laptopp kveldet.. må redde bilder igjen..
sense
Rørvik i Nord-Trøndelag
Da skjedde det igjen.. pc,en kveldet og selvsagt hadde jeg ikke kopiert bilder og dokumentene.. det jeg gjorde var og prøve denne metoden her:
File Recovery Guide | Inside my laptop
ikkeno problem og gå inn i documents and settings.. finner alt.. men alt er låst da gammle pc hadde passord.. har fulgt beskrivelsen i linken ,men får ikke opp bilder eller dokumenter.. hva gjør jeg galt???????
mvh sense..
lyntoft!
Kløfta
Har du fulgt alle trinnene i guiden? :
[h=3]“Access is Denied” error message[/h] While accessing user files you can get “Access is Denied” error message. It happens because your user account on the broken laptop was password protected.
In order to get access to user files on the external hard drive you’ll have to take ownership over the user folder.
Here’s how you can take ownership over the Users folder (if you had Windows Vista or Windows 7 installed) or Documents and Settings folder (if you have Windows XP installed).
STEP 1.
1. Access files located on the external hard drive and
– Right click on Users folder (if you had Windows Vista or Windows 7 installed)
or
-Right click on Documents and Settings folder (if you had Windows XP installed)
and after that click on properties.
2. Click on Security tab in User Properties windows.
3. Click on Advanced button.
STEP 2.
1. Click on Owner tab in Advanced Security Settings for Users window.
2. Click on Edit button.
STEP 3.
1. Left click on Administrators group.
2. Check the Replace owner on subcontainers and objects box.
3. Click OK button.
STEP 4.
Click Yes in Windows Security windows.
Process of taking ownership might take a long time, it depends on how many files you have in Users or Documents and Settings folders.
After it’s done, you should be able to get access to your files.
lyntoft!
Kløfta
Hva skjer om du drar filen(e) over til den nye maskinen?
superclementz
Hva med å i det minste synke med photos.google.com? Neste gang kanskje disken er død?
Kanutus
Nesodden
Er så 100%-enig! Disken kan like godt ryke som alt annet på maskinen, og er disken gått så er det ikke så enkelt som 'file recovery' nei ... Backup, backup og atter backup! :)
sense
Skal kjøre backup idag....:) skal se på løsningen til google...
er litt lei krøll med data nå...
mvh sense...
xerxes
Holmestrand
Disken ikke bare kan, men den VIL ryke!
Før eller senere. GARANTERT!
Så helt enig:
  • Husk sikkerhetskopiering
  • Trygt medium
  • Trygt sted
  • Automatisk
hansa-bergen
bruk live cd/dvd linux boot fra den og sett inn minnepenn du får tilgang til disken via linux
Bartesam
Hus
Kjøper alltid laptop med to harddisker. Havner aldri i den klemma :)
