Lab12 DAC1 Reference
  • Analoglydende DAC basert på TDA 1543 og triodeutgang!
    Lab12 har konstruert en ny NOS-DAC som overgår tidligere konstruksjoner. Den heter DAC1 Reference.
    Produktet har et no-sampling, no-upsampling design kronstruert rundt Philips multibit DAC chiper.
    Lab12 DAC1 Reference har også rørbasert utgangstrinn.
    Info fra produsenten:
    With the ever-expanding market of digital audio, both files and online streaming services, more and more people are discovering the world of digital audio. Furthermore, in the past few years many of the most demanding music lovers and audiophiles have discovered the unique sound of non-oversampling DACs to make the most of their digital audio sources.
    The biggest challenge for any DAC is the sound and not the ‘’numbers’’. Digital by default sounds very different when compared to analog and we at Lab12 have spent countless hours striving for the perfect voicing that resembles the very best qualities of analog. We couldn’t be more proud of our newest creation Dac1 reference. In this new DAC, which is based on the same core and philosophy as the successful and multi- awarded Lab12 Dac1 Special Edition, we pushed the limits even more in all stages, such as power supply stages, digital inputs crucial paths and receivers, jitter reduction etc, in order to reach the closest approach to the original analog sound.
    Dac1 reference uses eight multibit Philips DAC chips in a complex parallel configuration right after an efficient layout digital receiver stage, allied with two dual triodes tubes in output stage. Each and every part has been selected for its sonic value that brings identifiable and coherent benefits to the final sound you will hear. The result is one of a kind emotional and transparent sonic performance. As all Lab12 products, Dac1 reference also comes with two colour choices of glass blasting anodizing finish.
    Specifications: • Power: 210 – 240VAC 50Hz (110 – 120VAC 60Hz) • Power consumption: 70 VA max • Inputs: 2x SPDIF (Coaxial RCA), 1x USB2, 1x spdif (Optical Toslink) • Outputs: 2x RCA, 2x XLR unbalanced (balanced version available) • Frequency response: 20Hz to 20 KHz + 0dB/-1dB • THD: lower than 0.15% • Rated output level: 2.5Vrms • Tube complement: 2x 6922 dual triode • Available Colours: Matt Black, Frozen Silver • Dimensions (WxHxD): 43x11x29 cm • Weight: 7.5 Kg
    veil. Pris: 30900 ( Ta kontakt for beste tilbud!)
    Moiz Audio
    epost: info@moiz.no
    cbarth1
    Arendal
    Denne virket spennende! Finnes det en versjon som er fullbalansert? Hva er evt prisen på den?
    Moiz Audio
    Hei finnes ingen Fullbalansert versjon.. hvor har du sett dette?
    cbarth1
    Arendal
    Leser bare over her: Outputs: 2x RCA, 2x XLR unbalanced (balanced version available)
    motoren
    Flekkefjord
    Denne virker svært spennende :) Hadde vært moro å teste ut i eget oppsett
    Moiz Audio
    versjon med Lundahl OPT er tilgjengelig for bestilling
    Moiz Audio
    Moiz Audio
    Vi får inn en versjon med Lundahl utgangstrafoer neste uke. Pris: 38900 NOK
    Moiz Audio
    Hifi har testet DAC1 Reference
    Vi får inn nye enheter denne uken!
    Moiz Audio
    Lab12 DAC1 Reference tilgjengelig for hjemlån!
    Dharmabum
    Denne dac'en er sabla god! Har dere sammenlignet stock power cord vs lab12 knack?
    Nemlonif
    Jeg har hatt DAC1 Reference på hjemlån fra NAT noen dager, og må si det er et svært spennende bekjentskap. Den har spilt seg inn i anlegget, og skaper musikk på en måte jeg knapt har hørt ved digitalavspilling tidligere. Én låt de fleste kjenner, og som er spilt til det kjedsommelige på hifi-messer i inn- og utland, er Lofgren live med Keith don't go. Jeg har aldri hørt strengelyden mer forståelig, kasseklangen mer naturtro enn gjennom Lab12-dac-en. Dac-en er kanskje aller best på akustisk musikk, men den tar alt jeg kaster på den på strak arm, fra redbook 16/44,1 til 24/192. Den er motsetningen av analytisk, men får med seg alle detaljer i en bronseblank brystklang i en sømløs, tredimensjonal lydscene. Og så har den retro-bling-utseendet jeg liker godt ...
    Dharmabum
    Det må være et av de beste dac kjøpene der ute og lydmessig er den veldig naturlig , balansert og analog i klangen!
Moiz Audio
Moiz Audio sine annonser
Burson Audio Soloist Stellar
  • 2
Burson Audio Soloist 3X har blitt faset ut og har nå blitt erstattet med Burson Audio Soloist Stellar. Dette er en kompakt Klasse-A hodetelefonforsterker med 8 W balansert utgangseffekt, i...
Burson Audio Conductor Stellar 8 Watt Headamp/IEM optimalisert/Pre/DAC
  • 3
Burson Audio Conductor 3 Performance serien har blitt faset ut, og erstattet med Conductor Stellar. Fortsatt en kompakt integrert hodetelefonforsterker, men er nå betraktelig oppgradert...
Moondrop Para II
Moondrop Para II
  • 4
Nyhet fra Moondrop! Vi anbefaler PARA II hodetelefoner for audiofile som ønsker en allsidig planarmagnetisk hodetelefon til en konkurransedyktig pris. Lydsignaturen er naturlig og balansert. PARA...
AudioByte SuperVOX Multibit DSD DAC
  • 4
AudioByte SuperVox er designet for lydreproduksjon av absolutt ypperste kvalitet. DAC-arkitekturen er basert på AudioBytes egne proprietære digitale algoritmer og full balansert diskret analog...
Audiophiliac tester Lab12 DAC1 Reference
  • 22
klikk på bildet Lab12 har konstruert en ny NOS-DAC som overgår tidligere konstruksjoner. Den heter DAC1 Reference. Produktet har et no-sampling, no-upsampling design kronstruert rundt Philips...
Hi-Fi+ har testet Heed Audio LaGrange S
  • 7
Sjekk ut omtalen her: https://hifiplus.com/articles/heed-audio-lagrange-s-integrated-amplifier/ LaGrange S er den nye referanseforsterkeren fra Heed Audio. Forsterkeren er basert på TransCap...
