NAS->Squeezebox->Dac VS Cd->Dac.
CDWMcInSpots
Bergensregionen
Asbjørn skrev:
CDWMcInSpots skrev:
Det var nok denne "veteran Hi-Fi journalist" eller en av samme sorten, jeg snublet over i Hi-Fi Choice (eller Hi-Fi News & Record Review). Det passer også ganske bra med tidspunktet, sommeren 2010 eller litt tidligere.
Det var Malcolm Steward.
http://www.malcolmsteward.co.uk/?p=2534
Takk. Jeg var i ferd med å finne ut det samme. Det ser ut til å stemme at han har tilknytning til Hi-Fi Choice.
Jeg satt akkurat og så på noen søkeresultater.
Malcolm Steward:
The Original SATA Cable Post: http://www.malcolmsteward.co.uk/?p=2534
The SATA Cable Saga: http://www.malcolmsteward.co.uk/?p=2495
SATA: Friendly Fire?: http://www.malcolmsteward.co.uk/?p=2523
ZDNet: That SATA cable saga - the aftermath: http://www.zdnet.com/blog/hardware/that-sata-cable-saga-the-aftermath/9382
Det finnes mange flere.
CDWMcInSpots
Bergensregionen
Jeg lurer forresten på hvilken hifiprodusent ("highly successful British manufacturer") han hadde snakket og eksperimentert med:
Part 3
I decided to consult R&D engineers at an audio manufacturer just to prove once and for all whether the net terrorists who accused me of being delusional were correct. Surprisingly, these professional digital engineers did not consider it in the least bit odd that a SATA cable could influence musical performance. “We listened to dozens of SATA cables before we selected the ones we use in our equipment,” I was told at the outset.
I argued the assertion that digital was just 0s and 1s – it was either okay or not and was told “It might be 0s and 1s at either end of the cable but between the connectors it is effectively an analogue signal – albeit a square wave at a very high frequency.” Effectively, one software engineer argued, digital is best regarded ‘more as a concept’ than anything concrete. (Please note that this is the way he expressed this notion and is not my words. I am not saying anything philosophical about digital: I get in enough trouble just by saying it is imperfect. And it must be, else why does it need error correction?)
I do not wish to put any more noses out of joint but is it not interesting that a highly successful British manufacturer – one that has not become subsumed into a Chinese brand collecting empire nor is running on empty at the bank like some – treats SATA cables as regular components, just like resitors or capacitors, not as some perfect digital entity that cannot possibly influence sound quality?
The company’s MD, two R&D engineers, one of whom specialises in writing software, and I then compared a selection of cables in a hard disk player. Each displayed its own sonic character. The lead the company has produced, which is optimised for the equipment into which it was fitted – proved better in musical terms than both the samples I provided.
What I call the ‘Super SATA’ is clearly the better choice in my NAS but was not superior to the ‘standard’ lead in the HD player. The situation therefore seems even more convoluted than before. At least, however, I now know that I am not delusional. Or if I am then so are the individuals in the company I visited. Mind you, if they were I doubt it would be turning over the GBP millions it does.
Liotheles
CDWMcInSpots skrev:
Asbjørn skrev:
Tviler ikke. Og så er det noen andre av oss som ser på sånt som de målingene av intermodulasjonsforvrengning og jitterspektrum som Stereophile gjorde på en Squeezebox Touch og tenker at her er det ikke så mye behov for tweakeri:
Som du med rette har skrevet før:
På et eller annet punkt er det (mer enn) godt nok, og da er det ikke noe poeng å gå videre. Det er mye bedre å fokusere på noe annet.
Jeg syns det er greit å skille på type tweak..... de som er enkle å implementere og koster lite og de som er dyre og/eller er trøblete å få på plass.
Med soundcheck sitt TouchToolbox tweak er det BÅDE gratis OG enkelt, så da syns jeg det er greit å prøve. Syns tilogmed det gir en lydmessig gevinst så da er vel alt bare fryd og amen? ;)
_RoDa_
Jupp. Bortsett fra at det gir null effekt på signalet ut fra SBen. ;)
Hva kan man da forklare hørbar forskjell med?
CDWMcInSpots
Bergensregionen
Har noen målt á la Stereophile på Squeezebox Touch med og uten "soundcheck's Squeezebox Touch Toolbox"?
Lyttero?
_RoDa_
Sorry, tenkte på den andre supermodden.
Se tråd her på datahjørnet om parameterendring.
U
utgatt19288
Vet at Phil Leigh (fra User Forum Squeezebox) har et scop bilde på SPDIF utgangen av Touch før og etter implementering av Toolbox 2.0 -fant ikke noe. (Jitter målinger er krevende mht utstyr)
Ellers så er jeg helt på linje med Liotheles. Tweak som ikke koster noe og som er 100% reversible (factory reset) - er jo bare morsomt å prøve ut. Det eneste som kreves er litt mot til å sette i gang - eller er det vi som har misforstått noe?
Mens dere andre venter på jittermålinger så vil en håndfull av oss her inne oppgradere fra Toolbox 2.0 til Toolbox 3.0 som er like rundt hjørnet.
For all del. Jeg har ryddet bort alle mulige slags plugins som installerer seg automatisk med Squeezebox Server, i et håp om å spare litt regnekraft på serversiden. Noen ganger blir den en flaskehals når jeg streamer 24/96 med dropouts som konsekvens. Kall det gjerne en tweak, men forskjellen dropouts/ikke dropouts er i det minste ganske lett hørbar.
Finnes det en Toolbox for Transporter, forresten?
CDWMcInSpots
Bergensregionen
"soundcheck's Squeezebox Touch Toolbox" er vel en følge av at Squeezebox Touch er en liten, selvstendig datamaskin som kjører en liten Linux (med en liten Squeezebox Server)?
Det meste av jobben for Transporter og andre eldre plattformer utføres jo derimot av en annen enhet som kjører Squeezebox Server, f.eks. en datamaskin eller NAS.
Det er formodentlig mulig å tenke seg spesialversjoner av firmware, men jeg tror ikke jeg har hørt om at andre enn Logitech lager firmware, men jeg vet langtfra alt.
CDWMcInSpots
Bergensregionen
Malcolm Steward opplevde øyensynlig lydforskjeller ved bytte av SATA-kabler i en NAS.
Det virker da som om han mer eller mindre uten videre, publiserer dette (med brask og bram) som en sannhet. Det fremstår som merkelig.
Det naturlige og fornuftige hadde vært noe á la:
Dette funnet er mot all sunn fornuft. Hva kan være årsaken til at jeg hører forskjeller?
  • Sjekk kabler og koblinger for sikkerhets skyld
  • Har jeg en dårlig dag? -> Sjekk på nytt i morgen
  • Er det noe galt med mine ører? -> Be noen andre om hjelp
  • Lurer jeg meg selv? -> Blindtest
  • Andre forsøk/tiltak?
Hvis dette ikke avdekket noen årsak, og han fremdeles hørte forskjell, ville det vært naturlig å publisere noe á la:
Jeg har observert følgende ... og gjennomført følgende undersøkelser og eksperimenter ... Dette har jeg vanskelig for å tro på. Hva har jeg oversett? Hva kan være årsaken til mine observasjoner? ...
Trane
Søster & svoger er i ferd med å bygge hus. Første spadetak denne uken.
Om ikke lenge kommer et svært lass Leca til grunnmuren.
Jeg kommer til å insistere på at de får levert Leca-blokkene i en high end truck og at de blir lastet av i riktig rekkefølge og i klokkestyrt tempo for å unngå jitter i Leca-strømmen....det ville jo blitt et helvete å rekonfigurere rekkefølgen til en stødig grunnmur.
_RoDa_
Dere har ikke misforstått noe, det er moro å teste ut saker og ting!
Noe av grunnen til at vi sitter på gjerdet mens håndfullen (2 stk?) koser seg er at terskelen er for høy.
Dersom dere deler med dere og lærer oss hvordan vi kan ta del i dette så lover jeg å prøve det ut ;)
U
utgatt19288
Har en følelse av at du bare er en time unna - skulle vært fort gjort.
CDWMcInSpots
Bergensregionen
Fornuftig palleplassering kan faktisk være en god idé hvis man har plass, fordi det kan spare en del meter trilling og bæring under arbeidet. Dette er vanlig når man løfter opp takstein på tak med lastebilkran.
Lecajitter kan først bli et problem under selve muringen. Etter at mørtelen er blandet og lagt ut for et skift, har man kun en viss tid på seg til å mure dette skiftet og til å bruke opp mørtelen. Hvis man soser altfor mye, går det galt.
Nei, truckulykker ønsker vi jo ikke
Tillegg:
Utdrag fra Leca Byggebok side 10:
http://www.weber-norge.no/fileadmin...er/nye januar 2011/Leca Byggebok ORIGINAL.pdf
Adkomst
Det bør på et tidlig tidspunkt i byggearbeidet opparbeides god kjørbar vei helt inn til byggegruben. Da kan alle materialer kjøres helt inn på tomten og Leca pallene plasseres direkte i byggegruben med bilens kran.
Her er et par praktiske tips:
  • Plasser Leca-pallene slik at diagonalene kan måles. Se figur (10).
  • Blanding av mørtel bør foregå så nær muren som mulig. Plasser blandemaskinen slik at inntrilling av mørtel kan foretas enklest mulig gjennom hele murearbeidet
_RoDa_
Kult!
Er denne 3-ern sluppet eller kommer den etterhvert?
Liotheles
nma
Liotheles skrev:
Man skrev:
Mach2 bytter ut disken med en SSD disk. De fjerner også unødvendige drivere, ordbøker og slikt som bare plass på harddisken, men som ikke har noe å si for lydkvaliteten.
I tilleg har dem deaktivert flest mulig av prosessene som ikke er essensielle for å bruke OSX. Siden det er en del av disse prosessene, tar det nok tatt lang tid å teste ut alt hva man deaktivere og hva som er essensielt å beholde. Når de har funnet ut hvilken prosesser man kan deaktivere, så er det å lagre alt dette i et script slik at dette enkelt lar seg utføre på andre maskiner også. Det høres søkt ut men virksomheten er bygget opp med utgangspunkt i et shell script. Det er _svært_ enkelt å finne ut akkurat hva de har gjort om man sitter med et image av operativsystemet i en Mach2 mini.
Noe tilsvarende har blitt gjort for Squeezebox Touch for å tweake den til best mulig ytelse av en som kaller seg soundcheck. Se hans blog her:
http://soundcheck-audio.blogspot.com/2011/01/soundchecks-squeezebox-touch-toolbox-20.html
og denne tråden her:
http://www.hifisentralen.no/forum/index.php/topic,60107.0.html
Helt riktig. Forskjellen er at Mach2 tar seg godt betalt for hva som er essensielt et lite script som mer eller mindre gjør det samme. Det eneste som gjør at de slipper unna med det er nok at de markedsfører det som et "produkt", og at det ikke er en eller annen audiofil hacker har gjort det samme. Jeg tror neppe at han soundcheck-fyren hadde sluppet unna med det samme. Til det er det spesifikke squeezebox-miljøet såpass godt forankret i open source-mentaliteten. Det er jo forsovet OSX også, men man tenker jo normalt ikke over at OSX har sitt utspring i Unix.
Jeg har også eksperimentert litt med å deaktivere prosesser, men er ikke kommet helt i mål enda.. i motsetning til hva mange tror er det en haug av prosesser i OSX som ikke er nødvendige til vanlig bruk.
The Gunner
Har ikke peiling på dette, men har nå pløyd meg gjennom disse tre sidene uten å ha blitt særlig klokere. :-[
Så hva ble konklusjonen ifht trådstarter sitt "problem"? Er det bare å skaffe seg en Skvisbåks (Tøtsj), koble til en (god) DAC og kaste ut CD-spilleren, eller var det omvendt? ???
CDWMcInSpots
Bergensregionen
Hvis du liker CD-spilling, og misliker datamaskiner, er det godt mulig at en CD-spiller er det rette valget.
Ang. Squeezebox Touch (eller andre Squeezeboxer):
Asbjørn skrev at man må passe på at oppsettet av/parametrene i Squeezebox Server (og Squeezebox Touch) er fornuftige. Det er mulig å rote det til. Ditto for de rippede filene, replaygain, nettverk m.m.
Hvis avsnitt 2 ser "gresk" ut, må du velge avsnitt 1, være villig til å lære ("gresk") eller godta at Squeezebox-oppsettet ditt kanskje ikke er (helt) optimalt.
CDWMcInSpots
Bergensregionen
Etter leggetid i går kveld husket jeg plutselig noe jeg hadde snublet over og lest for lenge siden. Transporter har (etter sigende og med dagens standard) en relativt svak prosessor. Denne begrensningen skal visstnok være merkbar ved visse typer bruk 24 bit/96 kHz. Squeezebox Touch skal visstnok ha en vesentlig kraftigere prosessor, og dermed mindre fare for problemer på dette området.
Jeg gjorde et raskt søk og fant følgende (mine uthevninger):
http://forums.slimdevices.com/archive/index.php/t-87939.html
michael1232011-05-25, 12:44
CPU is weak and cannot carry the bitstream of 192/24 (which is also happening with 96/24 with high compression rate)..
Tillegg:
Hva er spesifikasjonene for din enhet som kjører Squeezebox Server? Under ovennevnte søk fant jeg ganske mye om problemer med 24 bit/96 kHz på svake Squeezebox Server-plattformer, typisk diverse NASer.
Jo, det blir av og til en "ploppelyd" når jeg går over fra 16/44.1 til 24/96. Den tror jeg skyldes begrensninger i CPU i Transporter. Det ble mye bedre etter siste firmwareoppdatering, men det er fortsatt en god idé å spare litt CPU-kraft med å begrense moroa på displayet ved å stille ned scrollehastighet osv. En sjelden gang kan det også bli dropouts underveis med 24/96, men aldri med 16/44.1. Det tror jeg skyldes begrensninger andre steder.
NAS'en er en Netgear ReadyNAS NVX. Den har jo en del kapasitet. Routeren er en gigabit-sak med kablet forbindelse mellom NAS og router. Jeg bruker default kompresjonsnivå 5 på FLAC-filer, forresten. Stort sett fungerer jo dette veldig bra, men noen ganger er til og med den kjeden litt i tregeste laget til å fylle opp bufferen idet en 24/96-fil begynner å spille.
CDWMcInSpots
Bergensregionen
Jeg formoder at en datamaskin istedenfor NAS vil(le) gi bedre kapasitet/headroom på akkurat dette området(?) Selv en ganske enkel datamaskin vil vel overgå Netgear ReadyNAS NVX o.l. i prosesseringskapasitet(?)
Tja, NVX'en har en Intel Tolapai prosessor som tusler avgårde med 1,2 GHz klokkefrekvens. Det tilsvarer vel en Pentium M laptop-CPU med en del ekstra funksjonalitet. Tror denne fortsatt er sammenlignbar med en low-end laptop i regnekraft, men noen stor tallknuser er den jo ikke.
Jeg har prøvd meg litt frem med å dekode FLAC->PCM på NAS'en og streame som PCM, vs. å streame som FLAC og dekode til PCM på Transporteren. Begge deler fungerer, men jeg har ikke testet nok med 24/96 til å være helt sikker på hva som gir minst sjanse for dropouts. Det hender jo at kidsa streamer video over samme trådløse nettverk. Selv med max prioritet for datatrafikken til Transporter kan det jo hende at det er nok til å skape en dropout.
Men generelt er det sånn at dette enten virker eller ikke virker. Det er ingen subtile forskjeller i lydkvalitet når det virker som det skal.
CDWMcInSpots
Bergensregionen
Trådløst nettverk kan vel både gi kapasitetsbegrensninger (båndbredde) som du er inne på, og forsinkelser ("lag")(?) Jeg trodde du benyttet kablet nettverk.
Jeg mener å huske at andre har rapportert om problemer med 24 bit/96 kHz og høyere over trådløst nettverk.
Dazed
Jeg har i alle fall aldri opplevd dropouts eller noe annet med hverken 24/96 eller noe annet over trådløst nettverk..
24/96 flac-filer har tross alt en bitrate på under 3Mbps, som er rundt en åttendedel av den virkelige kapasiteten i et 802.11b-nett (som begynner å bli avlegs nå.)
nma
Tror nok en Tolapai i utgangspunktet skal være mer eller mindre enn hurtig nok for å dekode flac i realtime uten noen problemer whatsoever. Selv om den baserer seg på en Pentium M med forminsket cache. (cachen var hovedforskjellen mellom Celeron og Pentium, Celeron var mye mye tregere hz for hz p.g.a den lavere ), så skal den gi omtrent samme ytelse som en Ultra, men støyer sikkert mye mer. Atom bruker mindre strøm og krever dermed også mindre kjøling.
Mitt nettverk er 802.11n via en D-link DIR-655. Den bør greie en 70 - 100 Mbps på en dårlig dag. Kablet mellom NAS og router, trådløst fra router til Transporter.
Barbaresco
Ethernet-protokollene har svært mye overhead, så bitrateberegninger må ha veldig store sikkerhetsmarginer. Stort sett klarer jeg meg med trådløst nett, men i ett tilvelle ble det mye dropouts, så jeg dro da opp kabel, og fortsetter å bruke den. Og ja, det er ikke små, diffuse nyanser, det fungerer eller blir helt borte. Ikke noe rom for synsing, som ellers med Hifi ;D
Dazed
Derav mitt anslag som sa at 3Mbps er ca. en åttendedel av reell kapasitet i et 802.11b-nettverk, som har teoretisk hastighet på 54Mbps
The Gunner
Nei, jeg misliker hverken det ene eller det andre. Er bare interessert i å få den beste lyden/signalet fra kilden, selv om det skulle innebære cd-skift. Så lat er jeg ikke ennå ;D
Altså, er det noen som kan verifisere eller falsifisere det trådstarter oppdaget? Noen som har prøvd det samme som ham og kommet frem til andre/samme resultater. Konkret? ???
authentic
Konklusjonen min er enkel, jeg gjorde en test for noen år tilbake og det finnes ingen forskjell.
Jeg testet imot samme dac bare at jeg gikk digitalt inn istedenfor å bruke drivverket. Samme spor rippet ifra samme plate ingen forskjell så det er bare å hoppe i det.
Petre
Siggerud
Ingen grunn til å tvile på at mange av dere ikke opplever forskjeller, altså finner Squeeze eller annen dataavspilling jevnbyrdig med CD. Med de brukerfordelene dataen tilbyr konverterer jeg tvert den dagen jeg opplever det samme hjemme hos meg, men den dagen er ennå ikke kommet. ( Med forbehold for at Touch kan være mye bedre enn Duet, som mine konklusjoner bygger på. )
CDWMcInSpots
Bergensregionen
Asbjørn har da besvart dette i svar #20. Husk også på at Asbjørn (normalt) er både grundig og rasjonell. Hans synspunkter er (som oftest) grundig og rasjonelt forankret.
PS: Parantesordene er inkl. for å ta høyde for at også Asbjørn kan tenkes ha en "dårlig" dag en meget sjelden gang.
marsboer
Phobos
Ethernet overhead er ikke noe problem for musikkavspilling for å si det slik. En ethernetpakke har en overhead på 38 bytes (42 om VLAN benyttes). Nyttedataene kan maksimalt være på 1500 bytes med mindre jumboframes benyttes. (1500/(1500+38))*100 = 97,5% utnyttelse på ethernetnivå.
Trådløst er så dårlig først og fremst fordi radiosignalene taper seg så fort og sekundært fordi en enkelt radio av natur er halv duplex med elendigheten det medfører.
Personlig lever jeg godt med min Transporter lydmessig. Ingen sammenligning jeg har gjort har fått meg til å tvile på dens evne som digital transport. Men så har det også vært dårlig med high end Hi-Fi CD-transporter her i hus.
CDWMcInSpots
Bergensregionen
Det er to "hull" her.
Ingen Squeezebox-produkter har 802.11n. Alle Squeezebox-produkter f.o.m. Squeezebox2 har 802.11g, mens Squeezebox har 802.11b og SLIMP3 kun kabel. T.o.m. Squeezebox 3 kunne man forøvrig velge om man ønsket en modell med eller uten trådløst nettverk.
http://www.smallnetbuilder.com/wireless/wireless-basics/30664-5-ways-to-fix-slow-80211n-speed
Fix #3: Don't Connect Draft 11n and 11b/g clients to the same router
An 802.11n router can also work with 802.11g and even 11b devices. But these much slower devices force the router to slow down to talk to them, which means a big throughput hit. Fortunately, the "legacy" mechanisms are pretty efficient and reduce throughput only when the slower devices are actively transmitting or receiving.
As we showed in Add, Don't Replace When Upgrading to 802.11n, mixing 11n and "legacy" clients can reduce throughput by 50 to 80%. So if you are mixing old and new devices, you could be shooting yourself in the (throughput) foot. Either upgrade to all 11n clients, or use a separate 802.11g router to handle your "legacy" stuff.
Siden alle Squeezebox-produkter er 802.11g (eller 802.11b), vil ovenstående mekanismer alltid gjelde når man faktisk benytter ("actively transmitting or receiving") et Squeezebox-produkt via trådløst nettverk. Selv i dvale, oppdaterer mange Squeezebox-produkter klokken, og når man slår dem på, kan man ofte øyeblikkelig finne en melding om at nå finnes det en firmwareoppgradering.
Alle dine trådløse nettverksdingser deler i praksis altså ikke lenger et 802.11n-nett, men isteden et 802.11g-nett, eller endog 802.11b-nett, helt uavhengig av deres egne innebygde muligheter.
CDWMcInSpots
Bergensregionen
Jeg foreslår at du går gjennom Asbjørns sjekkliste i svar #20:
Asbjørn skrev:
Min erfaring er den motsatte av trådstarters. Hos meg viste finlytting bedre tredimensjonalitet og generelt (litt) bedre lyd fra NAS enn fra CD ved identisk lydnivå. Da er det en Squeezebox Transporter som skyfler data videre til DAC'en, ikke en Duet.
Jeg ville først sett ganske nøye gjennom hvordan Squeezebox Server og selve Squeezebox'en er satt opp. For eksempel om den digitale volumkontrollen er aktiv. Jeg låser den til 100 % ettersom det finnes en analog volumkontroll senere i kjeden. Det kan også være lurt å slå av eventuelle ReplayGain-funksjoner hvis du vil sammenligne direkte med en CD. Da blir bitstrømmen fra NAS identisk med den fra CD, forutsatt at det ikke ble gjort noe rart under ripping. Se Spiller->Lyd->Volumkontroll i Server-innstillinger. Hvis alt ser OK ut, ville jeg kanskje mistenkt Duet'en og prøvd en Touch i stedet.
Jeg har ved sammenligning av Logitech Transporter og McIntosh MCD500 matet fra en Squeezebox Touch med et -10 dB signal rippet fra en test-CD, funnet ut at de ikke har samme utgangsnivå. Man kan lett bli lurt av slikt.
Dazed
Intet problem her, siden min Linksys WRT54GL ikke har noe raskere enn g, den heller. :) ...Men verdt å huske på når jeg kjøper ny wifi-router-
Det skal være sikkert, men kanskje oftere enn du tror. :)
