Høyttalere HORNOGRAFI !!!
  • BangBang
    Okka by
    Audio Note (UK)
    "A customer and great friend of Audio Note (UK) asked for something very special. He required the ultimate system we could produce, and the ultimate 211 SET amplifiers.
    Andy Grove took up the challenge, and here is the result; a system that represents the current pinnacle of sound quality.
    The ‘ULTRA’ amplifiers are true one-off designs, where everything from the casework to the output transformers has been custom designed and hand built. They have a solid copper chassis, milled from one piece, massive 55% nickel interstage and output transformers, nickel/silver chokes, and a filament PSU which took over six months of R&D to design.
    The output valve is the STC 4242, which is similar to a 211 but with a Molybdenum anode.
    The rest of the system features our top level statement products, which have been further optimised down to the last resistor by Andy Grove himself.
    Combined with the GIP-9700A horn ‘speakers from GIP Laboratories in Japan, this system is like nothing else in the world. We were truly honoured to be asked to collaborate in the execution of this project; the results are thoroughly magnificent.
    Here is the breakdown of the system: -
    TT-Three Reference turntable
    AN-1S SOGON tonearm
    IO Ltd Field Coil cartridge and power supply
    AN-S9 Step Up Transformer
    M9RIAA phonostage
    CDT-Six Red Book CD Transport
    Fifth Element / Fifth Force DAC
    M10 Signature preamplifier
    ULTRA Single Ended Triode power amplifiers
    AN SOGON and SOOTTO cables throughout
    GIP Laboratories 9700A horn loudspeaker system (extensively modified by Audio Note (UK))"
    Bjørn ("Orso")
    Destination Audio:
    Topphornet ligner mye på JBL sine biradiale horn. Og så er det trolig foldet horn under tilsvarende som Klipsch Jubilee bruker. Prisen skal være $95,000 for paret!
    LMC
    Drøbak
    folk vil ha brød og sirkus!
    det får de til gangs
    ca 91K USD profit!
    oks81
    Hjemme
    Destination Audio:
    Vis vedlegget 440210
    Vis vedlegget 440211
    Det der er JBL 2360 horn.
    Om prisen er slik, så tørr jeg påstå mitt oppsett er et aldeles vellykket Olsen Banden ran i øverste klasse!
    Bjørn ("Orso")
    Er vel heller de som utfører ran! Det koster riktig nok å produsere noe i pent treverk i vesten. Det er ikke billig og innebærer gjerne mye manuelt arbeid. Men prisen er uansett meningsløs og det er kopier av andre ferdige løsninger.
    oks81
    Hjemme
    Enig med deg :)
    Er det så dyrt bør det ikke være kopi.
    Evt må det markedføres på et vis med JBL merke som er opprinnelsen her.
    Men høyttaleren er tøff!
    trosse1
    Dette er ikke mitt prosjekt eller mine horn- sytes bare de fortjente en plass i tråden- skikkelig snekkerbu porn
    rumath
    Små hornhøyttalere som egner seg til meget kompakt lytterom? Expertisen er her skjønner jeg. :)
    Fint om de har litt spenstig bass også. Skal drives med Hegel Røst.
    oks81
    Hjemme
    Hvor små må de vere? :)
    rumath
    Godt spørsmål. :) Har system audio aura 50 der i dag. Kan tåle opp mot en meter. Ca. 25 cm brede, noe dypere, men må plasseres nær bakvegg. Hadde klart å plassere jbl 4319 eller Klipsch Heresy under tv'en, men da må jeg bytte stereobenk, til noe smalere. Dog ønsker jeg meg noe som ikke ruver for mye, er et lite rom. :)
    Bjørn ("Orso")
    Gode hornkonstruksjoner ruver. Slik er det bare. Et lite horn innebærer så mange kompromiss at man er mye bedre tjent med å velge et annet type design.
    rumath
    Hah, ok, så ingen av de mindre Klipsch RP-høyttalerne duger? Hmmm, tror det må finnes noen jeg da, men kan hende du ikke er den rette til å svare?
    Bjørn ("Orso")
    Du får en klassisk kollapsende direktivitet med slike hornkonstruksjon. Den går brott fra å være smal til bred og det midt i et sensitivt området. Det har lite med god lyd å gjøre IMO, så sant man ikke sitter et svært godt behandlet rom/studio. Da mener jeg det er bedre med et design som sprer bredt og uniformt. Som f.eks PSB høyttalere.
    baluba
    Kopervik og Bergen
    Nei, slik er det ikke. Orso omtaler frontladet fulltone-horn, det lager ikke Klipsch utover et par digre modeller. Alle "moderne" Klipsch har bassrefleks, og er altså bare horn i diskanten. Så de kan du trygt satse på uten å bry deg om Orsos litt unyanserte svar. Han tar heller ikke høyde for greie bakladehorn som passer akkurat til din beskrivelse. De har riktignok ikke fryktelig dyp bass, men er heller ikke store som hus. Så med en liten og nett subwoofer til ekstra hjelp i bunn vil slike kanskje være løsningen for deg?
    Eksempel på bakladehorn/eksponentialhorn.
    oks81
    Hjemme
    Mitt beste råd er at du veit best hva du liker.
    Rundt å lytte, lese litt, så finner du det du liker :)
