Finnes det noen "tweaks" som er så "over the top" at ingen går på de?
  • Distinctive
    Noen lærer tydeligvis av erfaring, ja.
    Men blurben for den tidsmaskinen er noenslags rekord i sin sjanger:
    The different perception in respect to any other Audio system, out the physical technology used above any actual system to reproduce music from a CD or DVD player, comes from a time shifting perception (not measurable by any instrument on earth) introduced by the QUANTUM AUDIO SYSTEM. By time shifting it is intended that TIMES VARY (as SPACE vary) depending on the Einstein relationship. This happens in the environment where the audio music is released and reproduced. The time shifting is a human been perception, and it is alterd by al list of means producing electromagnetic fields ad the 50/60 Hz power supply, the 2,45 GigaHertz of microwave hovens, mobile telephones and so on. The time perceiving is completely altered by these media. Also music reproduction in this case will be badly absorbed by human brain/ears. The Royal Device QUANTUM AUDIO SYSTEM, restores in part this time perceiving, and as a result in music reproduction it provides more deepness, more harmonics, high tridimensionality, better focusing, lowering the total distortion perceived by our brain/human ears in respect to any other high fidelity system not using the same bases.
    This results is extremely enhanced by the use of the ACCELERATORE ADIMENSIONALE, that we can assume as a DIGITAL QUANTUM ACCELERATOR for data transmission (never introduced by our science on Earth up to date).
    This works in the DIGITAL DOMAIN and it is a completely PASSIVE UNIT (no power feed, no silicon chips, no CPUs, no batteries, no software that provide any data manipulation). Only data passing thru in and out. The different result can be compared on the spot by substituing it with a normal coaxial data cable.
    INFORMATION can RESONATE IN or OUT the MATTER. If translated into matter, the resonance can sometimes in someway stop.
    This is confirmed by the fact that INFORMATION coming FROM OUTSIDE the material UNIVERSE, can be translated into matter/energy ONLY passing thru subatomic particles that have SPIN = 1/2 (electrons and neutrins). Electrons are held by electric current. While PHOTONS have SPIN = 1 and already have LIGHT in their hand showing the CREATED matter to us. This can be proven.
    THERE IS NO POSSIBILITY to have a RESONANCE using PHOTONS able to withdraw MORE INFORMATIONS from outside the TIME/SPACE environment. This is the reason why downloading a music file from the internet we lose the possibility to have added a QUANTUM RESONANCE to that DATA TRANSMISSION. This even if the DATA has a theoretical mathematical internal higher capacity in terms of speed and bits ---> 24/192 that do not use any compression). Ergo: the file will sound worst than a CD run on a CD player that uses copper (electric wires) to transmit DATA FLOW from the player to the DAC. Talking about the same source file.
    This is also the reason why a spdif connection in copper between CD or DVD player towards external DAC, always works much better in terms of sound quality than the same in fiber optic. But bits aren't bits? where does become this? Science up to now never answered.
    It is on the base of the above points that the ACCELERATORE ADIMENSIONALE works and of course ONLY with the COAXIAL copper connection. Only electrons can RESONATE INFORMATION, because they are with neutrins (nearly no mass) the GATE to get out the TIME/SPACE environment and recover some information from: the UNIVERSAL INFORMATION FIELD.
    Wow. Jeg mener, wow. Der har vi tydeligvis den lenge etterlengtede forklaringen på ulike metallers egenlyd. Mer her, men dessverre bare på italiensk: il PRINCIPIO dell'INFORMAZIONE UNIVERSALE
    coolio
    Alt som er beregnet for det Amerikanske markedet må sikre seg, selv når produktet heter "Useless Box". "It’s not quite totally useless"
    I'm not completely worthless. I can be used as a bad example?
    Synergistic Research PHT. Forøvrig fra ett av de "værre" selskapene.
    En bitteliten sak du setter på pickupen din for å bedre lydkvaliteten. Prisen er et par lusne tusenlapper.
    Iflg. stereophile et bra tweak som absolutt er verdt pengene
    I talked to Denney about the technology behind the PHT, but learned little beyond the fact that the effect has to do with resonances, is akin to "tuning," and is proprietary. Not very satisfactory answers for those with a scientific bent, but, as always, the proof of the pudding is in the eating—and this particular pudding tastes delicious. I think $199/pair for the PHTs, with money-back guarantee, is well worth it.
    Her er det bare å frotse i snakeoil produkter og forklaringer
    Mye flott der - fint design og bra egnet til å trigge "må ha" følelsen! God markesdføring. God forretningside fødselsraten tatt i betraktning. "There's a Sucker born every Minute" I hifiverdenen er vi nok nede på hvert 30. sekund, best å høre med målemafiaen om de kan verifisere det :rolleyes: Eller kanskje gullørene har hørt noe?
    DagT
    Fenalaar
    De hadde jo i sin tid et ganske heftig hornbass-system, som så høvelig gjenomtenkt ut. Her må de da ha røyka minst en meter med pot (jfr hets-tråden)....
    Johan-Kr
    "The snakeoil is strong with this one"
    Denne gang er det naim som uttaler seg om sine kabler...
    https://www.naimaudio.com/infinite-curiosity
    [FONT=&quot]Every Naim Audio interconnect is shaken 180 times by a custom-designed pneumatic production device affectionately named ‘The SNAIC Shaker’ by our technicians. Why do we do this? Because it improves sound quality.[/FONT]
    scaniagutten
    https://oslohificenter.no/kabler/tilbehor/nordost-sort-lift
    6000 spenn :D
    Vis vedlegget 398498
    "...[FONT=kelson_sans] enhances the sonic performance of loudspeaker cables, power cords, and interconnects, by minimizing the points of contact that cables make with the ground and reducing boundary effects, without negatively affecting the resonant properties of the cables themselves."
    jada jada ![/FONT]
    ER DET MULIG?? Dette må være en fleip? 5990,-
    Morten
    Balle Clorin
    6000 spenn :D
    jada jada ![/FONT]
    MAKAN!!! Når de selger slik humbug så mister jeg ganske enkelt tilliten til alt annet de selger også ...
    ymir
    Her,motsatt tenkning
    A.J. van den Hul talks with Thomas J. Norton
    file:///C://Downloads/Dutch_Master_-_Stereophile_Vol_17_No_11%20(2).pdf
    In the process,you bend the cable, stretch it, bend it, stretch it again — 30 or 40 times — so the wire is worn out even before it’s silvercoated.That’s one of the reasons why silver-coated copper sounds harsh.
    A.J. van den Hul
    He studied electronics and physics at the Technical University of Delft in the Netherlands, specialising in measurement techniques. Subsequently, he taughthigh school physics and technical high school for 13 years.
    weld77
    6000 spenn :D
    jada jada ![/FONT]
    For ganske mange av oss har der vært åpenbart at det er et tullefirma lenge før disse løfterene kom. Men bedre sent enn aldri - velkommen i klubben;)
    Min avdøde far var rørlegger. Når han hadde fått til noe riktig lurt, pleide han ofte si "Intet er umulig for Gud og rørleggere... " :)
    Ikke i HiFi verdenen heller....
    Din far var en vis mann! Ingen ting er umulig for Gud og Sluket :D
    svart-hvitt
    6000 spenn :D
    jada jada ![/FONT]
    OHC er vel en av de beste sjappene i Norge (bredden i utstyr, antall lytterom).
    Bare synd de støter fra seg våkne entusiaster med slikt tull.
    På den andre siden: Finnes sjapper (i forbrukersegmentet) som overhodet ikke har snake oil?
    Olav2
    Fikk tips om denne i går fra en med-forumist: hvis man synes at TV-møblene til IKEA ikke er solide nok, kan man alltids bruke «mellom 20 og 35 tusen dollar» på et rack fra Magico?
    Wizard High-End Audio Blog: Magico M-Rack Wizard High-End Audio Blog: Magico M-Rack
    bambi
    Smurfeland
    6000 spenn :D
    jada jada ![/FONT]
    Dette må være det tydeligste eksempelet jeg kan huske å ha sett på at visse deler av denne hobbyen har tatt en wrong turn et eller annet sted for lenge siden, og nå er fullstendig FUBAR.
    Jeg finner det ganske enkelt motbydelig at noen har mage til å skamløst promotere dette 'with a straight face'. Vik fra meg, dere ekle mennesker!
    sprellemannen
    Har sjølv ikkje noko særs respekt for butikkar som tilbyr og selger slangeolja til lettlurte personar, og kor selgarane pøser på med ville påstandar.
    Trur at ein må retta oppmerksomheten mot pro-sjapper som selger hi-fi til privatpersonar for å finna sjapper som ikkje selger slangeolja og der personalet ikkje pøser på med vås.
    oen
    Portugal
    Tror denne tråden har hatt en svært positiv effekt.
    Det har vært en enorm økning av dyre brukte kabler til salgs på Torget i det siste.
    flyer
    Ja det er et slit--------------:p
    weld77
    Jeg tenkte først og fremst på Nordost. OHFC har mye snasent forsåvidt.
    JENO
    Saksvik - Trøndelag
    Det er jo ikke rart at snake oil-bransjen eksisterer, siden det kanskje er det nærmeste man kommer gratis penger. Man bare bytter inn integriteten sin mot penger som folk tydelig vis kaster etter hva som helst, så lenge noen påstår at det forbedrer lyden.
    - men for Norges del er jo oljebransjen nede...? Dårlig med slanger her til lands også.
    Damtatam..
    Filter Modules
    On the basis of these findings we have devoloped products to recondition electricity for hifi and home cinema systems.
    The "Spatiumaudio Clavis Filter Modules" contain three seperate modules wich are especially matched with the requirements of the hot/phase, neutral/zero and the safety earth conductor.
    The innovation is based on a conductor wich is polished to a very low surface roughness. This conductor is surrounded by a matrix of different metals and minerals wich are encapsulated/ sealed in a box to secure and lock them into position.
    The modules are directional which means that they only unfold their optimal effect in the preferred direction of installation.
    In addition, there is a chip at the bottomside of the case of the filter wich regulates the function of the modules. The chip is exactly matched to your hardware requirements and allows tonal fine tuning.
    The parameters in the chip are custom programmed to each client.
    The result is a fidelity and picture quality wich fathoms the whole potential of your music an home cinema system
    Og de høyner med
    [FONT=&quot]Not only a Filter:
    [/FONT][FONT=&quot]The Spatiumaudio Crystal Clavis Filter Modules are not only a filter which improves sound and picture quality by reducing noise, but it is a "burn in generator" too which optimises the whole signal path . Even after removing the filter from the system this effect remains for weeks[/FONT]
    [FONT=&quot].[/FONT]
    Og på ebay får vi kjøpt ATP Quantum Disc
    ATP Quantum Disc | eBay
    This is a Quantum Disc by ATP, specially designed for Schumann Resonator Chartres series add on
    Quantum Disc is made from Quantum Powder level-3 and it cleans surrounding air by
    absorbing and controlling all waves that ruin the sound
    Result is more live, clean
    and dynamic sound while maintain focus, layering and musicality
    Placement is not only at Resonator coil but you can try at top of loudspeakers, BD Player,
    top of Amplifier DAC Power distributor/conditioner and Processor / HT system.
    grammofon
    Tenkte jeg skulle ta deg her (mobb mobb), men dessverre hadde du som vanlig rett:
    [h=1]"Mindre flått og hoggorm i år[/h]Kulde uten snø på bakken har ført til døden for flere av sommerens plagsomme arter, forteller zoolog."
    Faen også......:)
    vidarje
    Rasta
    Vi har da tre arter:
    Huggormen (Vipera berus), Buormen (Natrix natrix) og Slettsnoken (Coronella austriaca) :)
    ekstremsound
    Banned
    Tweak er å la USB dingsene dine stå på i minst 24 timer for å få best resultat.
    http://www.audioquest.com/resource_tools/downloads/whitepapers/Phase-Noise-Jitter-Report-0317-14.pdf
    Ja det er fuldstændigt rigtigt seriøse firmaer som Bruel og Kjær og Radiometer lader deres apparater står med strøm på i mindst 48 timer inden justering og støjmålinger, og typisk er der også kørt en indbrænding i klimaskab over mange dage inden slutjustering . ellers er det helt umuligt at få et stabilt resultat
    Hvordan ved jeg dette , det ved jeg fordi jeg har været ansat i begge firmaer og bl.a har lavet disse målinger og justeringer.
    Og taler vi om hifi så er der ingen tvivl om at opvarmning på nye eller apparater som har været slukket har betydning for lyden det stabiliserer sig også her først efter 24 -48 timer eller mere.
    Og det er også vigtigt her at forstår at selv kabler er en kombination sammensætning af ganske almindelige passive komponenter og derfor virker og reagere som sådan.
    Faktisk er det vigtigt at forstå at alt det som mange ser som "hokuspokus" det er overhovedet ikke "hokuspokus" men velkendt stof i i seriøse måle-firmaer.
    Det som diskussionen snarer gå på er om disse uendelig små måleforskelle faktisk er hørbare, rent teoretisk burde de typisk ikke være det.
    Men min mening er at det er de nogle tilfælde, men ikke nødvendigvis i alle, det er det som som jeg kalder stukturen i audio-signalet , en struktur vi alle genkender når den er rigtig , men også genkender når den er forkert.
    En struktur som kan genkendes igennem et åbent vindue eller dør.
    vidarje
    Rasta
    Det jeg også reagerer på er at n=1 brukes som bevis. De kunne i alle fall testet 5-10 DACer og vist gjennomsnittskurver med spredning og til slutt regnet på om det virkelig var signifikante forskjeller. Det er fult mulig de har gjort det og valgt å vise et sett med "typiske målinger (DVS den som passet best med markedsføringen).
    Et annet spørsmål er om det vil være hørbart (blindtester:))
