bød det seg ikke en anledning til å teste den hjemme, og det lille jeg har rukket å høre til nå er meget lovende, det eneste "negative" er at den er ren ss ;)
    Proffen
    Bæææærgen
    kablang skrev:
    Bada Purer 3.8SE
    Bada 3.8H
    . Remote controlled
    . THD:<=0.065%
    . Net Weight: 39KG
    Synes også denne rimelig "grom" ut, og den bør jo kunne funke greit til mangt.... (selv om den ser ut som et spin-off-produkt etter Krell`s integrerte FBI-sak...)
    Proffen
    niels
    Nadadouro, Portugal
    Ikke den grommeste, men den må jo med. B100 DA-SST
    Må innrømme jeg er svak for noe sånt her også, luxman L-560:
    musicus
    Grom og krom Fru Bl.., men regner man kvalitet fremfor kvantitet, så soleklar 8)
    John_Harald
    Sørumsand
    Vicarious skrev:
    Hvis 100k plutselig skulle komme min vei hadde nok Devaliet sin integrerte badevekt vært aktuell.
    Det var en voksen kilopris på den badevekten :)
    lakki_luke
    Jæren
    Technical Specification
    Type
    Single Ended Hybrid Zero Feedback
    Power 100 W @4 or 8 ohms
    Frequency Response DC to 200 kHz, -3 dB; 20Hz to 20kHz, +/-0,05dB
    Noise 96 dB IHF reference to 1W
    Gain 35 dB (X 55) Phase status: invert (180 degree)
    THD & N <0.1 %
    Input Impedance > 15 kohms
    Stereo Separation > 95 dB @ 1 kHz
    Tube Complement 2 x 6N23P-EV(E88CC), 2 x ECC85 per unit
    Output Impedance < 0.04 ohms (damping factor 200 reference to 8ohms load)
    Power Requirements 100VAC to 240VAC (50 to 60 Hz), max. 800 VA
    Dimensions 19" (483 mm) wide x 22.2" (565 mm) deep x 16.1" (410 mm) high
    NET Weight approx. 157 lbs (71 kg) unpacked
    TOTAL Weight approx. 212 lbs (96 kg) total with transport wooden box
    J
    J.J
    .........Har jeg oversett Accuphase ?? ........ Eller er den ikke nevnt her ?? ::)
