Hva menes med tweeting av forsterkere
OMF
Regner med at du mener "tveaking".
Går ut på å forbedre ytelsen til utstyret. Dette kan være ting som:
- sette inn bedre kondiser
- skifte interkabling
- skifte kondiser
- dempe chassis
- osv osv osv
OMF
PAR
Wikipedia:
Tweaking refers to fine-tuning or adjusting a complex system, usually an electronic device. Tweaks are any small modifications intended to improve a system.
In electronics, it is a synonym for "trimming." Analog circuit boards often have small potentiometers or other components on them that are used to calibrate or adjust the board as a service procedure: the small insulated screwdriver used to turn them is often called a "tweaker."
This use was echoed in the name of the product Tweek [sic], an audio product, popular during the 1980s (but controversial), which was claimed to improve the electrical characteristics of audio switch contacts.
