FM Acoustics
  • wizard
    Dynaudio høytalerene er nå byttet ut med Rockport Altair.
    wizard
    Og 115 effektene er nå byttet ut med super forsterkeren; 1811.
    Og Wadia riggen er byttet ut med Scarlatti.
    wizard
    Og et bilde av sjefspreampen 268 med sin Harmonic Linearizer.
    wizard
    En 1811 på vei til..
    for å testes her
    wizard
    Bruce Moore rør Pre
    Øverst 133 Linearizer
    wizard
    245+411II koblet til Magico Mini2
    Forceline 5 kabler.
    wizard
    Fra Audiogon
    I just heard a FM 255 in my system as well as my friend's and my god, NOTHING prepares you for it as we nearly died of shock in what we heard. We also had a Krell KCT and a Mark Levinson No.32 in hand for A/B/C and once the FM 255 went into the system, it made the other two sounded like a TOY. It is clearly IMO 6+ times better as everything about the sound is so correct, natural, resolution, dynamic, scale, timber.....OMG.....Yoy guys have to hear this thing in action.
    It is that good that Im not listening to music with the other pre amps.
    Their model 268 has a remote. And in the package, it throws in a 'superb' built-in linealiser section too! Imo, they are one of the finest, if not the BEST linestage currently available. From where I hail priced at around that of a brand new Benz E320!! Although in$anely expen$ive, I believe them to be a once-in-a-lifetime investment for most (ie.no more the urge to upgrade!). Look one up, they are worth a listen!
    Have had the opportunity to listen to the a pair of 1811s driving the Genesis 1.1 loudspeaker system and must say it is really good. After having in my system FM 255 pre and 811 power combo for the good part of 07 years I can only testify that Fms are the ultimate in it's class. The "Rolls Royce" of hi-fi , period.
    Having heard recently two different set-ups of 'FM Inspiration System1s', one being driven by 266mkII and a pair of 1811s. The other a 268 with a pair of their Anniversary 2011s (total 4pcs).. Left me plain speechless! Made me took the plunge and bought their 268 to partner them with my 611 for the time being.
    However, here's a story I'd like to share which happen late last year. A friend with the Kharma Grand Exquisite speakers ($300K+), tried to compete with this other guy driving the full FM Inspiration System1. However out of pride and not wanting to be called a follower, he tried all means to avoid the FMA gears used by the other guy (certainly not cost consideration as this Kharma guy has in his garage 2 Ferrari Enzo!!).
    He then seeks and even imported some of the best gears he knew ranging from Golmund Telos 2500, top line Burmester, biggest Boulders, Spectrals to Wavacs, after six months of trying and huge monetary loss, he gave up and only to end up with--you guessed it--exactly what his 'competing' friend has-the full FMA work. Well.. we just have a good laugh each time this story is brought up within the local audiophile circle. A good effort, but just ain't good enough I guess.. ;)
    wizard
    268+611 koblet til Magico Mini2
    Kabler er Forceline 3
    wizard
    Fra RMAF 2008
    245+811II, Weiss og YG høytalere.
    wizard
    Litt historie
    800A - den første forsterkeren til FM Acoustics - ble introdusert i 1976.
    FM 600A & FM 800A were the first power amplifiers manufactured by FM ACOUSTICS.
    The FM 800A was the result of a decision to build a robust power amplifier with safeguarding, better cooling system, higher output power and improved control of the speaker diaphraghms (all weaknesses of the design that at that time was the ‘State of the Art’ in power amplification). It was designed for our own use in room analyses. Only four pieces were built.
    One day an FM 800A’s was loaned to musician friends because their amplifier had broken down. A week later, enquiring about the return of the amplifier, the answer was straightforward: “we’ll never return the FM 800A because it sounds fantastic, so much better than any other amplifier…” (it must be remembered that at that time, it was generally believed that “all transistor amps with similar power and specs sound exactly the same”).
    This “much better sound” provoked our scientists to start a massive research to find the reasons for the audible superiority over other power amplifiers. Over the years, this self-financed R&D has provided a wealth of know-how which allows us to better understand certain interactions and circuit behaviour under dynamic conditions. It is the application of this know-how that makes FM ACOUSTICS products unique.
    The FM 600A was introduced in 1977 when a power amplifier for professional applications with somewhat lower power was requested. In its three versions it was manufactured for over 20 years.
    In the late 70ies, speakers with lower impedances came on the market and consequently more drive capability of the power amplifier was required. Specially for such applications, the ‘LI’ (Low Impedance) versions were introduced. FM ACOUSTICS were the only high-power amplifiers remaining absolutely stable and transparent while being able to drive impedances of 2 Ohms with unprecedented quality. They became a wide success.
    When speaker impedances dropped further, even more drive capability was required. The ‘ULI’ (Ultra Low Impedance) versions were introduced.
    It has been remarked that no other brand ever came close to these flagships used in studios, with musicians on stage and in private homes. Over 90% of all FM 600A’s and FM 800A’s that were manufactured are still in regular use today, indeed a rather rare occurence in audio. FM ACOUSTICS continuously invests in a tremendous parts stock and has kept available these parts over all these years, so even today these amplifiers can be kept functioning perfectly.
    Even complete restorations of products are performed. While this is a loss-making endeavour, we keep providing this service to our clients. After all, these amplifiers are part of our heritage.
    wizard
    An Audio System that Spares No Expense.
    When you spend $200,000 on audio cable, you know you're in a whole new league.
    When the owner of this home theater decided on having an audiophile-grade system, he went all out—to the tune of more than a million dollars.
    The room consists of super-high-end Wilson Audio loudspeakers, FM Acoustics 811 and 115 amplifiers, a Meridian surround processor and DVD player, a Halco preamplifier, dCS SACD transport and digital-to-audio converter, ReQuest Multimedia hard drive servers, about $200,000 worth of Transparent Audio cable, and a Faroudja D-ILA (direct-drive image light amplifier) video projector and processor—and those are just the highlights.
    “It’s nothing like I’ve experienced, and I’ve been in the business 25 years,” says audio/video installer Don Krasen of Krystal Clear Audio-Video. To say this system is powerful is a huge understatement. FM Acoustic amps can pump out 350 watts into 8 ohms of impedance and almost 900 into 2 ohms of impedance, and the Wilson loudspeakers will go down to 3 ohms, according to Krasen.
    In addition to the tall Wilson Alexandria speakers in the front and the Wilson Maxx speakers in the back, Krasen used a Wilson Watch center channel and five Wilson Watchdog subwoofers. “One sub is in front under the center channel, because Wilson doesn’t have full-range center channel,” says Krasen. The sub provides the low sounds for that speaker.
    Bass traps built into the corners with MDF board and filled with insulation absorb excess bass and help hide three of the subwoofers. Another is visible in the back. Krasen, an acoustic consultant himself, designed the room and bass traps in conjunction with Reiss Audio. “There’s prodigious bass, but it’s extremely tight,” says Krasen.
    The sound doesn’t go outside the area. “The room is designed like a recording studio,” Krasen explains, with room-within-a-room construction and a decoupled floor, so it’s not joined directly to the walls and susceptible to traveling vibrations. Acoustic foam and a space between the two perimeter walls also help isolate the sound.
    wizard
    The Gold Series
    In the early 1980's gold anodized versions were manufactured.
    The units available were the FM 212A Moving-Coil head amplifier, the FM 240 Thermo-Quad A Stage preamplifier, the FM 300A, FM 600A and FM 800A power amplifiers (in LI and ULI version).
    Due to regular demand, they were produced for almost 10 years until they were finally superceeded by the Resolution Series.
    Moiz Audio
    wizard skrev:
    Litt historie
    prøvde å vinne denne på ebay en stund tilbake, men som sagt den ble solgt for 2.5X buden jeg la inn
    :-X
    wizard
    Og her 2001A mono.
    Kom i 1995.
    Forløperen til 2011.
    Classic F-50B er også basert på 2001A, men i en enklere versjon.
    wizard
    Sikkert mange som har lurt på prisene.
    Netto Priser (ingen rabatt mulig)
    Prisene er uten mva og toll el noe.
    I CHF
    Pre
    155 - 10500
    245 – 21000
    255II – 36000
    266II – 63500
    268 – 110000
    Effekt
    411II – 49000
    711II – 70000
    115 – 85000 pair
    1811 – 133500
    611 – 57000
    611X – 60000
    Classic Series F-10B 18000
    Classic Series F-30B 27000
    Classic Series F-50B mono 77200 pr pair
    Riaa
    122II – 12000
    222III – 36000
    133 – 10500
    233 – 31000
    Høytalere
    XS-I – 325000
    XS II – 115000
    XS-III R – 75000
    Kabler
    Interconnect
    2x0,6m 1650
    2x1,2m 2150
    2x3m 3200
    Høytaler
    Forceline 3 og 5
    2x1,5m 4500/3300
    2x3m 6600/4600
    wizard
    wizard skrev:
    Og her 2001A mono.
    Kom i 1995.
    Dette settet er tilsalgs hos AV Partner i HK og er helt nytt.
    Pris 520,000 HKD.
    Roysen du er kanskje interessert?
    wizard
    Fra Audio Limits
    245+611X som er tilsalgs, koblet til Venture høytalere.
    wizard
    XS-1
    14Hz-32Khz, 110kg stk, 65x130x70cm
    wizard
    Jeg liker designen på 411II, og selvfølgelig hvordan den låter!
